Question about Baumatic 24 in. BFD60SS Free-standing Dishwasher
Stopped & won't drain
After initial spray, machine beeped 10 times and stopped, beeped again 10 times few mins later. on looking inside, dirty water in base. display shows like a small L with a line under it and lights 1,3&4 (of cycle options, on the right) are flashing.
what does this mean? nil in manual!
i checked drain hose-it's ok.
what else can i do??
Pump is Jammed
Posted on Jan 31, 2009
Bosch dishwasher beeping during cycle
Take the front kick panel off and see if anything under the machine is wet.
Jan 06, 2014 | Bosch Evolution 800 SHE58C02UC 24 in....
Indesit Dishwasher not washing properly or draining
Could be a few problems here. The main one may be the timer. Generally the timer will tell each part to do what it needs to do and when, if it is not closing relays then you get a dishwasher full of dirty dishes. I would also check the pump to make sure it is operating properly. But I would venture a guess at the timer being the main problem.
Sep 06, 2012 | Dishwashers
I just had my brakes changed on my 2006 passat. Now the electronic parking break sensor won't stop beeping but everything works. How can I get the fault to go away so It will stop beeping
also if u take battery off for 10 mins, hook battery back up again, turn car on, hold in break paddle for 35 seconds, then still holding in break paddle hold in handbrake button for 10 seconds, release all and start car up, press break button a few times, turn car off again take out key, lock and open car then press break button again and now all should b back to normal
Mar 27, 2012 | 2006 Volkswagen Passat
WILL NOT SPIN WATER OUT
Description of issue is lacking detail but... If the washing machine appears to be functioning normally but simply won't pump away the water then the possible causes, in the most likely order, are a blockage somewhere, a pump failure, or an electrical fault stopping the pump from running. A different fault that could be confused with "not emptying water" is if you don't take the washing out until several hours later and find there is still water inside the drum. If the initial water drained out ok but then water seeped back in over the next several hours you could think you have a problem with the machine not draining the water when in fact it's letting water siphon back in or a faulty valve is causing water to seep in.
Jul 25, 2011 | Washing Machines
Ignis adl349/a seems to fill and drain ok but stops after 2/3 mins and beeps 4 times
What this actually signifies is that there is a problem with the spray arms; they are blocked, needs cleaning.
Then, check on the filters as well, its an uncommon problem, but once cleaned, run the machine on a hottest wash, hope it clears the problem.
Check inside for the hose (see if in place or off the top spray bar)to check whether water is going into the spray bars and spray arms work well. ----------
The 5 flashes indicate a spray. Pump fault, either blocked or motor fault.
Press and hold the start button until the light goes out.
Select a program and try the machine again.--------
This should help.keep updated.Thanks.Helpmech,.
Feb 16, 2011 | GE Built-In Dishwashera Oven
Beeps 3 times when turned on
3 beeps means the machine has ran two 1 hour cycles back to back to make ice an average timeframe for ice making is 25-30 min. Could be several issues, float switch dirty, water valve leaking by, dirty spray tubes, dirty evap., then go to refrigeration Expansion valve, compressor, charge, Hot gas valve leaking by,,,,,
Jun 23, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Will not spin during any cycle w/ or w/out clothing inside
that sounds like something else, I had a similar problem yesterday, the washer would stop after a few mins, I traced the fault to the water hoses, it was plummed in with a hot water feed that can get dirty over time. this had blocked the inline fiter stopping water getting into the machine, if it does not fill within three minutes it can cancel, I cleaned the filter and was out in 10 minutes.
Apr 13, 2009 | Washing Machines
Dishes come ot just like I put them in
Check that both spray bars are turning. They can both be easily removed.
Once removed, make sure they are not clogged with stuff to prevent them from turning.
I assume you can hear water spraying around inside when it's washing, and that the dishes do get wet, and water does get hot.
Soap dispenser requires water hitting on it to open.
Jan 28, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Dishwasher not pumping water
anti flood mechanism activated in base pan you have a leak once the anti flood is activated in puts the machine into permanent drain thats why it runs even with the door open but only runs the drain pump not the wash pump.
Mar 01, 2017 | Bosch 24 in. SGI43E05GB Built-in...
1 beep per second and odd light sequence
there some simple solutions but may not always work but everyone should try. underneath when the water pump engage with the tub. there;s a white plastic clip press it out and turn the water pump. it will come off the tub. before doing this you should have the washer disconnected. have someone or put something under so the washer won;t fell on you while reaching down. sometimes debris gets stucks on the way from the tub to the pump. it insert your fingers inside once the pump is taken out and if you find debris take it out. put back the pump and connect the washer again. this can be a very simple solution it won;t work all the times. but what if it does. :)
Jun 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Baumatic 24 in. BFD60SS Free-standing Dishwasher Logo
426 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
rich2481
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
