Question about HP Deskjet D4260 Printer
Hi! I want to align my printing cartridges on my HP Deskjet 4260 and have forgotten how. Can you help?
  • bmadison613 Dec 16, 2008
    Thanks so much, TJ! Happy Holdidays to you!
    Novelist:
  • 157 Answers
Hey there and welcome to FixYa:
In order to align your print cartridges, all you need to do is:
1. load some letter sized paper in the paper tray
2. open the printer software that came with your printer
3. Click FILE, then PRINT
4. next, go ahead and click PROPERTIES (sometimes labeled PREFERENCES)
5. click the FEATURES tab, and then click the PRINTER SERVICES button. This opens up the printer toolbox.
6. Click ALIGN THE PRINT CARTRIDGES
7. Click ALIGN, and then follow the onscreen instructions.
This will print a test page that aligns that printer cartridges and calibrates the printer. Easy, huh?
Here is the manual
, and if you need anything else don't hesitate to ask!
Happy Holidays,
TJ
Posted on Dec 16, 2008
How do i do a print aligennment on a hp deskjet 6540
The printer automatically aligns the print cartridges after a new print cartridge is installed. You can also align the print cartridges at other times to ensure optimal print quality.
To align print cartridges:
1. Load letter-size or A4-size plain white paper in the In tray.
2. Open the printer Toolbox.
3. Click Align the Device.
4. Click Align , and then follow the onscreen instructions
Here are directions for how to open the printer Toolbox, in case you don't know:
The printer Toolbox contains a number of useful tools to enhance the printer performance.
Use the printer tools to perform the following tasks:
• Set the Auto-off function
• Clean the print cartridges
• Align the print cartridges
• Calibrate color
• Print a test page
• View estimated ink levels
To use the tools, open the Printer Properties dialog box, click the Services tab, and
then click the Service this device button.
AND, in case you don't know how to open the Printer Properties dialog box, here you go! :
The Printer Properties dialog box is also referred to as the Printer Preferences dialog box.
Opening the Printer Properties dialog box
Follow these steps to open the Printer Properties dialog box:
1. Open the file that you want to print.
2. Click File , click Print , and then click Properties or Preferences.
Good luck to you! I hope this helps.
Aug 07, 2014 | HP DeskJet 6540 InkJet Printer
I have problem that on my hp 1220 deskjet ar blinking all of buttons. I mean buttons for power, buttons for parer and button for cartrige and don't printing anything. How can I fix this?
Hi, This is the problem of cartridge mostly. You may need to replace the cartridges. Check the cartridges and make sure that the cartridges are not blank or not get the ink dry. Clean the printing head 2-3 times. Align the cartridges and clean the nozzles also. Reset your printer and remove all pending print job. If it doesn't solve your problem then replace the cartridges.
Sep 26, 2011 | HP DeskJet 1220c InkJet Printer
HP 950c printer is printing blurry. This started after changing the ink cartridges any idea what I can do it was not doing this before changing the cartridge and I have used servarl different cartridges.
HI ,
Hope somebody can help, my text is printing the top half of the script blurred but the bottom half is clear! My printer is a canon ip2600. I have newish cartridges and everything has been cleaned and aligned. Cheers
Apr 22, 2011 | HP DeskJet 950c InkJet Printer
I get a blurry result when printing. almost as if it gets printed twice on the same paper
Hi, this usally is becuase the carttridges are not calibrated/aligned.
To align the cartridges:
(extrated from HP.com)
  1. Open the HP Deskjet Toolbox .
  2. Click Align the Print Cartridges .
  3. Click Align , and the first test page will print.
  4. Examine the test page and follow the onscreen instructions to complete the Align Print Cartridges dialog box.
  5. After completing the Align Print Cartridges dialog box, click Continue . The second test page prints.
  6. Compare the second test page to the onscreen example and follow the onscreen instructions to complete the alignment process.
Cheers,
Ed
Oct 24, 2009 | HP DeskJet 845c Printer
Blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
Apr 15, 2009 | HP DeskJet 3745 Printer
How to align my HP DeskJet 694C ink cartridge
Hi, have you tried another cartridge? Sometimes if a cartridge has been sitting around for a while, they become blocked with dry ink and print quality gets poor.
Dec 16, 2008 | HP DeskJet 694c InkJet Printer
Actually for a HP deskjet 990cxi
Alignment:
1. Turn on the HP DeskJet.
2. Disconnect the USB cable from the all-in-one.
3. Press the sequence of front panel buttons below to start the print cartridge alignment process.
The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
1. Press and hold Cancel .
2. While holding Cancel , press On .
3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
4. Press Cancel again.
5. Press Copies .
6. Press Paper Type .
7. Press Color Start Copy .
The alignment page will begin printing.
If the alignment page does not print, repeat the button-press sequence in this step.
4. When the alignment page has printed, place the page face down on the scanner glass and press Scan .
The alignment is complete when the On light stops blinking.
5. Reconnect the USB cable.
Jun 03, 2008 | HP DeskJet 940c InkJet Printer
Printer Not Align
Pls replace the printer en-coder strip, after that check it will solved automatically.
Apr 02, 2008 | HP DeskJet 9670 InkJet Printer
HP Deskjet D4260 Printer Logo
431 people viewed this question
Seeker5211
Seeker5211
