Question about Toshiba 50HX81 50" Rear Projection Television
Toshiba 50hx81 no picture or sound
Turn on with button on tv, light comes on, speakers make a sound like they have power, but no picture or sound. how do I get a repair manual?
  • Anonymous Feb 28, 2009
    toshiba 50" rear projection, tv comes on with green screen and I have sound in all ports but no picture. Menu screen appears and looks perfect.
  • Toshiba Master
  • 5,568 Answers
If you managed to find a manual or have resolved the problem, please post it back here to benefit others. You probably had a partial or complete power supply failure.
Thanks-
Posted on Jan 27, 2009
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
No pic or sound with power on my Toshiba 50HX70 Tv
The plug configuration shouldn't make a difference; the third (round) pin is only an earth/safety ground. The two primary plugs supply the AC. You probably have a failed power supply which may be a separate board. Check to see if this is the case, look for a part number and see if you get any hits on it on search.
Jan 16, 2009 | Toshiba 50HX81 50" Rear Projection...
Tosheba 50hx81 no picture or sound. press on button and hear speakers do something but no sound
It is likely that you don't have the right input to the television.
First get a source that you know works. How about a DVD player.
Get the cables from your DVD player (should be yellow RCA or "Phono" plug for the composite video out put.) Connect only the yellow video out put to your t.v. input and then press the av input button until you see the picture (note: besure that the DVD player is turned on and you have a dvd in it. We sometimes miss the very basics).
Once you get the picture than connect the audio cables, should be red and white to the corresponding colors. Do you have audio now?
If this test worked fine, it is likely that the solution to your other problem is that you have it on the wrong av input and need to press that button a few more times to find your satallite or cable input. There is a possibility that you are trying to use the tuner in your T.V. and it may be again as simple as choosing antenna input and that too needs to be hooked up to a good source.
Write me back if none of this helped.
Dec 16, 2008 | Toshiba 50HX81 50" Rear Projection...
No sound or picture
your relay is turning off most likelt due to on of the stanby voltages being out of parameters I would check the low voltage regulators and the horizontal output transistors.
Jun 16, 2008 | Toshiba 50HX81 50" Rear Projection...
Toshiba TV 50HX81
Check fuses on Power Supply board (F850, F851, F852) and all other fuses. Replace blown fuses (will need an ohm meter to check fuses). I would also replace the two convergence amps (STK392-110's on the signal board, the big black ICs on the two heat sinks). This worked for me.
Mar 30, 2008 | Toshiba 50HX81 50" Rear Projection...
Toshiba 50hx81 power light just blinks
Go to Powered Products List view all in my profile and read
Toshiba entries........Let me know how it is going.........T.
Mar 15, 2008 | Toshiba 50HX81 50" Rear Projection...
Issues with picture after moving Toshiba 50HX81 - picture is bad
i would check for loose connections by the convergence amp ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 25, 2007 | Toshiba 50HX81 50" Rear Projection...
Toshiba 50hx81 Squiglly Lines
Bad hyper board = Needs rebuilt, technician skill level high....
Sep 15, 2007 | Toshiba 50HX81 50" Rear Projection...
Toshiba 50HX81 50" Rear Projection Television Logo
165 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
