Question about IBM ThinkPad 600X Notebook
Not starting up properly
Turning on my laptop IMB thinkpad 600x i get on the screen that one of my disc has a bad file.How can i remove that bad file?
How to reboot an IMB think pad
No! you need the boot disc in order to load the critical files for your laptop, go to www.ebay.com Type: boot disc
May 27, 2012 | IBM ThinkPad X31 2672 Notebook
I got erro 08611, how can i fix?
1. switch on your laptop
2. the screen will display "error 08611
3. click "ok"
4. the screen will show the components in your laptop.
5. click "exit"
6. then, click "configu"
7. press ctrl + the letter D =
8. screen will display the commands to run your laptop.
9. you go to first column and third row change the nomber "02" to "01"
10. press f3
11. reboot your laptop
Source:
http://mailman.linux-thinkpad.org/pipermail/linux-thinkpad/2004-February/015935.html
Hope this helps.
Mar 19, 2011 | IBM ThinkPad 600X Notebook
I reformatt my thinkpad 600x to WIN xp SP3, then ive lost my audio, I had no audio drivers to install. Ive tried the different audio drivers offered by lenovo for thinkpad 600x,but then i failed to get the...
Normal 0
The same model ThinkPad can have different types of network, video and audio drivers and unless you know exactly which one is installed in your ThinkPad, you need to download all the drivers and install each driver until you find the right driver.
When you download the drivers, write down the device driver and it's file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive.
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer, Use this link: -
http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
You can download the various drivers and then you click on and run the various driver files, they will then unzip and expand into a sub folder on C:\drivers Then install the various drivers from this folder (run the set-up file).
Sep 29, 2010 | IBM ThinkPad 600X Notebook
I have a IBM thinkpad 600x laptop without a charger.It looks very old and cannot start.What can i do?
A universal charger is easy to find, but I do know that model uses a 16v AC adapter which can be found at any store that sells electronics (Best Buy, etc)
May 03, 2010 | IBM ThinkPad 600X Notebook
Ibm 600x won't run windows
my ibm 600x thinkpad wont load anythig, it comes up as Error 00178 and 00301 and 00188
Jan 10, 2010 | IBM ThinkPad 600X Notebook
I have a IBM 600x recently installed windows xp sucessfully and today it wont boot up at all it wont acept a charge using the ac adapter apears to have power/the adapter light lights up when not plugged...
Try taking the battery out and just use the AC adaptor.
Does the PC "come on" when you press the power button?
Does it show the animation bar at the bottom of the screen when XP first starts?
Apr 25, 2009 | IBM ThinkPadĀ® 600X (2645-9ZU) PC Notebook
Ibm thinkpad 600x brightness control
There is no otherway. becase the slides sends direct signal to inverter for adjusting brightness. You can adjust brightness the
other way ,through graphic cards property, but that is only adjustment for the color and if you do make it bright, you'll be loosing the vivid color..not so natural.
takecare.
Apr 19, 2008 | IBM ThinkPad 600X Notebook
Think pad 600x screen
If 3 beep....if I'm not wrong its a VGA chips problem.You need to send the board to check.But first what I recommend is try to remove external hardware one-by-one.Like memory,DVD,..
after remove one-by-one try to tuun on and see.If it doesn't work then its a VGA chips problem.
Goodluck,takecare.
Apr 04, 2008 | IBM ThinkPad 600X Notebook
Troubleshooting errors
Try starting the computer in Safe Mode.
Then run the anti-virus.
Feb 10, 2008 | IBM ThinkPad 600X Notebook
ERROR MESSAGE READS...
Try starting it in safe mode. (Hold F8 after power on). If you get your icon screen go to start, run and type in msconfig. Click startup and disable all the items. Hit OK and try a normal restart. This error can be caused by a bad program starting up.
Aug 30, 2007 | IBM ThinkPad 600X Notebook
IBM ThinkPad 600X Notebook Logo
82 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
