Question about Dell Inspiron 6400 Notebook
Button broke off PC keyboard
I have a Dell Inspiron lap top and my arrow-right key came off. It does not look broken but I don't know how to fit it back on. Can you help?
  • neilgards Dec 20, 2008
    Many thanks for the tip. It worked a treat.
    Do you know how to keep my kids off the PC?!
  • 57 Answers
Is it a flat key or a normal keyboard type key?
If its a flat key make sure the things underneath the key are flat against the key and put it back on its spot and just press down on it until it clicks. You may need to press hard but please don't press too hard or you might do some damage.
Posted on Dec 16, 2008
  • Andrew
    Andrew Dec 20, 2008
    It depends on what you want to do.
    If you want to keep them from doing anything on it I would use CA Parental Controls. Its made by Computer Associates and lets you set what times they are allowed on and such,
    If you want to keep them off your PC period I would just hide it.
How can i tell if my keyboard is backlit in inspiron 15r?
If you press any key on the keyboard, the back light should come on automatically. If not, hold down (Fn) function key and press "right arrow" with a blue florescent symbol until the back light is lit. Pressing the "right arrow" key while holding down the (Fn) key lits the back light and can also reduce, increase the light.
Hope this helps
May 31, 2014 | Dell Inspiron 15R Laptop
Everything on my screen is going side ways the cat walked on the key board can you help
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key.Restore by pressing Ctrl-Alt plus the up arrow key.ALSOTo change the display from portrait to landscapePress Ctrl-Alt plus a left or right arrow key.Some computers do not have this function.
Jun 26, 2012 | Dell Inspiron 1318 Notebook
Where is the enter button on my keyboard
The enter button will be located to the right of your keyboard. under back space and above shift. The enter key will have an arrow pointing left on it. Usually 3rd button down at the far right of keyboard.
Hope this helps and please rate thanks
Mar 19, 2011 | Dell Inspiron 1300 Notebook
How can I lower the brightness of my screen in my Dell 1525 lapto
Sometimes the brightness is on the arrow keys hit the Fn or function key and press down on the arrow to dim the light or press up on the arrow key to increase brightness
Jul 28, 2009 | Dell Inspiron 1525 Laptop
How to install xp in dell
you must first tell the computer to boot from the cd and not the hard drive. this is done-> turn the computer on when you see any word it the top right hand corner push F2 on you keyboard. that will get you into the setup. your looking for boot sequence use your arrow keys (mouse doesn't work yet) when you find it hit Enter now you want to put the CD/Rom in the boot first position select it with the arrow keys and use the letter U (up) & D (you got it -down) to put in the first spot.
then hit ENTER then ESC...exit and save
then put the disc in the cd player and reboot...the follow the instructions...it's pretty straight forward.
If you need more help...ask again. Hope this helps
Apr 23, 2009 | Dell Inspiron 1525 Laptop
I have a new key board but I don`t no how to remover the broken one its a dell inspron 1525 lap top
The link below will take you to a step by step guide for replacing the keyboard:
http://support.dell.com/support/edocs/systems/ins1525/en/SM/keyboard.htm#wp1180346
Good luck and please let me know how you do with the replacement.
~ Spoem
Apr 13, 2009 | Dell Inspiron 1525 Notebook
Back arrow not working and cursor jumping around
you laptop is going through a keyboard failure.
Apr 03, 2009 | Dell Inspiron 2650 Notebook
How do u put a enter button bk on
If the plasic clips are damaged then you can get replacements from ebay very cheaply, just search for you laptops model number + replacement keys, most will come with the clips and instructions on how to fit them.
If they are intact then they will just clip back onto the keyboard, if you tell me the laptop model i can tell you how, there should also be a little rubber "spring" which allows the key to spring back up. for most keyboards they will go back on with the wider edge at the bottom.
Dec 10, 2008 | Dell Inspiron 1501 Notebook
Inspiron 5100 bios a32, keyboard
You can try reseating the keyboard connector. If that doesn’t work, the keyboard needs to be replaced. To reseat the keyboard connector, follow this link: http://support.dell.com/support/edocs/systems/ins5100/en/sm/keyboard.htm#1084976
Be sure to remove AC power and the Battery.
Nov 01, 2008 | Dell Inspiron 5100 Notebook
Keys dont work.alternative way to change brightness?
Yes you can go into your display properties and look in the settings tab and look for advanced click that and open color tab or the overlay tab, color tab should get your brightness turned up, And if you can't see you can go into your bios and adjust your brightness from there and get it back to where you can see it if you can't write me back here so we can try another method. Ok I hope that helps you out somewhat, Oh yeah you can also hook up an external key board into your usb connections and you should be able to work everything from that too.
Jan 15, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron 6400 Notebook Logo
166 people viewed this question
Alun Cox
