Question about Toshiba 50HX81 50" Rear Projection Television
Tosheba 50hx81 no picture or sound. press on button and hear speakers do something but no sound
    Scholar:
  • 61 Answers
It is likely that you don't have the right input to the television.
First get a source that you know works. How about a DVD player.
Get the cables from your DVD player (should be yellow RCA or "Phono" plug for the composite video out put.) Connect only the yellow video out put to your t.v. input and then press the av input button until you see the picture (note: besure that the DVD player is turned on and you have a dvd in it. We sometimes miss the very basics).
Once you get the picture than connect the audio cables, should be red and white to the corresponding colors. Do you have audio now?
If this test worked fine, it is likely that the solution to your other problem is that you have it on the wrong av input and need to press that button a few more times to find your satallite or cable input. There is a possibility that you are trying to use the tuner in your T.V. and it may be again as simple as choosing antenna input and that too needs to be hooked up to a good source.
Write me back if none of this helped.
Posted on Dec 16, 2008
Why is there no sound from rear speakers?
One of the buttons you pressed probably disabled surround sound
Nov 03, 2015 | Denon AVR-791 7.1 CH A/V Home Theater...
Speakers wont come on
Lets start with the basics.
1. Make sure the power cord to the computer speakers are plugged in. Check at the wall and make sure the power cord is connect to the back of the speaker. If there is a power button make sure it is pressed in the on position. Make sure the volume level is turned up.
2. Check the computer and make sure the sound is not on mute. Turn the volume level up from the computer settings.
3. Try playing some music. If you hear sound you are good to go.
4. If you are not able to hear anything than continue. I would suggest plugging your speakers into you cell phone. Try playing some music from your cell phone.
5. If music plays through the speakers from your cell phone, something is wrong with the computer. If no sound plays with your cell phone then something is wrong with the speakers.
6. If worse comes to worse bring your computer into a computer store. Tell the salesman you want to buy a new set of speakers. You just want to make sure your computer works with the speakers before you buy them.
7. If all else fails, ask a local tech you trust.
May 25, 2015 | Audio Players & Recorders
The sound does not work on my samsung infuse 4g. I press the volume buttons up and down. I can't hear the ringer on any incoming calls. The alarm clock doesn't sound. I can hear it if I have my...
I had the same issue. Its hardware related due to no good contact between the phone and your tiny speaker.
To fix it no too hard.
1) Open up your Samsung infuse case directions here video http://www.youtube.com/watch?v=ewdyo2fkJj8
or pictures http://androidforums.com/samsung-infuse-4g/532693-how-fix-samsung-infuse-4g-screen.html
2) The speaker is located bottom left corner (two etched holes for sound)
3) With cover off locate 2 brass/bronze tabs that connect the phone to the speaker.
4) Slightly lift these tabs make sure not to far to brake off (1 mm)
5) Put back the cover and phone speaker should work fine
I hope this helps.
Jul 13, 2011 | Cell Phones
Toshiba 50hx81 no picture or sound
If you managed to find a manual or have resolved the problem, please post it back here to benefit others. You probably had a partial or complete power supply failure.
Thanks-
Dec 16, 2008 | Toshiba 50HX81 50" Rear Projection...
Can not get 3 speakers on my samsung home theater to work!
There are a few settings that will just give you a stereo output. The first one is with the Pro Logic II. If you press the PLII Mode button on the remote it will go through a series of settings from MUSIC ➞ CINEMA ➞ PRO LOGIC ➞ MATRIX ➞STEREO ➞ MUSIC. Pro Logic setting will only produce sound from the front speakers and Stereo from the front speakers and the sub. Put it on Matrix for 5.1 surround sound.
Also for speaker settings follow the instructions below.
Signal outputs and frequency responses from the speakers will automatically be adjusted according to your speaker configuration and whether certain speakers are used or not.
In Stop mode, press the MENU button.
Press the Cursor down button to move to Audio and then press the ENTER button.
In the SPEAKER SETUP, press the ENTER button again.
Press the Cursor button to move to the desired speaker and then press the ENTER button.
For C, SL, and SR, each time the button is pressed, the mode switches alternately as follows : SMALL ➞ NONE.
For L and R, the mode is set to SMALL.
SMALL : Select this when using the speakers.
NONE : Select this when no speaker is connected.
Press the RETURN button to return to the previous level.
Press the EXIT button to exit the setup screen.
It also seems that with this system, if you are on 5.1 surround but your music source is only in stereo, you will only hear stereo.
Nov 20, 2008 | Samsung HT-Z310T Theater System
Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Oct 22, 2008 | Vizio GV42L 42 in. LCD Television
Playing MPEG's
* The MPEG Playback function works in M. PLAY mode only. * You can play moving picture images on the Memory Card. * To hear sound during MPEG4 playback, you must hook up to a PC and listen to the PC's speaker. (You cannot hear it from the speaker on the camcorder or a TV) 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to PLAYER mode. 3. Press the MENU button and turn the MENU DIAL to highlight MEMORY. 4. Press the ENTER button to enter sub-menu. 5. Use the MENU DIAL to select MPEG4 from the sub-menu. (M. PLAY SELECT) 6. To exit the menu, push the MENU button. 7. Using the (FWD) and (REV) buttons, search for the moving picture that you want to playback. 8. Press the PLAY/STILL button. The moving pictures recorded on the MEMORY CARD begin playing back.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Toshiba 50HX81 50" Rear Projection Television Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
