Question about Hitachi CP-X327 Multimedia Projector
Not getting any scrren at all.
When the projector is powered the power light stays on and red and the temp light just flashes. before this problem it would show a screen and say that there was a problem with the lamp and it needed to be replaced. the lamp was replaced and this new problem appeared.
  • 944 Answers
Is the cooling fan working? - usually if a bulb replacement doesn't solve the problem, and it has been installed correctly, then the safety overheating cutout may be preventing the bulb from working due to a cooling problem - check the fan spins and sound healthy, check all the yents / filters are clear and if you can see the blades, see if they are particularly dirty/dusty. If the fan seems to be fine then the safety cutout itself is likely to be faulty - contact hitachi; http://www.hitachi.co.uk/service/index.jsp And they should be able to give you the details of the nearest service to you. Hope this helps :)
Posted on Mar 22, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 22, 2007
    That should say vents, not yents. Sorry :)
A flashing red light came on my acer projector pd120d but it did not stay on it displayed the power, temp and lamp
Projector bulbs generate alot of heat. Make sure the vents are not blocked or dirty. Check the fan to make sure it is operating properly. Hope this helps.
Jan 06, 2014 | Acer PD120D Multimedia Projector
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Infocus in15 temp and lamp indicator flashing
In attempts to get your IN15 projector working, please try the steps below.
Disconnect AC power from the projector and wait for 10 seconds for supply to properly discharge.
While holding down the Menu, Select and Input buttons simultaneously, plug in the main AC power until
the LEDS stop flashing (approximately 7 seconds)
Jul 15, 2012 | InFocus IN15 DLP Projector
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
Projector problem HELP!? my projector was on whiles the utility power went out, and when the power came back i realised it had affected my projector, when i put it on (press the power button) the:...
Kindly get intouch with Cinesonic Audio Visual Pvt. Ltd. in New Delhi at 10/2, DLFIndustrial Area, Shivaji Marg, Moti Nagar,
New Delhi-110015
Contact: ' Board: +91-11-47424444 (30 Lines)'
e-mail: Robert@cavpl.com
For any problem related to Casio Projectors
Mar 21, 2011 | Casio XJ-S31 Projector
The projector turned itself off after couple hours of use and the Temp. red light came on. Power Light turned red instead of orange as usual. After 3hrs I turned it back on, cleaned the dust off the fan...
There are three temp sensor inside the projector and now your projector need full service but if the air filter becomes clogged with dust, the internal temperature of the projector will rise, the TEMP indicator will illuminate and the projector's power will turn off (the TEMP indicator will flash after the power is turned off) The air filter should be cleaned every 100 hours of use.
If you clean the filter with a vacuum cleaner to clean off any accumulated dust. then your projector working normally
Jan 03, 2011 | Panasonic PT-LB50U Multimedia Projector
PROJECTOR PROBLEM Casio XJ 31
it wasn't able to go through cooldown mode. turn it on, power down and let it go through cooldown. does the light come on at all?
May 31, 2009 | Casio XJ-S31 Projector
LCD projector still not working after lamp change
Sounds like you have a faulty ballast. I recomend changing it. This is your lamps own power supply.
Apr 10, 2009 | Hitachi CP-X250W Multimedia Projector
Hitachi CP-X327 Multimedia Projector Logo
214 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
