I have just installed an amplifier in my car but there are a couple of loud clicks (through speakers)when turned on.Also an alternator whine is detected whilst the engine is running.I have a good earth to the car and have turned down the gain on the amp but to no avail ! Please help.
PyroMan6x9x9
  • 150 Answers
SOURCE: Alternator whine
Try purchasing a "ground loop isolater", when your head unit and amp are grounded in 2 diffrent locations the diffrence in volatage to ground between the two will cause interference. Check the below link for more details, can be purchased of a shelf at you local radioshack http://www.radioshack.com/product/index.jsp?productId=2062214&cp=&kw=ground loop&parentPage=search Hope this helps L8R
Posted on Sep 17, 2007
x3n0x
  • 12 Answers
SOURCE: amp going into protect mode
If you set the gain too high on the AMP, at loud volume levels some clipping or distortion of the output signal will occur. Most amps have a Circuit inside that detects this clipping or distortion and applies protection to prevent damage to the speakers and the amp. It would help to know if you are driving the speakers with a Line level output or using the speaker output from your deck. There are many things that can cause an amp to go into protect mode, and knowing a little more about your setup will help to solve the problem.
Posted on Nov 09, 2007
  • 631 Answers
SOURCE: RCA Whine, Newly Installed Amp
The shield ground is probably open in the head unit. You can check the shield ground by measuring the resistance from the shield of the RCA connector to the chassis of the head unit. It should be near 0 ohms. Disconnect all RCA cables from the head unit before testing.
If you find that the shield ground is indeed open, the following link has more information for a temporary fix.
Temporary Shield Ground Repair
Posted on Nov 18, 2007
SOURCE: Car audio amp or speakers bad?
If you know how to use a multimeter, you can test the amp this way:
-unhook the subs
-hook up a cheapie speaker you know for sure works to one of the channels
-unhook the audio inputs
-turn the amp on
-set your meter to VDC
-put the positive probe on the inside of the input connector, being sure you make contact with th inner contact
-take the negative probe and tap it on the outside of the connector
What you are doing is sending a low voltage (replicating an audio signal) into the amp audio circuit and allowing the amp to amplify it. If the amp makes the speaker pop each time you strike the probe, the amp is working.
There is an inherent problem with band passes. The naturally filter out high frequencies like a crossover, including distortion, so it makes it hard to hear when the subs begin to protest.
Posted on Nov 22, 2007
  • 1894 Answers
SOURCE: Hi, Just installed a new
HELLO SIR
Posted on Mar 09, 2008
03 saturn vue radio noise
You are getting alternator whine, that means you need to move your ground wire and if you have a amplifier then make sure your RCAs are on he opposite side of your car
May 21, 2013 | Car Audio & Video
I hear my car through my speakers
Chances are that you have the ground for the stereo or the amplifier not grounded well enough, to bare metal. This can create a ground loop, which then creates a whine in the speakers when the alternator winds up and down. You can either get a better ground or go to Radio Shack and buy a ground loop isolator and install that inline into your stereo setup.
Aug 20, 2012 | 2002 Toyota Camry
Whining or hissing noise from rear area of 1998 chevrolet corvette
If the alternator has a bad bearing or bearings it would likely make a noise.
Oct 18, 2017 | 1998 Chevrolet Corvette
I have a lanser 4000 outputting loud engine noise
Double check your connections. Sounds like you are picking up alternator whine. Make sure the rca cable is at least 12" away from power and remote cables when installing fem radio towards amp. Its best to runthem on opposite sides.
.A thumbs up would be greatly appreciated if this answer is helpful to you. lanser-4000-outputting-loud-engine-noise-shonxoarcym4awy4zl1imx4o-2-0.jpg
Jul 17, 2010 | Lanzar MXA282 Car Audio Amplifier
I have a mustang 98 and i install 2 speakers panasonic 300w and now i hear feedback in from my car when i push acelator can you tell me how can fixed
Replacing 2 speakers will not cause engine whine. Did you install amplifiers and subwoofers or just replace 2 existing speakers? If it was an amplifier install then engine whine is a very difficult thing to diagnose and fix.
Mar 01, 2010 | XM Radio (XMP6000)
I cant stop the whine
Ok, if it only happens when the engine is running and the noise changes with the gas, that's alternator whine. Alternator whine is caused by the ambient noise in the voltage which is produced by the alternator. Alternators don't make DC current, they make AC current. The AC current is then converted to DC current and then sent to the rest of the car. The noise comes from an imperfect conversion from AC to DC. That noise travels down the power cable to the amp and causes noise in your speakers. This is often called "dirty power". Dirty power can be variations in voltage, inconsistent current, or noise within the voltage. One of the simplest ways to clean up noise in a car stereo system is to use capacitors. If you add a capacitor to your system just before the amplifier's power cable, it will help filter out the noise from the alternator. Start with 1/2 Farad or 1 Farad. That should be plenty to clean up the noise. The capacitors will also have a positive effect on your amplifier's thermal and sound performance, but you may not notice it.
May 14, 2009 | Performance Teknique ICBM-892 Car Audio...
500X emitting feedback squeaking
One source of hum is from bad rectifiers in the car alternator, if this problem stops when key is turned to accessory then have your alternator checked for bad rectifiers.Good luck and please don't forget to rate.
Apr 09, 2009 | Rockford Fosgate Punch 500X Car Audio...
High Pitch Whine from Amp (not speaker)
make sure your rca andpower/remote wires are ran on seperate side of your car.it maybe recieving some kind of interference from the alternator. try buying higher shielded wiring too
Apr 20, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Engine whine
You're hearing whine from the alternator as it charges the battery. You could reduce it by turning the input level down on the amp, or by adjusting the filter on the high end. You can also buy a whine filter kit.
One last thing... you may have blown one of the diodes in the Alternator itself when you shorted the speaker wire. It would still work and charge the battery, but would not be able to filter the whine like it should.
Hope that helps...
Geno
Mar 25, 2008 | Eclipse XA5000 Car Audio Amplifier
Amp problem on a bmw 3 serie
you have a ground loop problem that whining is called radiated engine noise.
Sep 30, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
24 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
