Question about Zenith C27A24T 27" TV
Only showing 3 channels.
Channel 61, 39, and 20 only works. I need to get to channel 3 to set my cable working again.
  • unmechanical Dec 19, 2008
    Same problem, but need to get to channel 3 for direct tv. Stuck on channel 2 and no remote.
  • 20 Answers
You need the remote. it is the only way, unless you have a menu button on the front of tv...sorry, wish i could help more
Posted on Jan 02, 2009
How do i set up my tv with my sony vcr
Hi Katie.. If you are using a coaxial cable to connect your TV and VCR, the TV needs to be tuned to channel 3 or 4. If you are using the Yellow, red and white cables, your TV should be on video mode to work.
Sep 14, 2015 | Toshiba 24AF42 24" TV
I have a Symphonic model ST420FF along with a Phillips Universal remote. The tv used to work oerfectly but then the channel changed (we have a charter cable box hooked up). Now when I try to change the...
Can you use the menu buttons on the TV to navigate to the control panel to automatically or manually add channels? That would be a start to make channel 3 exist again.
Sep 20, 2014 | Televison & Video
I work for a Super 8 Motel chain with Zenith televisions, Model H25C39Y. My problem is recently we switched cable providers, their signal is on Channel 3, a lot of our Zenith televisions are set when you...
You have to be sure your TV, is in the auto tuning mode. If you have a cable box, this box must be on as well. Get into the menu of the TV and find set up. You will see auto channel search. The TV will note the channel needed to watch TV. Thanks for asking and show all hands of support!
Jul 29, 2011 | Televison & Video
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
I can't get channel 3 to show satellite channels. They only show up on Video 3. I need channel 3 to work for surround sound. I checked wiring diagram and it looks like everything is hooked up the way it...
Hi there Guest, what you will want to check is what type of cable is hooked up to the TV. To broadcast on channel 3 it needs to be connected from the receiver by a Coax cable instead of RCA/HDMI/Component cables.
Tommy Faust
DISH Network
May 15, 2010 | DISH Network IR Remote Control
Only shows channels 3-23 and then only shows a few hd channels
Are you using a Cable Card? Have you tried the Channel search function in the user menu. Select Channel set up and do a channel search.
Apr 12, 2010 | Samsung HP-P4271 42 in. HD-Ready Plasma...
No Signal
Reboot ur DirectTv box.By unplug,replug it and hour later to let the box upgrade it solfware.Go to ur tv menu setup rescan it again for all the channels.It should work now.
Mar 14, 2010 | Vizio VO47L 47 in. LCD TV
Tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
Mar 29, 2009 | Philips Magnavox MS3652S 36" TV
Hitachi 27
If the sat feed is on channel 3, and the TV is tuned in and still does not get the feed, check the feed wire to be okay. If all is okay, there is a possiblity that the tuner module in the set has failed.
Jerry G.
Apr 29, 2008 | Hitachi 27CX01B 27" TV
Zenith C27A24T 27" TV Logo
41 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
