I have a dell dim. e521 when i did an update it seemed like the sound card quit working help
    Genius:
  • 1,605 Answers
Go to dell.com>> support and service>> type in the model number and download the audio driver for the system.
Posted on Dec 16, 2008
Dell e521 onboard network card will not register in system utilities and neither will any card put into pci slots. after much trial I did get the pci express slot to see a video card but even this is not...
Try cleaning your registry with Eusing free registry cleaner, and if that doesn't help try this, click start, control panel, performance and mainteneance, see basic information about your computer, the hardware tab, device manager, system devices, then double click your PCI bridge (name varies from motherboard to motherboard but it should have pci bridge in the name) then update driver, if the driver is currently up to date then roll back driver. Hope this helps, Daniel
Oct 23, 2010 | Dell Dimension E521 PC Desktop
Dimension e521 doesn't boot, black screen
no you got it my freind just take the gfx card out (when the power is off and its unpluged)
and you can try the onboard gfx but remeber depending on the game you might not get v/g gfx or might be basic and if its having to boot to safe mode you might with the hard shut down have destroyed windows itself but you can alwas reistall alsow check your anti virise sounds mad but one you go on to the chip set get avast and do a boot scan once its updated as its a great antivirise
Mar 13, 2010 | Dell Dimension E521 PC Desktop
Help! My dell dimension E521 will not boot after
Its seems like your RAM is not working properly, so once you replace the this RAM and check it, you problem should be resolve.
Regards
Ashly
Feb 01, 2010 | Dell Dimension E521 PC Desktop
Where is the sound card located in a dell e521?
the sound card is the card that holds the audio jack. if it is bad, you cant remove it. you only have to by and external audio jack and use it via your usb port
Jan 23, 2010 | Dell Dimension E521 PC Desktop
Hello, i have a dell dimesion e521. Our power
just remove your ram and reinstall it. that is loose contact problem.
Dec 11, 2009 | Dell Dimension E521 PC Desktop
I need help upgrading PLZ URGENT dell dimension E521
The most powerful CPU Dell sole in the E521 was the 5600+, 2.8G, Pretty Cheap on EBay
http://shop.ebay.com/i.html?_nkw=Athlon+5600%2B&_sacat=0&_trksid=p3286.m270.l1313&_odkw=Athlon%2C+5600%2B%2C+2.8G%2C+1MX2%2C+Dual+Core%2C&_osacat=0
Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150369
Power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007
Oct 08, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
I recently got my computer fix but it came back with no audio.
Did you check that compatible driver for your audio device is installed Properly? Go to Device Manager and verify. if there is yellow marked device error with name of Audio/Sound you need to update this driver.
Go to;
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=DIM_P4_E521&os=WW1&osl=en&catid=&impid=
Download and install/update this driver, reboot your system and check audio output. Hope this will work for you.
Best of Luck,
Regards;
Hassan
Jul 27, 2009 | Compaq Audio card Sound Card
Please direct me to a diagram that explains the symbols on the sound board connectors. Dell Dim E521 code JX80N2J
Right mouse click on my computer. then u get hardwere click .then u get sound optionwith speaker sign .if there is yellow sign .keep *********** bord cd on optiifcal drive . then right mouse click on yellow sign then u can update your sound driver. 2/ type "control" on run then u can get speaker and sound . correct it setting .i thik u can do. 3/ if not work keep sound card in your computer mother board slaut to check sound.
Jul 11, 2009 | Computers & Internet
DELL PART # DN804 For E521 computer
Hi
Dell Part # DN804 is PCI-e ATI Theater 650 Pro Combo Analog/Digital TV Tuner and it is compatible with Dell Dimension E521.
The ATI Theater 650 Pro PCI-e card is available in two form factors - Low Profile or Full Height. Dimension E521 is compatible with Full Height cards only. It is important that you ensure the you receive a full height card.
Check Installing a PCI Express Card for help installing the hardware. Next install required software/drivers.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/parts.htm#wp1080274
Mike
May 03, 2008 | Dell PART NUMBER CARD NTWK PCI TR IBM 16/4...
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
