Question about HP Office Equipment & Supplies
My cd-rom of installation dosen't work - HP Office Equipment & Supplies
  • 21 Answers
You can download the driver for the printer from appropriate website. You can try the following link. Just select "Download software and drivers" and type in the product model name in the available box
http://welcome.hp.com/country/ca/en/support.html
Posted on Dec 16, 2008
My cd rom drive does not recognize media
First check CD (bad, scratch) Change it... if not OK then
then Check Software (like media player, VLC player) re-install it
if not OK then...
Then check Cable of cd rom (loos connection) in not OK then
bring any friend's or neighbor's CD ROM for few minutes and replace... if other CDROM working ok then problem in your CD ROM
open cd rom and Check Lance (head) of CD rom... mostly lance not working in these cases.
Oct 13, 2012 | Dell Inspiron 8600 Notebook
Im being told mine isnt compatible with my 64 bit pc
This is the specification mentioned on the website:
SYSTEM REQUIREMENTS PC:
  • Intel Pentium III 800MHz MMX compatible or higher
  • Microsoft Windows 98SE, ME, 2000 / XP
  • 64 MB RAM (128 MB or more)
  • CD-ROM drive
  • Available USB port
  • 160 free disk space
  • DirectX 8.0
Here are the links for the driver:
1.Windows Vista
2.WINDOWS 98/ME/2000/XP
If the webcam still dosen't work and gives you the compatibility problem then what you can try is you can run the program in compatibility mode and always run in as administrator. Give it a try. And let me know if this works in.
Thanks
Oct 07, 2012 | Genius Trek 310 Webcam
My hp laptop cd rom is not detecting the cds. i want to formate my laptop.
Hi there, do not format now. Just try these.
Run the driver disk & install the CD/DVD driver. After finish the setup restart your pc or laptop. Hope that time your CD rom detecting the cds. But make sure, that your rom is working. Because if the cd rom is damaged then after formatting you can't install the operating system. May be your cd rom lens is damaged & that's why he can't read the cds or dvds. I suggest you Visit a service center & check the cd rom only. If you able to view the cd rom driver in side the my computer then, i am sure your vd rom lens is damaged.
Thanks & waiting for your feedback.
Feb 14, 2010 | HP Compaq nx6110 PC Laptop
I re-installed windows and low level formatted the hard drive, and now the bios won't recognize the cd rom drive. I also ran the bios utility that comes with dell... what can I do to fix this problem. I...
Even if you don't have driver for CD-DVD ROM with the Operating System,your BIOS must recognize the CD ROM.Set the BIOS to Default setting and check it recognise now.Check if you have disable anything related to CD ROM in your BIOS. Remove your CD Rom and place it again and check.
Drive light comes because of power supply to the CD-ROM.
If nothing works,Download the firmware update
Here is the download link
ftp://ftp.us.dell.com/rmsd/R104295.EXE
Jan 04, 2010 | Dell Inspiron 1000 Notebook
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
Cd/dvd dosen work pleace geimy a solution
i cant get you. cd/dvd is not working or cd/dvd rom drive is not working ? To work cd/dvd rom drive properly, Make sure the Jumper settings of the drive is set to slave or else remove all the jumpers from the cd/dvd rom drive, it automatically sets to slave. Check the power cable and the FRC(flat ribbon cable) of the cd/dvd rom drive. Hopefully it should work. Thank you.
Sep 11, 2008 | Computers & Internet
Dvd-rom not installed but not working
Right click on cd rom device with yellow mark and click on uninstall. after that cd rom device is deleted from device list.now right click on Home and click scan for hardware changes.now you got driver installation for your cd rom.if not restart yopur system you will get driver installation.
Jun 08, 2008 | Biostar P4M80-M4 Motherboard
Installation problem
yah.. borrow some PC with cdrom working.. compy all files from installer cd to USB flash drive.. then install cam to your pc without cd rom.. or you can download installer from internet..
Jan 01, 2008 | Philips J44414
CD ROM Won't work
First you want to make sure the CD you are using is good. Try a different CD-ROM, a known good one. If a different CD-ROM is readable then the problem is with your CD media and not the CD-ROM Drive. If another known good CD does not work then the problem is with the drive.
To fix this you must purchase a new CD-ROM drive and install it. Newegg.com has great deals. If you only want to read CDs and are not interested in burning then you can get a name brand CD-ROM drive for around $15.00, but if you need to burn as well the CD+-RW will run you about $30.00.
If you are using Windows XP then it is pretty simple to install the new CD-ROM drive.
Nov 20, 2007 | HP Pavilion a1330n (EL466AA) PC Desktop
18 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
