Question about MSI Wireless-G RG54G3 Router
Puting in a password for my Wireless router
How do i put in a password to stop anyone using my ISP provider for free.
R T Rayner Known as TERRY. Thanks
  • robtel41 Dec 17, 2008
    Every time i try this number, all i get is Connection interrupted, The document contains no data, The network link was interrupted while negotiating a connection, please try again. I have tried again eight times with no luck. TERRY
  • 827 Answers
Type 192.168.0.1
the default will be 'Admin' for username and 'password' for password.
don't mess about with anything else, apart from 'Set Password', if you are not sure exactly what you are changing.
write it down somewhere safe!
hope this helps
chris
Posted on Dec 17, 2008
  • chris grams
    chris grams Dec 17, 2008
    have you tried 192.168.1.1 and 192.168.2.1?
    the third number will be 1,2, or 3.
    if it isn't then the router is set to some custom setting, in which case, you can press and hold the reset button (probably the little hole at the back, with something sharp like a paper clip) which will restore it back to factory settings. then try one of those gateway numbers above again.
    good luck terry
    chris (ziraffa)
Can't get my router to connect to ISP with username and password
It is not done at the router but at each device. The router supplies connections via a local sub-masked address. It is typically assigned an IP address via the ISP's DHCP server. Typically usernames are used for e-mail and Usenet. Your connection is validated by the MAC address on the router. Your ISP can not look beyond your router. You can have 1 device or dozens. It matters not.
Jan 01, 2014 | D-Link Dlink Airplus Xtreme Dwl-2100ap...
If I reset my dynex G router using the reset button; 1) What will be my default password? 2) Will resetting the router affect the hard wired connection?
the default ip is 192.168.1.1  username admin password admin or leave the password blank.
hardwired you mean is utp cat 5e cable? known as internet cable, which using switch hub.
well, it will affect if the wire/cable you mean is came from the router you reset.
the wire and the access point  came from the modem is still active.
 do not reset your hardware if it is also your modem. Because when you reset it, all configuration of  your modem will be lost, including your user name and password provided by your ISP.
Feb 04, 2011 | Dynex Wireless-G Broadband Router
My wireless router can connect my computer,but can not open internet website.why?
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Jan 17, 2011 | Netopia Cayman 3347W-Ent Wireless Router
Compatibility problem with Microsoft Wireless router MN 500 after working fine for many years
also
hope this helps
Jan 14, 2011 | Microsoft Broadband Networking MN-500...
Not sure that this is a netGear problem, however, I have Windows XP, (Very old version, prob never updated - not mine - Father in laws) Ethernet port broken so bought NetGear N300 wireless adapter. Have...
also
hope this helps
Jan 12, 2011 | NetGear Computers & Internet
Forgot password
The system's default password is located on the back of the unit. A series of numbers and or letters in brackets. If you have changed the default password, you will have to reset the router back to factory by pressing the reset button on the back for up to 1 minute. Once this is done, you will lose your Internet Access until the unit can be configured through the wizard provided by your ISP. You will need to call your ISP and provide your credentials in order to have them assist you (free). The basic routine is to configure your ISP provided email address and password to connect via PPOE. Once that is done, you should be back online and able to configure any other settings you may need for firewall settings, manual IP addresses etc. If you need more information, feel free to contact me. I use this same exact unit with my IT business. I have to reset it occasionally as these are not very stable, especially on the wireless side. I am also on my 3rd one for bad power supplies in the last year.
Sep 08, 2010 | 2wire (2701HG-B) Wireless Router
Isp password and name?
Your ISP should give you your username and password, not the router manufacturer. To know how to punch it in your router, please refer to your router user manual.
Mar 27, 2009 | Computers & Internet
Problem with wireless network!!
You don't need the CD no. What you need to do, is reset the router if the old wireless authentication key is still activated. To do this, locate the little hole at the back of the router, and use a pen to press it in for approx 30 seconds. This will reset the router to it's default values, and allow you to configure the authentication and such yourself.
May 25, 2008 | D-Link DI-624M Router (DI624MRE)
WiFi
if you want to use your wireless in the home you will need to arrange an internet service provider (ISP) ADSL service,then wait until you have been advised that the line has been activated by them,you will pay a monthly charge for this service.
you will also need a wireless modem/router to receive the data from the phone line, then send it on to your computer wirelessly,
the modem/router will need to be set-up with your user name and password ,in the first instance usually provided by the ISP.
hope this helps you
please rate my efforts as that is our reward
Terry
Apr 04, 2008 | Computers & Internet
Username and password
You will probably need to reset your router to get access to it again with a known username and password. BEWARE THIS WILL PROBABLY RESET ALL CONFIGURATION INFORMATION AND YOU WILL BE REQUIRED TO COMPLETELY RECONFIGURE YOUR ROUTER INCLUDING POSSIBLY ISP SPECIFIC INFORMATION. If you cannot do this including knowledge of all the required answers and proceed anyway you may lose access to your internet connection until this is successfully done. Proceed beyond this point AT YOUR OWN RISK.
Follow the link below to determine the model of your router
Router Link
As your profile indicates you are from Australia -- there is a link at the top of the page for a DI-624+ that may also apply to you.
If this does not work or your model is not a DI-624 as indicated try the following Assuming you have a DLINK router
Go to www.dlink.com
Choose your country
Choose Support
attempt to access product information -- if your model does not appear there may be legacy products link on the page to choose
Download your user guide.
The following link may provide an emulator for your router to allow you to preview the configuration process (this does not configure your router. You may have noticed this emulators link earlier when accessing product information above, if you could not use the link.
Emulators Link
AGAIN PROCEEDING BEYOND HERE CAN RESULT IN THE LOSS OF ACCESS TO YOUR INTERNET SERVICE -- proceed with care.
Doing this will may require you to configure specific ISP required entries into your router to restore internet access, I do not know what those requirements are now. I may be able to research them if you provide information about your internet service provider such as their web site or help/support web site. Be aware that you will require all answers for this before doing it as you may not have internet access again after starting this until you successfully complete this. With all the previous warnings in mind you can consider the following step.
Using the instructions in the user guide you can probably reset your router and get access to the configuration.
Dec 14, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
MSI Wireless-G RG54G3 Router Logo
232 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Computer Links
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
