Question about Sony PlayStation Portable (PSP) Console
My WLAN switch is on yet the green light is not flashing and it will not connect me to the internet....I have a wireless router, that is on and working perfectly also
After further investigation throughout many electronic helping sites/forums, I came to the conclusion that my ''Wi-Fi'' card (which is located under the motherboard of the PSP console) had expired but it can be replaced in a few ways..you can buy a Wi-Fi card and manually replace the older one, you can buy the card and get a professional to replace the card, or you can send the PSP with your problem in writing to Sony and they will replace the card and send the PSP back to you.
Posted on Jan 03, 2009
I got a Netgear WNCE2001 today. My router is a Verizon router. (The one with the WPS button on the front.) The security password is in WEP. When I try to connect it with WPS, the light on the WNCE2001 just...
which light is blinking ?
may be this help you ?
2. Select a radio button.
• Push and Connect (recommended). Either click the button or press the WPS
button on the rear panel of the Internet adapter.
• PIN Number. Select the radio button and a PIN displays.
The Internet adapter tries to join the wireless network for 2 minutes if you are using Push
'N' Connect, or 4 minutes if you are using a PIN.
3. Go to the router.
• If you are using Push 'N' Connect, press the router's WPS button.
• If you are using a PIN, log in to the router and type the PIN from your Internet adapter
in its WPS screen.
4. Go back to the computer that is connected to the Internet adapter, and make sure that you
are connected to the wireless network.
• When WPS is running, the WLAN LED blinks, alternating between green and amber.
• If the computer does not to connect with WPS, the WLAN LED is solid red for 5
seconds.
• If the computer does connect using WPS, the WLAN LED is solid green for 5 seconds
Then the WLAN LED returns to indicating a wireless signal.
Feb 12, 2014 | NetGear Computers & Internet
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
Flashing WLAN LIGHT ON EDIMAX ROUTER
No, it means it cannot set up a Internet Connection.
Try Powering Off and On again, if not contact your Internet Supplier.
Jan 27, 2013 | Edimax WiFi 150Mbps ADSL2 Modem Router
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
My wlan light keep going on and off on my wrt54g
Also check if the power light on your router is blinking. If it is blinking, that's an indication of hardware failure. To revive it, do a hard reset. Press and hold the power button of the router for 30 seconds then unplug the power. Wait for 30 seconds again before you plug it back in.
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
The green power light is on but the WLAN light is off but flashes every now and then. I can't connect to the internet. I have switched off and on again with no joy.
try doing a reset
there is usualy a small button on the back it looks like just a small hole use a pen to reset the router then go to mfg websight and down load there software it will walk you through the setup process to allow you to set up firewall and the wireless is included
Aug 03, 2009 | Computers & Internet
Wlan light orange
Orange WLAN light means no connectivity to the network. Try to reconnect to your wireless network and make sure to enter the correct wireless settings like the network key and SSID.
Apr 25, 2009 | Computers & Internet
Linksys wireless G broadband router
Hi
No problem if dmz is off ( only if you put one of your computer outside router firewall it will turn on though tghis is not recomended )
Wlan will be on only if you are connecting wirelessly .
Yes if power is not on spells trouble .
Go to your router support site update latest firmware it will end the problem .
Feb 16, 2009 | Linksys Wireless-G Broadband Router
Thompson speedtouch ST585 RED LIGHT ON WLAN
When the red WLAN light is flashing in conjuction with the internet light it just means a wireless computer is connected to the internet through the router
However I had a problem with the internet light flashing red and it required the router to be reconfigured
gudozdad
Oct 20, 2008 | Computers & Internet
Linksys wireless router
You can try the steps on this link. This will give you a step by step guide on how you can reconfigure the the router for timewarner (cable) connection. click here.
Jul 31, 2008 | Linksys Wireless-G Broadband Router
Sony PlayStation Portable (PSP) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
