Question about Atlantic Luggage Atlantic, Inc. Wire 4-Tier Gaming Tower - Silver (45506019)
Lights on towed f-150
I want to flat tow my 08 f-150 pickup STX package, yes it has a manual shift transfer case. i want to know if I create a harness to plug into the trailer light receptacle and the other end to the motorhome, will htis activate the tail and brake lights? are the actual lights on a different circuit? if so is there an aftermarket plug to expediate the chore? if they are on a different circuit, where is the easiest place to splice into the circuit? thanks
  • 382 Answers
No you can not plug into your towing wiring harness. It will daage the lighting system. It is a little tricky to explain and usually less trouble to just get magnetic remote lights. If you really want to make the lights on your truck work as described, you will need to connect the wires to each light and install diodes in the lines to prevent the current from back feeding onto your trucks electrical system. There are a few sites on line to search for more info. They call what you are doing is Toad towing. Good luck and I hope this enlightens you a bit.
Posted on Jan 30, 2009
I have a Suzuki Jimmy manual 4x4 year 2002 can I flat tow it on a Aframe behind a motorhome
welcome to USA forum
the country with not ONE< JIMNY,
but i can answer
there are 4 ways to tow this is but 1.
backwards towing is best way or drop rear drive shaft (ask)
flat tow 101:
the Jimny is SJ413 here,called Samurai.
the transfer case sets this rule (most rear device)
that rules is dont flat tow it, more that 200 miles
the rear bearing has no lube actions towed
here is the near same transmissions.
and rules (of xfr case)
ill quote my 2001 Vitara, (same setup.)
Follow these steps:
1. Set the parking brake.
2. Shift your automatic transmission into PARK (P), or
your manual transmission to SECOND (2).
3. With the ignition key in the ON position, move the
transfer case to NEUTRAL and make sure the 4WD
light on the instrument panel cluster is off. See
"Four-Wheel Drive" in the Index.
4. Turn the ignition key to ACC to unlock the
steering wheel.
5. Release the parking brake
If you tow your four-wheel-drive vehicle from
the front, make sure to move the transfer case
into NEUTRAL or your vehicle could be badly
damaged and the damage would not be covered
by your warranty.
Stop towing every 200 miles (300 km) and start the
engine. Leave the transfer case shift lever in
NEUTRAL. Shift your automatic transmission to
DRIVE (D); leave a manual transmission in
SECOND (2) with the clutch engaged. Run the engine at
medium speed for one minute to circulate oil in the
transfer case. Turn the ignition key to ACC. Now, you
can continue towing your vehicle.
The front wheels transmit shocks during towing.
The steering column may not be strong enough to
withstand the shocks. Always unlock the steering
wheel before towing.
Make sure that the towing speed does not
exceed 50 mph (80 km/h), or your vehicle could
be badly damaged
end direct quote operators guide .....
got that?
not how the 5speed box is in 2nd.
this is to keep it from spinning, and its rear bearing damaged.
there are 2 bearings to worry the rear 5sp and rear transfer case.
on ours, we use an electric oil'er pump added to transfer case.
unlimited tow. (wires power feed from RV via coupler.)
or the drives shaft decoupling device, (not cheap)
or we drop the rear, of prop shaft, and tie up the rear up high
so it cant drop nor let it fall of rear of transfer cases
we use bunji cords, for up,
and then pull the front,
if the prop shaft falls out, you will lose GL4 gear lube out rear
of the transfer case. it falls out so very easy, off that spine.
there are all ways flat,
done them all.,
Mar 04, 2017 | Suzuki Cars & Trucks
Can I tow a 1994, 4x4, 4 cylinder, Toyota pick up with a manual transmition on a car dolly? And if so, what is the correct proceedure?
yes, for short distance just place the transfer case in nuetral, for long trips place the back tires on the dolley, place everything in nuetral and ensure the hubs are unlocked if equipped with manual hubs
Mar 13, 2012 | 1994 Toyota Pickup
1995 nissan pickup 4wd 2.4 base model. Can i use 80-90 gear oil in tranny, differentials, and in transfer case?
yes, you can used 80w-90 in the transfer case and differentials, you can try it in the manual transmission but if it is to hard to shift you will have to go to a lighter fluid.
Jan 24, 2011 | 1995 Nissan Pickup
Looking to put a hitch on my ram 1500(2001). Is the wiring harness the same as if i had a tow package on it?
the wiring harness is the econimical way to go about it; it serves the same function as if you had a tow package. But if you want the Dealer Tow package look, there are multible harnesses that you can just plug into the existing plug under your vehicle
Dec 15, 2010 | 2001 Dodge Ram 1500 Truck 2WD
Can I flat-tow a new 2010 Suzuki Sierra Jimny 4WD ( i.e.on an A-Bar behind a motor home). Will flat-towing effect my new-car warranty? How do I set up the gears and transfer case for flat-towing? Thanks...
if it is 4wd with an automatic trans and you can put the transfer case in neutral it is ok to tow, any models with a manual trans. are ok to tow also
Jul 19, 2010 | 2006 Suzuki Swift
Can a 1998 4x4 S-10 blazer be dinghy towed?
Yes it can, just place your Transfer Case in Neutral position.
Shifting into NEUTRAL
To shift the transfer case to NEUTRAL do the following:
Make sure the vehicle is parked so that it will not roll.
Start the vehicle or turn the ignition to RUN.
Connect the vehicle to the towing vehicle.
Put the transmission in NEUTRAL (N).
Shift the transfer case to 2HI.
Simultaneously press and hold the 2HI and 4LO buttons for 10 seconds. The red NEUTRAL light will come on when the transfer case shift to NEUTRAL is complete.
Shift the transmission to REVERSE (R) for one second, then shift the transmission to DRIVE (D) for one second, or FIRST (1) for vehicles equipped with a manual transmission.
Turn the ignition to LOCK.
Place the transmission shift lever in PARK (P), or FIRST (1) for vehicles with a manual transmission.
Release the parking brake prior to towing.
Shifting Out of NEUTRAL
To shift out of NEUTRAL:
Set the parking brake and apply the regular brake pedal.
Shift the transmission to NEUTRAL (N) and turn the ignition to RUN with the engine off.
Press the button for the desired transfer case shift position (2HI, 4HI, AUTO 4WD or 4LO).
After the transfer case has shifted out of NEUTRAL the red light will go out.
Release the parking brake.
You may start the engine and shift the transmission to the desired position.
Excessively shifting the transfer case into or out of the different modes may cause the transfer case to enter the shift protection mode. This will protect the transfer case from possible damage and will only allow the transfer case to respond to one shift per 10 seconds. The transfer case may stay in this mode for up to three minutes.
NEUTRAL: Shift the vehicle's transfer case to NEUTRAL only when towing your vehicle.
Good luck and hope this answers your question.
Jan 30, 2010 | 1998 Chevrolet Blazer
I CAN NOT SHIFT THR TRANS INTO NUTRAL SO I CAN TOW IT BEHIND MY MOTOR HOME. IT WILL SHIFT INTO 2H, 4H, 4L
Shifting to NEUTRAL
To shift the transfer case to NEUTRAL, first make sure
the vehicle is parked so that it will not roll:
2. Start the vehicle.
3. Connect the vehicle to the towing vehicle.
4. Put the transmission in NEUTRAL (N) or have
the clutch pedal pressed for vehicles with
5. Shift the transfer case to 2HI.
6. Simultaneously press and hold the 2HI and
7. Shift the transmission to REVERSE (R) for one
for one second or FIRST (1) for vehicles with
8. Turn the ignition to OFF.
9. Place the transmission shift lever in PARK (P) or
FIRST (1) for vehicles with manual transmission.
10. Release the parking brake prior to towing.
1. Set the parking brake and apply the regular
brake pedal.
2. Start the vehicle with the transmission in PARK (P)
or FIRST (1) for vehicles with manual transmission.
3. Press the button for the desired transfer case position
4. Put the transmission in NEUTRAL (N) or press the
clutch pedal for vehicles with manual transmission.
5. Shift the transmission lever to the desired position.
After the transfer case has shifted out of NEUTRAL,
6. A re-engagement sound is normal when shifting out
of NEUTRAL.
Jan 22, 2010 | 2000 GMC Jimmy
I do not have power on the aux. terminal in the trailer plug on a 2008 dodge ram. Any ideas?
You have got 7 pin trailer connector that was included in the optional trailer tow package. This trailer tow package also includes an electric trailer brake wiring provision that terminates at a connector located on top of the large body harness connection under the instrument panel to the left of the break pedal, as well as an electric trailer brake pigtail harness and an instruction card that are stored in the glove box when the vehicle is shipped from the factory. You will need to add an electric brake controller of your choice that will plug-in to the harness and that will also give you power on your auxiliary circuit.
Oct 04, 2009 | 2008 Dodge Ram Pickup 2500
4x4 Automatic, manual transfer case. Need to know maximum flat towable speed.
I would think if transfer and trans. are in neutral it would not matter how fast you go with in reason.
May 09, 2009 | 1993 Chevrolet S-10 Blazer
Towing question
yes, but why would you want to
Nov 17, 2008 | 2008 Dodge Ram 2500
Atlantic Luggage Atlantic, Inc. Wire 4-Tier Gaming Tower - Silver (45506019) Logo
122 people viewed this question
Top Atlantic Luggage Computers & Internet Experts
David Payne
David Payne
Are you an Atlantic Luggage Computer and Internet Expert? Answer questions, earn points and help others
