Question about RCA RS2652 Shelf System
Fuses blow Ive had my RCA 5-CD Shelf System, RS2652 for less then a year it worked perfect till a few weeks ago the fuses blew i contacted the company and they told me to go to radio shack and buy replacemens so i did but they blew the second i put them in the wear the same as the ones i took out to so i went and got another set 50 watts more but they blew can anyone tell me whats on or how to fix it please???
  • dodirty Jan 26, 2008
    i got a 6 cd unit and my fuses blow almost instantly alsobig problem
  • 944 Answers
In addition to what i said in the live chat about the transformer, here is a link to the manual for the RS2653 which seems very similar; http://www.rcaaudiovideo.com/rcaav06/AudioVideo/ProductDownloads/RS2653_IB.pdf or this link to contact RCA directly; http://www.rcaaudiovideo.com/en-US/ContactUs.html Hope this helps, not much in the manual of any use for this problem :)
Posted on Mar 22, 2007
Rca rs2652
Your CD drive may have failed
Sep 29, 2013 | RCA RS2652 Shelf System
How do I replace the fuse in the stereo for the speakers
pull the cover off and on the circuit board on the bottom of the unit you will see a row of fuses
Nov 12, 2012 | RCA RS2652 Shelf System
I have a rca rs2640 stereo system. The display, cd player, tape player, radio, and headphone jack all work. But when a cd, tape, or radio is playing, the speakers do not make any sounds. I know it is...
It sounds like maybe you have speaker wires touching somewhere. If they are touching it will blow fuses, especially if you turn the volume up to try to hear anything. DO NOT put bigger fuses in to replace the old ones, you will actually do more damage to your system because a higher volt fuse will allow a higher voltage to "spike" in your stereo and might just start frying internal parts.
Aug 10, 2009 | RCA RS2640 CD Shelf System
RCA RS2656 Shelf System
Had a problem with a customer's stereo system, i replaced the transformer and put in two new fuses and all worked good again. Another time it was a damaged capacitor allowing full charge to go through causing the fuse to blow immediately so i just replaced the capacitor and the fuse and all was good.
Dec 31, 2007 | RCA RS2656 Shelf System
Will not open....
select another option such as "tuner", then go bak to CD
Dec 13, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
Can you tell me how to change the clock on my RS2652?
press and hold the "CLOCK" button until the time flashes, the using the << & >> buttons, adjust the hour, press "CLOCK" once more to select minutes. again, using << & >> to select time. press "PROG. SET" once. good luck
Nov 20, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
RS 2654 RCA
I would say it's the main power supply. Try looking for a short in there using a multimeter
Nov 13, 2007 | RCA RS2652 Shelf System
RCA 5-CD Shelf System, RS2654 Fuses
Never ever replace a fuse with a bigger one, you are lucky the unit did not blow up and statrt a fire. When a fuse blows there is usually a reason.There is a short in the main power supply or the output stage. You will need to test for shorts on the main transformer, B+ rectifiers and the main filter capacitors. If that does not show any shorts, you will need to test the audio output circuits for shorts on the audio output IC's. Good Luck
Mar 22, 2007 | RCA RS2652 Shelf System
RCA RS2652 speaker rumble...
you can use wood glue and glue it back together thats what i did with mine and i havent had a problem since
Aug 07, 2006 | RCA RS2652 Shelf System
RCA RS2652 Shelf System Logo
160 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
