Question about HP 2500 CM InkJet Printer
Ink heads have dried
Black ink cart is empty
  • HP Master
  • 2,794 Answers
Remove the ink jet cartridges and clean them with a moist paper towel.
The black one will have to be replaced. If there dried I wouldn't refill them because chances are the nozzles are clogged and they won't work on a refill.
Posted on Dec 16, 2008
Risograph. Why does it indicate empty ink bottle when it is a quarter full?
Most inkjet printers don't actually measure the amount of ink in the cart. They estimate the amount of ink based on what you've printed and how many cleaning cycles you're run. They have to estimate "empty" well before it's empty, in case you've used more ink than they expected, so the head doesn't go dry. Also, showing empty makes you buy more ink, and that's where they make their money.
Mar 09, 2016 | Office Equipment & Supplies
Black not printing on my canon pima 5220, did cleaning and deep cleaning already
Dear
The black ink cart. may dry or empty. try to replace with fresh cart.
Repeated cleaning consumes more ink.
thanks.
Feb 21, 2015 | Canon Office Equipment & Supplies
I've replaced all ink cartridges but the printer is only printing color and no black please help
the black is plugged in the printhead. take it out, and to the sink. run hot water thru the head. rinse it thoroughly. even put the nozzles up to the sink nozzle and force water thru it. when it decided to unplug you will get a bunch of black ink for a second or two. then take the head and shake it out and if possible blow it out with compressed air. get it dry then take a pencil eraser to the contact points on the back of the printhead to clean them. reinstall your printer and let it cycle to charge the printhead. try to print. if not good results try one more clean and if still no black, go back to the sindk and try again. repeat this a couple of times, if it doesn't work, let it sit in really hot water for a while then try to flush it out again. make sure it is dry when you put it back into the printer. try to print again. do use good inks to do this. empty ones won't work.
Aug 13, 2014 | Canon PIXMA MP780 All-In-One InkJet...
Would not print black, I think the head is dried, so normal clean is not working
try replacing the black ink cart-rig. it might be empty. if it senses the level of the ink and it says it is not empty i might be broken and actually be empty.
Apr 09, 2011 | Kodak ESP 5 Printer
Lines show up throughout print jobs
Your print heads most likely need to be cleaned.
When you don't use your ink carts for a while, when you get new ink carts that have been stored in warehouses for a number of months, or when you have refilled a slightly too dry ink cart, the print head nozzles on the bottom of the ink carts get clogged with dried ink. The printer head cleaner menu will not disolve the dried ink. Water will. Try this. Soak the bottom of the clogged ink cart in 1/2 inch of hot water for 15-30 minutes. Blot dry with clean paper towel(you should see the ink color on the towel). Retry.
Mar 07, 2011 | Dell 942 All-In-One InkJet Printer
Ink is not visible on paper
First NEVER raise the tanks of a CISS above the height of the printer otherwise all that is going to happen is that the ink will syphon out and end up getting everywhere.
As you have not used the printer in a long time there wil be dried ink in the print heads 3x head cleaning is nowhere near good enough to clear the blockages.
One thing I would do as you have a set of OEM carts is the following presuming you have the equipment.
Drill a small hole in the top of each cart and extract as much ink as ps=ossible with a syringe (you can put it in the ciss ink tanks) and replace with head cleaning solution. Reseal the ink carts (if clean selotape will do) insert carts and do 5x head clean, leave 24hrs and do 5x head clean again. This will allow the head cleaning solution to get right insine of the print head, soften the dried ink and then flush it through..
A lot of messing about I know but you've just shelled out a few bob for a CISS so it's worth it.
NB
Make sure you keep the CISS carts above the tanks whilst outside of the printer.
Aug 24, 2009 | Epson Stylus C88 InkJet Photo Printer
I can't get my black ink to print.
Could be the ink dried up. Unusual but happens sometimes. If you shake it does it sound like liquid in it?
If you recently replaced the cartridge, did you remember to take the tape off? (I know, sounds silly, but sometimes it happens.)
In the software, does it register that there's a blank ink cartridge installed?
Just a couple of ideas to get you going. Respond back and I'll work more with you.
Apr 07, 2009 | Epson Stylus Multifunction Inkjet Printer/...
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Supply expired
So many models. Does this model have printheads under the ink carts? If so, remove the print head and clean the jets with a damp Bounty paper towel. Fold the towel up a few times and blot the head into it a few times to clean out the dries ink.
Aug 09, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Printing Problem
Cleaning cycles use ink. So it's no wonder it got worse, the ink level went down. Are you 100% sure that the black cart is full? they can give a wrong reading on occasion. what makes you think its full? Could be also that you need to replace the head- the part the cart fits into. generally they don't last more than 18 months.] Another possibility is that the black is indeed full, but dry. Put a wet sponge to the nozzle, see if it soaks up a decent amount of ink. Good luck
Jun 06, 2006 | Canon PIXMA iP4000 InkJet Photo Printer
HP 2500 CM InkJet Printer Logo
60 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
