Question about HP P1100 21" CRT Monitor
Picture problem sir ihave a 21"inch HP P1100 (Sony D2846 monitor N3 Chassis).problem is when i adjust pic up or down it shift more high or down not proper centre & when i zoom it pic turn in side on both top corner.cinema scope pic is ok i mean to say 2"top side & 2" bottom side.now i adjust vertical hieght pic shift more up or more down. kindly reply soon. thanks. satnam singh NEVER POST EMAILS
  • HP Master
  • 3,529 Answers
CATHODE RAY TUBES IN YEAR 2017, ?
whats it plugged into.
my guess its plugged in to some unnamed PC.
try it on , another PC yet, that monitor ,new will no recognize old monitors.
test the monitor , then if its ok then the unstated PC is at fault./
you have 2 boxes there, 1 or other is faulting.
easy no?
Posted on May 19, 2017
5 Suggested Answers
SOURCE: HP mx705 17 in.CRT Conventional Monitor vertical goes bad
it seems that youre monitor has a dry solder problem, try tapping it if the picture resumes to normal for a while than get it resoldered from a technician. if it soesnot solve problem than look out for a burnt resistance.
Posted on Jun 26, 2007
daemonguy
  • 118 Answers
SOURCE: usercontrol automatically displayed when bootup
Please change the switch pannel  and check
Posted on Nov 20, 2007
bluenadas
  • 203 Answers
SOURCE: monitor settings
Have you checked the actual board that has the buttons to see fi there is an issue there?
If you've found nothing there and still experience the issue, sounds to me like you might be looking at a bad micro.
Posted on Nov 21, 2007
SOURCE: Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Posted on Oct 28, 2008
I need to plug an HP f2105 monitor into an HP elitebook laptop
Elitebook has a vga port with is 15 pins. If the monitor only has DVI you can get a VGA-to-DVI-A cable. They are cheap and available on monoprice.com Make sure the monitor supports DVI-A
Make sure to check the DVI port on the monitor for the wide horizontal pin with two small pins on top and two underneath. See pic below.
Dec 03, 2012 | HP f2105 21 inch LCD Monitor
How to adjust color of screen
click start control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range
click start control panel,display,desktop you can select a different desktop from the drop down list also there should be a browse button where you select your own personal picture saved in my pictures also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope it helps
May 15, 2012 | Hannspree HF225DPB 21 inch LCD Monitor
I have an EIZO T962 CRT 21 inch monitor with bright screen. I can't adjust brightnes with conventional means ( adjusting via buttons). In the past I correct this problem on Sony trinitron 19 inch monitor...
CHECK FOR DAMAGED RESISTORS ON BOARD NEAR HIGH VOLTAGE AND ALSO ON CRT SOCKET, ITS A COMPONENT PROBLEM, RECTIFY IT..CHANGE THE DAMAGED COMPONENT, ALSO CAPACITORS IF POSSIBLE..
Oct 16, 2009 | Eizo FlexScan TX D7S Monitor
No green red and blue good.
THERES A PROBLEM WITH HIGH VALUE RESISTOR ON YOUR CRT SOCKET CONNECTOR, RANGING IN 15K OHMS, CHANGE IT..CHECK FOR DRY JOINTS RESOLDER IT...BETTER IF BOTTOM BOARD IS SOLDERED..
Oct 13, 2009 | HP P1100 21" CRT Monitor
Compaq P1100 Monitor
The monitor probably is no good.
Oct 22, 2017 | HP Compaq P1100 21" CRT Monitor
Polaroid monitor picture is shifted to left about an inch
Hi you may try
1)to key the auto(adjust) button at TV monitor keyboard if not ok,
2)to change display pixels density from PC display setting because TV monitor could not support the display pixels you using and sync.the picture on well.
3)also you may adjust monitor screen H position(it maybe not convenience for back TV).
Dec 21, 2008 | Polaroid Computers & Internet
Not powering on
You will need to take it in for repair. This is most likely a power supply problem.
Lou
Aug 24, 2008 | HP P1100 21" CRT Monitor
Many screens on one monitor!
Your monitor is malfunctioning and requires servicing. Unfortunately there is no software solution, and no monitor adjustment buttons will control this problem. Due to the high cost of replacement parts and service technicians, it may be more cost effective to buy a new LCD monitor. Sorry to be the bearer of bad news :(
Jun 10, 2008 | IBM P 202 21" CRT Monitor
Not coming on
check your connection on your graphics.make sure you have activated your screen on control panel-display-advanced.
May 12, 2008 | HP P1100 21" CRT Monitor
Small annoyance with HP P1100 monitor. Slightly darker vertical lines.
Sounds like dried out electrolytic caps. How old is the monitor ?
Dec 19, 2006 | HP P1100 21" CRT Monitor
HP P1100 21" CRT Monitor Logo
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
