Question about RCA Lyra RD1072 MP3 Player
My mp3 does not connect to my computer
I use a usb cable, but when I connect it it doesn't turn on and when I connect it while on it freezes or keps saying: RCA Please Wait... for like three times and freezes. Please help!
  • 944 Answers
Try this link - they have udated drivers for your player, which hopefully will solve the problem; http://www.rcaaudiovideo.com/en-US/Downloads.html?ProductID=RD1070 Try a different cable also, and check by plugging it into a usb port on another computer that the problem is not with your usb ports. Hope this helps :)
Posted on Mar 22, 2007
SOURCE:
I lost my charger to my mp3, where can I get a new one that doesn't cost much?
You can charge the MP3 player by connecting the USB cable to the MP3 player and then plug it into the USB port of your computer.
Jul 14, 2012 | Coby MP620 MP3 Player
Tip
Connecting an Eclipse MP3 Player to a Computer
Many people have found that their computers do not recognize the Eclipse mp3 Player, even after connecting with a USB cable. I had the same problem but discovered that the problem lies with the cables themselves. I have several USB 2.0 5-position cables that fit the Eclipse USB port perfectly, but only ONE of them actually works - the cable that came with the player itself. If you've lost this cable, you may be in trouble.
Attached is a screen-grab of the type of USB plug and port involved. You don't see them around very much anymore, and I have no further advice if your player doesn't have a USB port of this shape.
on Feb 01, 2015 | Eclipse Audio Players & Recorders
My sansa clip is frozen on the blue flower
One issue that people experience with the Sansa Fuze player is that the screen turns white when they are trying to use it. If you experience this common Sansa Fuze MP3 player repair issue, you need to reset your player. Hold down the "Play" and "Power" buttons for about 20 seconds. The player should automatically reset.
MP3 Player Freezes
Another issue is that the player freezes. You may see lights on the player, but it won't do anything. Follow the below steps to correct this issue:
1. Use the above steps to perform a hard reset.
2. Turn the player back on, and slide the "Power" button upward.
3. Use the USB cord that came with your player, and connect it to your computer. Only connect your player directly to the computer. Don't connect it to a USB hub.
4. See if your computer recognizes that a device was connected to it. Or, look in "Devices and Printers" folder, and see if the device shows up in it.
If your device doesn't reset, and the computer doesn't recognize it, contact SanDisk for additional assistance. Or, you can attempt to repair the device yourself.
Repairing Internal Components
If your Sansa Fuze player is out of warranty, you can attempt to repair internal components. This is an "enter at your own risk" solution, but you may be able to fix the issue. If it doesn't work, or if you damage another component, you will most likely need to get a new player.
1. Shut off the device.
2. If you don't have one, purchase a case opener tool. This is a tool with an extremely small head that is used specifically for opening up small devices.
3. Place the head of the tool in the seam of the device, and rise up the faceplate. Do not do this forcibly, or you'll break the ribbon cable connected to it.
4. Remove the ribbon cable from the faceplate.
5. Examine the battery cable. If this connection is loose, your Fuze player won't turn on. Plug the connection firmly into the port.
6. Check the LCD screen connection. A loose connection here means that you can't see anything on your screen. Disconnect the cable from the port, and reconnect it.
7. Reattach the cable to the faceplate, and reattach the faceplate. Turn the device back on.
These Sansa Fuze MP3 player repair suggestions may not fix all issues. If your player is still not working properly, either take it back to the place where you bought it, or contact SanDisk for additional help.
References
Fixya.com, http://www.fixya.com/support/t4267400-sandisk_fuze_4gb_locked_lights_will_not
SanDisk, http://www.sandisk.com/products/sansa-music-and-video-players/sandisk-sansa-fuze
Jul 18, 2011 | SanDisk Sansa Clip MP3 Player
My ASK 16 GB mp4 player with camera won't play the video I transfer into it cause I accidentally deleted the software files in it after connecting to the computer. Also, I can't restore the software...
I format my mp4 through my computer & when the mp4 suddenly freeze, I just have to connect it to another USB cable to my computer & it'll start working again. Basically, you need 2 'USB cable' to interchange if your ASK mp4 start freezing.
Nov 23, 2009 | Audio Players & Recorders
Ipodnano8GB connection
you have to restart your iPod. press the middle/center button and the menu button for a few minutes
Jan 01, 2009 | Apple iPod nano
Please Help
Hello Pookie34,
In general, most MP3 players are charged by connecting them to the USB port on your computer using the supplied programming cable. Make sure you are connecting the cable to a USB port on the computer itself and not a USB hub as most USB hubs do not have enough output power to charge your device.
Your MP3 player can also probably be charged by connecting it to an appropriate AC wall charger or automobile power cable. However, for most manufacturers these are optional accessories not normally included with the player.
Best Regards.
Ken
"Go Ahead. Use Us."
Jul 22, 2008 | Memorex MMP8565 MP3 Player
Freezing up when i hook up the usb cable to my real player
You can try this, but I was completely unable to get a similar model, the SA4111 to work on my computer using any method at all - this was not their best product:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 26, 2008 | Philips SA4010 MP3 Player
Zen keps freezing
http://193.95.171.84/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=551,E=0000000000295096978,K=561,Sxi=19,Kb=ww_english_add,VARSET=ws:http://us.creative.com/,Case=obj(20243),Kb=ww_english_add
Nov 27, 2007 | Creative Labs Zen V MP3 Player
Hey
It is easier to reformat the mp3 player. When the mp3 is plugged in to the PC, go to my computer, the double click the mp3 player there. You will see internal storage, right click that and click format. You will lose all the stuff on the mp3 player.
Oct 26, 2007 | RCA Lyra RD2765 MP3 Player
RCA Lyra RD1072 MP3 Player Logo
150 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
