Question about Gaggenau EB294/295 Electric Double Oven
Code F14 When is is not in use, it occasionally beeps and displays a code F14. The code can be cleared by opening and closing the door, or fiddleinf witn the on/off knob. What does this code mean?
  • 27 Answers
F14 is usually the fault code (open circuit) for the NTC sensor on the electronics module. I would suspect a bad connection from the oven temp sensor (located at the rear of the oven) to the electronics module. If you are able to remove the oven from the enclosure and remove the top and rear panels, (power disconnected!!) I would suggest checking all connections to/from electronics module. Also make sure door contact switches are secure and not loose (remove side panels) Oshie
Posted on Jun 26, 2007
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
Tip
My Whirlpool oven wont work, and I get error code E1-F5 on display.
Hi.
On Whirlpool ranges the error code E1-F5 means that there is a problem with the door latch switch or with wiring to door latch.
Try first disconnecting power for five minutes, by either tripping circuit breaker or disconnecting power cord.
You may have to pressand hold the Cancel/Clear key on control pad down for about 1 minute to clear F5 failure code from ERC internal EPROM.
If that does not work, then there is a fault.
Disconnect power, access the door switch and testwires and connectors going from electronic control board to the doorswitch. An easy way to test wiring is by reading Ohms on the wire. Ifthe circuit is closed, the tester will read zero or low impedance, thatmeans that the wiring is good. If the multimeter set on impedance readsopen (no continuity), that means that the wire is broken and the wiringharness to the door latch must be replaced or fixed.
If there is no problem with the wires from Oven Electronic Control toDoor Latch Switch, then the door switch is probably faulty.
The switch can be tested reading Ohms on its contacts, and checking ifthe switch is opening and closing circuit while actuating the switchwith a pointed object at the same time.
If the switch is faulty, then replace the door switch.
After repairing the wiring or replacing the switch connect power back.You may have to pressand hold the Cancel/Clear key on control pad down for about 1 minuteagain, to clear F5 failure code from ERC internal EPROM. When F2 isshown on display, push the Cancel/Clear button again and observe theappliance working testing it again, to ensure that the repair had beensuccessful.
The tip is not only valid for Whirpool ovens, but also works on other brands that had been built by Whirlpool.
Best regards.
Ginko.
on Mar 22, 2010 | Ovens
Frigidaire beeping with F10 signal
sounds like you need to get all food out and switch it off and leave the doors open and leave it for two days with the doors open ok then afther you have left it swich back on with doors closed do not open doors for 24 hours swicth on ok then it should be ok if not then its lack of gas
Oct 15, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Can't open the oven door with an F9 and beeping
Here's the info from the service manual
"Fault Code: F9
Likely Failure Condition/Cause:
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for
30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door
Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and
close, check with ohmmeter). The Lock Motor may be
powered as in above step to open and close Lock Switch. If
the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
Feb 24, 2011 | Frigidaire GLEB27S7A Electric Single Oven
Frigidaire oven f9 code
Here's the info from the service manual:
"Fault Code: F9
3. Wiring Problem.
1. Press CLEAR key.
Switch circuits.
P4.
- www.fixyourboard.com
Jul 25, 2009 | Frigidaire FEB30S5D Electric Single Oven
Beeping driving me crazy
Ok, the first issue is the oven temp sensor. it is shorted. you will need to replace this device asap. Now, the second is is concerning the Self clean latch. it is not functioning and it is unable to be locked by the control(shorted). Use the procedure below to test this device.
1. If door latched:
1. Disconnect power from unit.
2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Replace door switch.
4. Re-apply power.
5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
May 29, 2009 | Whirlpool RBD305PR Electric Double Oven
Code fse1 comes up when a few minutes after pushing start to cle
F5 - E1 Self clean latch will not lock
1. If door latched:
  4. Re-apply power.
Apr 01, 2009 | Ovens
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
F-24 error, beeping after use - Thermador C302US
error code f24 oven shuts down while baking if i open the door and beeps continuously
Jan 24, 2009 | Thermador C302U Electric Double Oven
F14 error message
First change the fuse. Then if it still isn't functioning properly, you may have to replace the lamp, in which case you should contact a specialist. Details can be found in the Instructions Manual.
Go here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
and enter EB270 and click the Go button.
Then download the PDF file of the manual in English (EN)
Hope this helps :)
Chris (ziraffa)
ps Someone else on Fixya claims to have fixed the F14 problem by changing the PCB Board, whatever that is.. but there was no further rating or feedback given. That's all I have.. Good Luck!
Jan 11, 2009 | Gaggenau EB270 Electric Single Oven
Gaggenau EB294/295 Electric Double Oven Logo
1,235 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
Oloyede Monsuru
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
