Question about Toshiba 32AF41 32" TV
Toshiba 27A51 TV won't power up, relay clicks twice
When power button is pushed, there is the normal relay click as it tries to power up. Almost immediately, there's a 2nd click and it powers down.
I've been trying to find a service manual, or at least a schematic.
  • 3 Answers
Must be some of parts broken down. you have to check powersupply thorougly.
Posted on Feb 04, 2009
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional...
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Aug 06, 2010 | Toshiba 51H84 51" Rear Projection...
No picture just clicking noise
bulbs burnt right out. old old old tv. needs to be replaced. it would be cheaper to grab another tv then to try and repair this.
Feb 16, 2010 | Toshiba 27A51 27" TV
Toshiba Color TV Relay clicks slowly. TV does not come ON.
Electrolitic Capasitors in the power supply going or being bad will cause this. At some point a low value resister also will start to run hot or burn up. I believe it it a 16v 1500 uf cap near the relay. I would also replace any 10uf 160v caps in the powersupply too.
Hope this Helps,
Skyassoc
Jun 17, 2009 | Televison & Video
My tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Apr 07, 2009 | JVC LT-42X579 42 in. LCD TV
Toshiba cf32c50 tv will not turn on
This is a typical condition if the power supply has failed or a power-consuming circuit the supply services has exceeded a predetermined current draw. The relay you hear is preventing further damage or even fire.
You will need local tech help with this.
Sep 29, 2008 | Toshiba CF32F50 TV
Will not power up
your problem is in flyback or high voltage section failure.
  • check horizontal output transistor
  • check fly back transformer.
  • check for supply to horizontal section as high voltage from power supply may create such problem
  • as this failure is due high voltage section so it is better to take skilled technician help.
  • good luck.
Oct 15, 2007 | Toshiba 27A51 27" TV
Toshiba 27A51 problems
reduce raster no picture no sound and the power stays on.
Oct 27, 2006 | Toshiba 27A51 27" TV
Toshiba 27A51
check brightness and contrast setting haven't been reduced to zero.
Aug 28, 2006 | Toshiba 27A51 27" TV
Toshiba 32AF41 32" TV Logo
196 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
