Question about Sony CMT-CPX11 CD Shelf System
System turns off!
Need some help, ive got a Sony CMT-CPX11 system, and when i turn it on, it turns off automatically after 1 or 2 seconds and then the stand-by light continues to flash. It cant seem to stay on. Any suggestions on why this is occuring? Thanks
  • Anonymous Feb 18, 2008
    I have the same problem. Try to unplug the CPX11 and leave it for a minute. Plug it in and it might work, my CPX does so.
    Håkan
  • 691 Answers
The flashing standby light indicates the system detects a fault. When the ?/1 (?/1 is the symbol for the standby button lamp) indicator flashes Immediately unplug the mains lead and check the following items. ? If your system has a voltage selector, is the voltage selector set to the correct voltage? Check the voltage for your region, then make sure the voltage selector is set correctly. ? Are the + and ? speaker cords short circuited? ? Are you using the supplied speakers? ? Is anything blocking the ventilation holes on the rear of the system? (The thermal cut out may be operating but more likely after a longer period of use) Check all the above items and fix any problems found. After ?/1 indicator stops flashing, reconnect the mains lead and turn on the system. I f the indicator still flashes, or if the cause of the problem cannot be found even after checking all the above items, consult your nearest Sony dealer.
Posted on Jul 02, 2007
Set time on sonymp3 cmt-bx20i
You need to use buttons on the remote to set the clock.
1.Turn on the system.
2.To select the clock set mode press TIMER MENU. If the current mode appears on the display, press up and/or down to select
"CLOCK SET?" and then press (+)
3.To set the time. Press up and/or down to set the hour, and then press (+) to confirm. Repeat to set minutes.
The clock needs to be re-set whenever power is lost to the unit.
The clock can be momentarily displayed when the system is off by pressing DISPLAY. The clock is then displayed for about 8
seconds.
The full support section with manual downloads is available here for further help and guidance:
http://esupport.sony.com/US/p/model-home.pl?mdl=CMTBX20I
Hope this is of help.
Dec 17, 2014 | Sony Vertical iPod micro system CMTLX20I...
Stuck in standby
You can reset all to factory settings, which may help; unplug power, put back in switch on with power button. Then press together "tape", "CD" and the power button. You may need to reset the clock before it will work. If you need the manual, here is the link; http://pdf.crse.com/manuals/2048589112.pdf check page 26 for the reset if not clear - nothing else in there that seems to be related, but you may find something i missed. Hope this helps :)
Jul 01, 2007 | Sony CMT-CPX11 CD Shelf System
Need remote for cmt ex100
1) http://remotes.com/store/sony/cmtex100.html,
2) http://www.dvdremotecontrols.com/Mfrs/device_files.php?brand=SONY&dt=AUDIO,
3) http://www.newtvremotes.com/Catalog/Item.php?BLI=SONY&CG=1&model=CMT-EX100&qlref=317876741
Feb 08, 2013 | Sony CMT-EX100 CD Shelf System
I can't turn demo mode off or Standby from flashing on my Sony CMT-MX550i, can't turn unit off without unplugging it.
Sony CMT-MX550i -- I had good results by pressing the "TIMER MENU" button on the remote and simply setting the time. After that, no more demo.
Jan 16, 2013 | Sony CMTMX500i Desktop Micro System
Sony CMT-GP5 subwoofer output very quiet
From the description the subwoofer is the problem, since the item is new return it to the place of purchase, this is a manufacture issue.
Aug 13, 2012 | Sony CMT-GP5 CD Shelf System
My sony cmt-nex3 has the standby light flashing, but when i press the on butto, it doesn't turn on
Check the back for speaker wire shorts, next! there may be a short in the audio output chip or surrounding parts in the stereo, this is more suited for a technician to sort out.
Jul 03, 2012 | Sony CMT-NEZ3 Shelf System
Sont CMT-NEZ5 won't stay on, standby light blinks
Hello
I haven't the schematic diagram to your set at present. If you send the schematic you have with me now, I'll refer it and will give you further assistance. OK.
gopalan.gopakumar327@gmail.com
Nov 10, 2011 | Sony CMT-NE5 CD Shelf System
Sony CMT-EP515 CD Shelf System. CDs wont play. Place CD in tray and close, disc doesnt spin but 4 distinct clicks heard then nothing
It could be 3 things.
1. the Laser carrier may be stuck and may need to be gently pried from centre to outskirt and back.
2. your cd spinning motor has gone and needs to be replaced,
3. your laser carrier motor has gone and needs to be replaced,
hope it helps.
Aug 04, 2010 | Sony CMT-EP515 CD Shelf System
Please help - I purchased my Mother an iPod (4g NANO) for Christmas and need to know how she can hook up the iPod to her stereo system to use it as I do at home. With mine all I needed was a AUX Cable...
All you need is a 1/8th stereo adapter that runs two rca jacks out red/white! You can get this at any radio shack store...Plug jack 1/8th into mp3 player and the red/white jacke can plug into her aux input Or any other input!
Please rate my answer and help keep this site free!
Thank You
Dec 23, 2008 | Sony CMT-HP7 CD Shelf System
CD Player
WIthout knowing the specific model, I can't be 100% sure, but a number of models in that vintage had a problem with cracked ribbin cables that go to the drawer unit. Replacing the cable usually fixed the problem. What is the specific model number?
Dan
Jul 29, 2008 | Sony CMT-CPX11 CD Shelf System
Sony CMT-CPX11 CD Shelf System Logo
413 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
