Question about RCA RS2652 Shelf System
RCA 5-CD Shelf System, RS2654 Fuses
Ive had my RCA 5-CD Shelf System, RS2654 for a little over a year it worked perfect till bout 3 weeks ago the fuses blew so i went and asked the company what to do they said go to radio shack and buy replacements but when i installed them they blew instantly and now i cant reach the company so i figured id go up some wattage so i bout some that could hold more watts but even they blew could you tell me whats wrong and or how to fix it or at least what i should do??
  • 1 more comment
  • andy vice Mar 22, 2007
    how do i test for a short???
  • btc9090 Nov 06, 2007
    I have RCA2654 .It is not Powering up.I opend its's main power supply and found resistance R886 blown up and fuse 505 opened.Can somebody help to trace the problem and value of resistor.Better if someone has circuit diagram.You may forward circuit diagragm at my mail btc9090@yahoo.com
    Thanks
  • BobDS Dec 27, 2007
    My husband received the RS 2654 unit for a gift last year. We weren't able didn't get it set up until last month because of space. Today it died. No power! No nothing. Any help would be appreciated!
I traced the portion of the circuit involving the fuse and failed resistor. Fixed the problem by replacing R886 with a 1.2K, 1/2 W resistor, a zener diode that had heated the circuit board and tested bad with a 15 volt, 1 watt zener and replaced the blown axial lead 1.5 amp fuse. I also noted a jumper missing that would connect the common of the circuit with the failure to the main ground of the rest of the board. I installed the "missing" jumper thinking that this was probably the root cause of the problem.
With these repairs the RS2654 has worked fine for many hours.
Don L
Posted on Mar 18, 2009
  • jrobin4450 Oct 16, 2012
    can you tell me the lcoation of the zener diode?
    President:
  • 3,130 Answers
Never ever replace a fuse with a bigger one, you are lucky the unit did not blow up and statrt a fire. When a fuse blows there is usually a reason.There is a short in the main power supply or the output stage. You will need to test for shorts on the main transformer, B+ rectifiers and the main filter capacitors. If that does not show any shorts, you will need to test the audio output circuits for shorts on the audio output IC's. Good Luck
Posted on Mar 22, 2007
  • Larry  Dillon
    Larry Dillon Mar 22, 2007
    You will need to use a multimeter, if you do not have one or if you do not know how to use one, you should play it safe and get this unit looked at by a pro, there are no user replaceable parts inside these units.
How to hook up my speaker wires
Just follow the color code of where the wire suppose to go, it's like a puzzle, but it's that your following the Bi-Amp wiring on the back of the unit of your amplifier output
Mar 30, 2013 | RCA RS2652 Shelf System
Our Bose Wave music system has stopped working - it is 5 years old - suspect a power supply problem - other than the three screws - how does one remove the cover without breaking it?
Our bose wave system stopped working also. The remote wouldn't work, it wouldn't turn off nothing. So finally we re-set it by clicking the button on the power strip it was plugged into.
It then worked! we had a power glitch a few weeks ago and think that had something to do with it. I hope this helped, and helps others!
Annie
Jun 24, 2010 | Bose Wave Music System CD Shelf System
Tuner does not work
If you're trying to listen to FM, and are indoors, and your walls are fairly thick, or brick and mortar, chances are you're not getting a strong enough signal.
Modern minisystems like yours come without an external antenna, and use their power cords in lieu of one. Try extending the cord, not coiling it, for better reception.
Other than that, your system may have had a spontaneous problem to its FM tuning module, though not likely.
Aug 29, 2009 | RCA RS2664 Shelf System
RCA RS2654
There were 2 problems that I found with my daughter's rs2654, which wouldn't open. The first is that a 2.2 ohm resistor opened up near the IC that drives the motor that opens the drawer, so no voltage to the moter. The second was that the grease in the gears was so stiff that the motor barely turned the larger pulley. Changing the resistor and cleaning up and regreasing the gears fixed it.
Jan 02, 2009 | RCA RS2652 Shelf System
RCA 2130i manual needed
Hi, go to http://www.retrevo.com/support/RCA-RS2130i-manual/id/19240ci969/t/2/ register (it's free) and themn you can download your manual in pdf format
Dec 09, 2008 | RCA RS2130i Shelf System
5 CD Changer won't work
my rca 5 cd changer skips on all cd's?
Jun 26, 2008 | RCA 100-Watt Stereo System With 5-CD...
SET CODE FOR RCA MODEL RS2654
I need to program my stereo Durabrand (HM3817DT) to operate with universal remote Philips (SRU4105WM/17) can you please get me the search code for it.
Thank you
Nov 26, 2007 | GPX HM3817DT Shelf System
Fuses blow
In addition to what i said in the live chat about the transformer, here is a link to the manual for the RS2653 which seems very similar; http://www.rcaaudiovideo.com/rcaav06/AudioVideo/ProductDownloads/RS2653_IB.pdf or this link to contact RCA directly; http://www.rcaaudiovideo.com/en-US/ContactUs.html Hope this helps, not much in the manual of any use for this problem :)
Mar 22, 2007 | RCA RS2652 Shelf System
RCA RS2652 Shelf System Logo
927 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
