Question about Magellan RoadMate 700 GPS Receiver
The screen images are in reverse
After coming on the screen will start to go white. Turning the unit off then on seems to fix the screen except everything on the screen is in reverse. Also have the sound problem, but can hear a slight scrathing sound when the voice is supposed to be saying something. Wondering if its worth getting it fixed with the way GPS prices are falling.
    Novelist:
    Scholar:
  • 86 Answers
For clarification: You turn on your unit, the blue magellan logo appears clearly, but then the screen slowly starts turning white. Turning the unit off/on fixes the white but images are in reverse. CAUTION: It would help if you were grounded in some way prior to proceeding. Also, of course do this at your own risk. Make sure the cable going from the main board to the LCD is making a solid connection: 1. Take screws out of rear housing 2. Slightly seperate the rear/front housing 3. Disconnect the RF cable attached on the corner of the main board. 4. Pull off (or locate if they already fell off) 4 O rings from the screw mounts. 5. Fold over mainboard ontop of rear housing 6. Use fingernail or tweezers to lift up the plastic locking mechanism that attaches your LCD to the backside of your mainboard. 7. Pull out LCD cable, inspect for "gunk" on conacts (clean if necessary) 8. Shove cable back into slot on mainboard 9. Press down locking mechanism 10. fold mainboard back over 11. Put 4 O rings back on screw mounts 12. PLUG RF CABLE BACK IN! (signal will be zero if this doesn't happen) 13. Fit together front/back and screw back in.
Posted on May 04, 2007
Left half of screen dimmer than right
same issue with my 47le5900 - I have fixed it... if I look through the back panel I can see a circuit board on the right... coming out of this at the top are two flat data cables, each about 1 1/2 inches wide, one is labeled (L) the other (R), it seems the (R) one was a little loose, so I pressed it downwards with a small screwdriver, problem solved.
Jun 25, 2012 | LG 42LE5500 42 in. TV
My lg dvd player doesn't show images (except the black and white diplay on the screen) but i can hear the sound playing, the kids might have changed some thing in the setup. please help if there a
Hello
You haven't given the exact model number ot your LG DVD, so I can only give you a general solution to this problem.
Get into its meny, surf through, come to SYSTEM adjust window, change the system. If a NTSC system recorded disc played with PAL system adjustment with DVD, there will be only black/white pciture, and vice versa.
Adjust it to the color system thathave been adopted your country. this must solve the problem. OK.
Jan 31, 2012 | LG Televison & Video
No image on screen, screen is black except for icons
Sony will fix until March 10,2010. Go to this site and file the form.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Jan 06, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Phaser 7300 - one color fading on diagnostics page
Are you using third party toner? That is one thing that causes that problem. Use only xerox toner.
The other thing is that your image unit could have come defected, if it was brand new. Try changing the image unit and that should fix that problem. Good luck. 016-1993-00 image unit & toner 016-1977-00
Oct 02, 2009 | Xerox Phaser 7300DN Laser Printer
Reel to reel plays audio backwards
HAVE YOU TRIED TURNING THE REELS OVER? ON SOME PANASONIC UNITS THE REELS CAN BE PLAYED IN EITHER DIRECTION BUT THE SOUND IS REVERSED IF THE REELS ARE UP SIDE DOWN. TRY TURNING THE REELS OVER AND IT SHOULD STRAIGHTEN OUT YOUR AUDIO PROBLEM AS WELL AS BOOST THE VOLUME
JAMESFWALKERJR2006@YAHOO.COM
Aug 29, 2009 | Quantegy 456 Reel-To-Reel Recording Tape...
Solid white screen on my laptop
sounds like the on-board video card is dying/ or the screen is dying too
Apr 11, 2009 | Computers & Internet
White turns to pink on acer laptop
The problem is CCFL light bulb in the screen. It is starting to die :( Can be replaced but that is not an easy task (easier is to replace screen as new bulb comes with it)
Jan 12, 2009 | Acer Aspire 5630 Notebook
Multiple screen coming up in black and white also flickering on and off
I have a logitech quickcam E3500
I have 4 black & white images
I tried downloading older and newer versions of the software, no joy.
From the logitech site, I found this fix:
Go to Start>Run, type "dxdiag", wait for the application to show, then go to the "Display" tab and disable Direct3D acceleration or Directdraw acceleration. Exit. That's all.
I tried it and it works a treat.
May 16, 2008 | Logitech QuickCam Pro 5000 Webcam
SCP-7050 screen reads backwards like a mirror image
I had the same problem with my phone, had it fixed once under warranty a few months later had the same problem. They told me it would cost a fortune to fix, I was about ready to give up until i examined the phone a bit further, it seemed as though the contacts on the battery were somewhat worn, I simply packed some paper between the battery case and the top of the battery, seemed to fix the problem for now.
Aug 03, 2007 | Sanyo SCP-7050 Cellular Phone
Magellan RoadMate 700 GPS Receiver Logo
103 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
