Question about HP Pavilion a810n (PP164AA) PC Desktop
HP Pavilion a810n green light flashing but won't power on
Green power supply light flashing , but computer will not turn on. I have taken the front casing off and tried the power button that way, and still nothing. I have tried to "reset" cpu by pulling and replacing ribbon cables with power to computer, that didn't work, and it has always been foolproof way to start computer. Help?!
  • jleighkelley
    jleighkelley Aug 08, 2012
    Nope, the hard drive was fried.
    Sergeant:
  • 176 Answers
It sounds like power supply problem
Posted on Aug 06, 2012
SOURCE:
SOURCE: Hav a pavilion a510n HP
I had a similar problem. Moved a 4-year-old desktop. Got the flashing light and no start. Quick fix is to unplug unit, open up case and unplug the large power connector on the motherboard. (On mine this is marked P1 and has a lock tab on one side that must be held in while unplugging.) Plug the 110-volt power and THEN plug the connector back into the motherboard. Button the case back up and all will be well until the next time you shut the power off to the computer.
The cause of this problem is likely that the battery on the motherboard is nearly dead. The flashing light is a warning to replace the battery. (It would have been nice if they would have put this into the user manual.) When you disconnect the power as described above, you interrupt the low-battery circuit. Replace the battery and all should be well.
Posted on Dec 02, 2008
siawolf
  • 749 Answers
SOURCE: HP Pavilion A767C Computer. Power
I would check your fans first , a failed cpu fan will cause the computer to overheat and not start.then cables, add-in cards and memory to be sure ones not halfway in it's slot.. then i would suspect the power supply, they can be missing power on a rail and still have a light on the back. you can buy a power supply tester at tigerdirect for 20 dollars. once all this is checked , i would look to the motherboard..
hope this helps in the decision making process..
Regards.
Posted on Oct 29, 2008
jtuckerj
  • 59 Answers
SOURCE: HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
Posted on Dec 12, 2008
SOURCE: i had a powercut, when power returned, computer would not boot
what you have to is to unlplug the cord then cut the computer on
Posted on Feb 14, 2010
mrninja
  • 600 Answers
SOURCE: my "hp pavilion a220n" won't
Check all wires for loose connections--- if the memory was wrong or something, it would still attempt to boot but stop during the POST and start to beep
Posted on Dec 23, 2010
Blinking green light, will not power on
Did you have a surge protector that your computer was plugged in if not it may have done something to your power supply good luc hope this helps Merry Christmas
Dec 09, 2017 | HP Pavilion a810n (PP164AA) PC Desktop
HP Pavilion a 1250n won't turn on. Green light is on under the plug in the back but noghting else.
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Sep 22, 2012 | HP Pavilion a1250n (EG194AA) PC Desktop
Please try the following:
1.remove the power cable an plug it again
2.check is the power it's on at the back of the source.
3.if you hear some noises write them down and search for the error codes on the net.
Green power supply light is flashing so power is getting to the computer, however the computer will not start from start button. Have removed case and tried ***** start button. Didn't work. Comput
Power getting to the computer/Power Supply?
Yeah.
Power Supply good? -> NO
A) IF ALL of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
HP Pavilion a810n Desktop PC?
Uses an AMD Athlon 64 3300+ processor,
(Operates Up To a frequency rate of 2.4GHz)
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00280647
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_microprocessors#.22Newcastle.22_.28CG.2C_130_nm.29
Can use up to 89 Watts of power.
Your Power Supply doesn't even have enough power to spin fans, much less start the Processor.
Want to test the Power Supply? Have a multimeter?
No? Have a power supply you can borrow for a test unit?
KNOWN to be good, and Compatible?
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 05, 2012 | HP Computers & Internet
HP Pavilion a1020n will not power on.
The green LED light at the back of the Power Supply, is now a diagnostic LED light.
Tells you the Power Supply is bad.
HP Support > Pavilion a1020n Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=459880&lc=en&cc=us&dlc=en&lang=en&cc=us
Solve a problem > Start-up / Shutdown / Power >
(No Thanks) > Power management,
Scroll down. Click on the + sign to the left of the blue -
Power supply light is on or flashes
(When the PC worked the green light stayed on constantly. You are correct)
Now,...
1) Is the computer dirty inside? Need to know how to properly clean it?
2) Would you like to know the easy test, to see if the problem may be a $5 ATX power on switch, or the Power Supply?
3) I also suggest you remove all ram memory modules, ('Stick'), and clean their gold plated contact pins, with an eraser.
There is a proper procedure for this.
Post in a Comment if you wish to know.
Regards,
joecoolvette
{By the by. Did you or your father live in K.C.K, (USA), and does the name Philip B., ring a bell? }
Jul 02, 2012 | Computers & Internet
Hp pavilion a1217n tower won't power up...the green light in the back is blinking rapidly....help!
it could be 3 things eigther the hard drive failed or power supply went out or mother board went bad you can take it to a reputable computer repair store and they will check these for free
Jul 08, 2011 | HP Pavilion a1217n Desktop PC
Suddenly my hp pavilion a1217n tower won't turn on...the green light is blinking rapidly...
are you referring to the light on the back? if so the power supply has most likely failed, mother board can also cause this issue.
I have an HP Pavilion a384x. It will not turn on
First with the computer turned off make sure the switch on the power supply is set to 115v.
If you turn the computer back on and you still get a flashing green light on the back of the power supply and a constant light on the front of the computer with no video, then try replacing the power supply with either a new one or a known working good one.
If that doesn't do it then it has to be the motherboard at that point.
Keep in mind normally on those power supplies, the green light should be constant. So it has to be either the power supply is bad or the moterboard is bad and you'll know when you put a new or known good working power supply in the computer.
Aug 03, 2009 | HP Computers & Internet
Dec 12, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
HP Pavilion a810n (PP164AA) PC Desktop Logo
836 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
