Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Blue vertical line on plasma screen - Panasonic TH-42PD50U 42 in. Plasma EDTV
  • 91 Answers
Either the blue jet is up too high or the red green jets are set too low.
Posted on Dec 16, 2008
lukster
  • 217 Answers
SOURCE: black vertical line on p42w34p plasma
could be a loose ribbon cable on a buffer board, or one of the buffer could be going bad
Posted on Feb 17, 2007
  • 6 Answers
SOURCE: Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Posted on Mar 23, 2008
  • 3 Answers
SOURCE: vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Posted on Jan 13, 2009
  • 23 Answers
SOURCE: plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Posted on May 02, 2009
SOURCE: got a blue vertical line on me plasma
I have done extensive reading and "Googling" about the - Blue Vertical line from top to bottom. (Oh so many problems and answers.) We are getting the shaft with these products: extended warranty or not. I have a 46 inch Samsung LCD TV (LNT4671F). I bought it 11/2007. Problem: I have a 2.5 inch wide hazy blue vertical line on the left side of my screen. Answer: I have found the problem to be related with the following: when you change to a new TV channel there is (normally) a small rectangular window that is a "channel display window" of the channel you switched to and some information, then it shuts off, and then you have a perfect viewing screen w/o blue line. When this "channel display window" comes on; I have noticed there is a vertical blue line - exactly 2.5 inches wide - which is exactly the same as my vertical line problem. I took the back case off and looked at the component at the top middle of the TV inside. I put everything back together, and then, turned the TV back on. Where there was a vertical blue line from top to bottom...now it is gone. One thing which is different --> I did not have this function set up before; the "channel display window function is now ON" whereby, previously, I believe I shut it off. Important: since the display window is back on (which shuts off in 10 to 15 seconds) --> I don't have a vertical blue line anymore !!!!
:) Very happy right now. If I called a service rep: they would have sucked lots of cash out of me b/c as customers ... we know little about how to fix this S_it.
Posted on Aug 22, 2009
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
TV has blue vertical lines and no picture
I have a 42" Electrograph plasma and it has a 2" black vertical line on the left side of the screen.
Aug 02, 2010 | Electrograph Systems DTS4230 42 in. Plasma...
Hitachi 42HDS69 Blue Vertical Lines
I think that you have dry solder joints on either the vertical scan board, the focus board, the line output stage, or the chroma panel. Hope this helps.
Sep 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
Jun 14, 2007 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
318 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
