Remote control is not sending signal to pioneer karoake machine
The machine is working fine, but i cannot run the machine from the remote control and i changed the batteries, could it be the remote or possibly the infared in the machine. control parts number is pww1062 and the pioneer karoake machine model is PD-V10G. someone told me i could test the remote control by using a analog radio on AM and see it is puts out a signal, is that correct and if so what should i look for. How or where do i check for the infared, assuming that the remote is ok. Remotes costs from $39 to $49 plus shipping and tax.
bobotfel
  • 236 Answers
SOURCE: remotes won't work
There is a reset button in your remote try to reset it then try the remote to your unit. If it wont work then the receiver board is defective.
Posted on Jan 04, 2008
harry0000010
  • 40 Answers
SOURCE: Toshiba 50A62 Remote Infrared Sensor
I have replaced these IR sensors before and it has solved the problem...they dont blow all the way..they just get weak......replace it.
Posted on Jan 26, 2008
robotek
  • 1512 Answers
SOURCE: Need radio shack remote control code.
It will be one of these codes.
Orion 0236, 0463, 1463
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=radioshack&dv=universalremote&md=1521473in1easytouse&kw=&st=&ar=&dt=&so=&pg=3&file=others/radio_shack/152147-manual.zip
you can go to the manual direct at. Good luck
Posted on Jan 29, 2008
TotalControl
  • 23 Answers
SOURCE: pioneer remote for receiver
It's quite likely the codes are the same. Check the manuals for the models on Pioneer's website (www.pioneerelectronics.com) for the year/date they were issued. For most models issued around the same time the codes were the same, but they also post IR codes, so you can verify there as well. If you can't find any information I will give you info on ordering the exact remote you need and options for universal remotes that have your model.
Regards,
Vincent J. Bova
Total Control Remotes
Programming Remotes & Advanced Control systems
www.totalcontrolremotes.com
Posted on Dec 12, 2008
SOURCE: Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Posted on Dec 26, 2008
What to do if PIONEER DVR-940HX is not responding at remote control comands
Have you tried a cheap universal remote just to verify the receiver is working for the infrared remote signal?
Jun 21, 2016 | Pioneer Televison & Video
PIONEER RECEIVER VSX9700S REMOTE ISSUE
check your remote. try fresh batteries as well. if it still wont work, try opening your remote and clean it with a soft bristle brush or the like. try testing it again.
Jan 27, 2008 | Pioneer VSX-D906S Receiver
Remote No Longer Operates the BluRay Player
If you have tried battery removal and reinstallation/replacement it may be necessary to replace the remote
Nov 04, 2012 | Pioneer New Original VXX3379 Remote...
Remote control problem pioneer dv-f727
A few thoughts.
1. The remote was water/liquid damaged and the buttons no loger make contact with the silicon board to send a signal.
2. Low battery??
3. If you are using a universal remote, you may have found a code that only partially functions. Keep going through the codes until you find one that fully functions.
Hope this helps!
Jun 26, 2012 | Pioneer DV-F727 DVD Player
Hello, I bought audio4you karoake mixer but did not get activation code. In spite of sending 3-4 emails I did not get any response from them. Is this company cheating customer? I am going to publish...
Hello, I bought audio4you karoake mixer but did not get activation code. In spite of sending 3-4 emails I did not get any response from them. Is this company cheating customer? I am going to publish this internet Please let me know if we get crack version of karoake. Thanks, Israel
Feb 12, 2011 | Audio4You Software Karaoke Mixer
Reciever only allows 2 channels(speakers) at a time.
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
Jan 03, 2009 | Pioneer VSX-818V-K Receiver
I have a Pioneer VSX1016TXV-K receiver & the remote doesn't work
It is unlikely to be the sensor. Could be the wrong code from the controller.
Jun 17, 2017 | Pioneer VSX-1016 Receiver
Pioneer 530H DVD recorder
You said that you have changed the batteries.
While you're checking the batteries, make sure that the contacts for the batteries aren't corroded or bent. You can clean them with a pencil eraser followed by a nail file. If necessary, gently bend them back to their correct position.
Try these too,
  • Go up to the receiver and try changing the channels without using the Remote Control.
  • Refer to the Remote Control setup instructions, and make sure you have the correct codes programmed for your equipment.
  • Make sure nothing is blocking the front of the receiver (e.g., furniture).
  • Make sure you are operating the Remote Control within 20 feet of the receiver.
If all the above doesnt work,
Then
Either the remote or the receptor on the device is not functioning.
1. Use an Infrared Sensor Card to see if the remote is sending a signal.
2. If the remote is sending a signal, it used to control that device, and no other solution works, you should have a service center look at the device and remote to determine the problem and if it can be fixed.
You can visit this site for further support, www.pioneerelectronics.com/PUSA/Support/CarAudioVideo
Hope my info solves your problem,
Thanx for using fixya....
Oct 01, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
