Question about Weather King 12AJA6001AH Air Conditioner
The thermostat is set at 72 and the heat hasn?t been kicking on!
We have been experiencing a cold wave with outside temperatures below zero at night. Could extreme cold be compounding the problem?
  • 700 Answers
Yes it can what happens is that the house is loosing more heat than what your furnace or heat pump can produce.
Posted on Dec 22, 2008
Heat pump not keeping up to set temperature on thermostat but never drops below 63 degrees whens its 20 degrees outside.
It may be getting low on refrigerant due to a small leak. I'd have it serviced soon. When running at less than peak efficiency it will much more often switch on the heat strips and they are not cheap to operate.
Jan 06, 2015 | Heating & Cooling
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
My robertshaw thermostat works well in summer when using my Air conditioner. I have a heat pump. but in the winter the thermostat frequently displays "ER" during cold winter nights when the unit...
what it sounds like happening is the unit is realizing it is falling behind most thermostat s have a 3 degree deadband if they fall 3 degrees or more at a time after running for so long then it will bring on the emergency heat which is located in your inside unit... when it gets really colds and you see this you need to go outside and look is the outside unit still running and is it freezing up on you...also if running check the larger of two pipes make sure the large pipe is hot to touch...based on the description you have given the thermostat is calling for emergency heat but for some reason is not bringing it on or there is a problem with the emergency heat.... hope this helps out some
repost with any additional questions...
Jan 08, 2011 | Honeywell Electronic Programmable...
On my thermostat which is a white-rodgers the flame symbol is flashing the heat is set to 68 but it stays on 66. I have a split unit Ruud. The problem happens at night when it is cold.
Is this a heat pump system? If so I would recommend switching the thermostat to aux. or emegency heat at night when it is cold outside. The heat pump will not keep up when the outside temperatures are real cold.
Jan 15, 2010 | Heating & Cooling
My heat pump runs most all the time i will set the thermostat on 70 when it gets to 70 it still runs I can kick it back down to 69 and it kicks off.I can put it on 72 when it gets to 72 it still runs, I...
therostats have what is known as off-set deflection , or simplely put the plus or minus of the temp range which the heat turns on or off this setting is adjustable on many thermostats i usually set for 3 degrees if it is set for 1 or 2 it will run all the time refer to owners manual to see how to set this in program
Jan 06, 2010 | Honeywell Programmable Thermostat Heater
Goodman package- no heat below 30 degrees outside
I believe the unit you are describing is a heat pump. Heat pump are great when the temperature isn't below 30 With low ambient temps. outside it is much more efficient and comfortable to run aux. electric heat from the heat pump.
Jan 03, 2010 | Goodman PHKJ048-1 Air Conditioner
Furnace runs but does not heat up the house to thermostat tempera
Did this problem just start? Or has it been a long term issue? Check for broken ductwork, return air pulling outside air in. Check supply air temps, should be 100-140° or more. And what is the outdoor temp? If it's 0° outside, 74° is doing good. Is the home insulated properly? And there is a small hole behind the t-stat where the control wire comes through the wall. Plug that hole, seal that hole to prevent cold air from fooling the t-stat. The furnace has 3 fan speeds and it may be in low speed. If so it should be in medium speed. I'd suggest a service tech doing this for you unless you are experienced in furnace repair.
Nov 02, 2017 | Goodman Heating & Cooling
Goodman PHJK048 Heat Pump Package
ok...where to start.lol ....the thermostat is just a switch.It will tell the unit to run or not run.if you measure the temp with the heatpump running,the air is warmer than 68 but it feels cool to you because your body is 98.6.The unit will run more often and for longer periods when the temperature drops outside for a few reasons.First,your house has more of a load to heat,meaning you have more heat loss because of the difference in temperatures outside and inside.Second,your heat pump pulls heat from the outside air.The colder the air outside,the less btu's for it to pull.If you have anymore questions hillbuck29@aol.com Hope this helps,Dave
Nov 10, 2008 | Goodman PHKJ048-1 Air Conditioner
Weather King 12AJA6001AH Air Conditioner Logo
75 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
