Question about Kenwood KDC-MP528 CD Player
Face wont open
Face on the KDC-MP528 Kenwood wont open, everything plays, but cant eject disc,
  • 34 Answers
If you have already tried hitting the reset button you should first remove the faceplate and check the contacts on the main unit and the back of the faceplate. if they are dirty clean them (with power off) with contact cleaner or a small eraser. if your lucky that will fix the problem but most likely you have a bad ribbon cable. this cable attaches the faceplate contacts to the main unit and flexes as the face tilts. after time these cables get small cracks that may not be visible. you can usualy buy the part from a place like pacparts.com and replace it to solve your problem.
Posted on Jan 08, 2009
How do i install my alpine cd changer to a kenwood mp528 unit
It is unclear which Alpine CD changer you have and what output connections are available from it.
However your Kenwood unit has Aux input terminals at the back. With appropriate cable connectors you should be able to hook the two up. In the Kenwood you will have to select AUX in menu when playing CD changer. Download user manual for Kenwood from this site.
http://www.kenwoodusa.com/Support/Car_Entertainment/
Search using full model number KDC-MP528
Sep 04, 2014 | Kenwood Car Audio & Video
I have no display on my kenwood radio, but it will play the radio fm stations. the cd door will not open either.
Use a small pick tool (like dentists use) to reshape those brass connectors on the back of the face plate. If this model has a ribbon instead of brass connectors it's junk. Make sure where the connectors meet the head unit is clean.
Sep 29, 2010 | Kenwood KDC-MP528 CD Player
Face plate on KDC-MP528 kenwood deck wont open
if you have checked all of your wiring and fuses and already tried hitting the reset button you should first remove the faceplate and check the contacts on the main unit and the back of the faceplate. if they are dirty clean them (with power off) with contact cleaner or a small eraser. if your lucky that will fix the problem but most likely you have a bad ribbon cable. this cable attaches the faceplate contacts to the main unit and flexes as the face tilts. after time these cables get small cracks that may not be visible. you can usualy buy the part from a place like pacparts.com and replace it to solve your problem.
Dec 16, 2008 | Kenwood KDC-MP528 CD Player
Reseting cd player
is it connected to your ignition if so then unplug the cd first and them your battery in this sequence negative first then positive and wait ten secs.then reconnect with positive and then negative and then replug the cd.
Jul 12, 2008 | Kenwood KDC-MP528 CD Player
Kenwood KDC-119 car stereo problem
There is a small hole at the bottom of the stereo face that will reset the system. I pushed a pen tip into the hole and it turned the stereo off. When I removed the pen, the system turned on and the CD ejected. Problem solved.
Jul 02, 2008 | Kenwood KDC-135 CD Player
Kenwood w6527
ebay is your best bet. simply save a recurring search if you don't find it right away and you will get an email when one is available.
May 16, 2008 | Kenwood KDC-MP528 CD Player
Kenwood kdc-mp528
it sounds like the laser is bad, here is the part number
X93-2010-00
You can probable buy it from an authorized kenwood service center
Jan 20, 2008 | Kenwood KDC-MP528 CD Player
Kenwood kdc-mp528 amp/speaker problem???
This is a common mistake. This problem indicates that you are using the solid blue wire from the head unit to the remote turn-on on the amp. This is a power antenna wire that only receives power when on FM radio. You need to replace this with the Blue & White wire from the head unit (power control wire) to your remote turn-on on your amp. This should solve your issue.
May 12, 2007 | Kenwood KDC-MP528 CD Player
Kenwood KDC-MP528
It is all described in the manual, page 27 Here is the instruction manual: http://inform2.kenwoodusa.com/manuals/KDCX589.pdf If you have problems downloading, send me an email where i can send the file.
May 24, 2007 | Kenwood KDC-MP528 CD Player
Kenwood KDC-MP528 CD Player Logo
103 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
