Question about Bose (321GS) System
Disk player door
The unit will not eject the disk. I think a regular size CD was put into the unit while a small CD was alread in the tray, then the door was closed. Now the eject will not open the door. How do I fix?? dago
  • easydiver Apr 02, 2008
    was watching a dvd. it locked up. door will not open to eject disc. powered off and on but message "opening....." remains. will not open. help.
    Genius:
  • 1,175 Answers
I agree with "wireless"
The case needs to be opened to get the Cds out
Posted on Jan 15, 2009
    Scholar:
  • 113 Answers
You would need to disassemble the unit to take out both the CDs. Trying to force the disk out without opening the unit might damage it. If you are not comfortable with open it, please get someone who can actually do it for you. please revert back with the results.
Posted on Mar 22, 2007
SOURCE:
CD compartment door does not open
Hi, maybe the disk tray is stuck, with a clip you can push into the small hole located in the front of CD unit to manually eject disk tray to check if a disk is "tramping" the tray, if not, the unit is faulty and needs to be replaced.
Nov 07, 2017 | Power Up Computers & Internet
Dvd player
hey, have you tried to unplug the dvd player for a while, also hold down the eject button on the player, if there is a small hole in the tray use a needle or other small object to eject the tray,
Sep 03, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
How so I manually remove a disk from an HP Pavilion Slimline, s3120n TV PC. It is vertical, I can open the lid, but there must be a trip than releases the drive unit. I need to remove a disk with power...
Can you find a very small hole, about the diameter of a paperclip wire, on the front of the unit, maybe behind the lid? If you take a paperclip and straighten it out, gently push it into that hole until you see the disk tray push out slightly, then CAREFULLY pull the tray out the rest of the way with your hand. It should be done with the power off so the disk drive doesn't try to close itself on your fingers! Hope this helps. I've included a video I found on youtube.com that shows exactly how to do this, it only takes a second!
Dec 19, 2010 | HP Disk drive - CD-RW / DVD-ROM combo -...
Disk won t load
if it is a brand new unit you have to remove the shipping screws that are usually on top of the unit, if these havent been removed you cannot load or eject a disk. They put theses in to prevent damage to the unit. If it is an old unit, ensure there isnt alread a disk inside the device, or worse that a child or etc hasnt jammed anything inside it.
Aug 08, 2010 | Rosen A7 Car DVD Player
Dvd will not eject from jvc hr xvc27u dvd player all it will do is display the word read on the screen
elsombro is right. There is a little whitish plastic square on the right side of the player, part of the DVD assembly (after you take off the cover). It's about 1/4 inch square. With the unit turned on, push that square with a pen about 3/4 of an inch in or as far as it will go. There will be a clunking sound but that is the sound of the DVD being released back onto the tray. Now gently push the back of the tray forward, ejecting the disk manually. Take the disk out and then press the close button. If the door doesn't close, it's out too far so manually push it in about an inch or so and then press the close button again. Should be fine after that. I think my problem was a DVD I recorded on my computer and it has the wrong format or something. After I got it out I put a regular DVD back in and everything was fine.
Dec 30, 2009 | JVC HR-XVC27U DVD Player/VCR
Manaully open a disk player for a emachine
there's a small hole in the front of the disk drive close to the base of the tray and near the button used to open the drive. get a paper clip, open one end, hold carefully, and place it in the hole and push carefully till the drive opens.
to close, just push the tray back in firmly but without slaming it in. don't want to damage any of the gears inside.
Sep 24, 2009 | Computers & Internet
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
Disk tray wont open
Either loading belt for mech has gone meaning not unloading for door eject,or door belt has gone
Dec 28, 2008 | Sony CDP-XE570 CD Player
Cd is stuck
put the same disk in , play it for a while then eject it properly.
Nov 13, 2007 | Pioneer AVH-P6500 Car Video Player
Bose (321GS) System Logo
143 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
