Question about Panasonic KX-TG5439 5.8 GHz Dual Handset Cordless Phone (P02120)
Can't make or receive calls
When I try dialing out the phone readout states "No link to base. Move closer to base Try again"
I was just using the phone. Both phones live in their recharing bases and I am within 2 feet of the base unit trying to make a call. The phone doesn't ring when someone is trying to call in.
SOURCE: Link to Base
unplug both wires at back of base and replug after about 5 minutes - it should work now
Posted on Jan 02, 2008
jessee007
  • 310 Answers
SOURCE: no link to base Panasonic KX-TG2357
are you running a wireless router? try unpluging router to test phone.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 07, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: no link to base move closer to base
Your getting this message because the radio portion of the handset or/and base is not communicating with each other. This can be temporary or fatal. You can try re-registering the handset(s) to the base by following the directions in the manual, its fairly easy to do for any model. If that does not work,and you have more than one handset not working with this problem, then it sounds as if your base needs repair or replacing.
Posted on Feb 04, 2008
tomsbn
  • 65 Answers
SOURCE: Handset is fully charged and states No Link to
before using the phone,the handset has to be registered with the base...from the menu select handset registration..then press the speaker button for some time which will register the handset...if u have a manual for this phone,please try from that book about handset registration..
Posted on Oct 23, 2009
  • 5 Answers
SOURCE: My cordless phone says No link to base Move closer
This is the usual message that the phone gives when the battery has died and it has lost connection with the base unit. The usual fix is to remove and reinstall the battery, then place the unit on the charger for a full charge. This will usually fix the problem that you discribed. If after a full charge, you still get that message, you will most likely need a new battery. Good luck...
Posted on Nov 06, 2009
A key symbol on the left hand side of the phone is blinking. I'm unble to make a call,its telling me that no link to base. move closer to base, Try again. All the phone cords are in the socks and...
The key symbol is supposed to be an antenna.
It can't receive a signal.
There are a few possibilities:
- Too far from base. Move closer.
- Base is unplugged (no power at base station)
- Phone has become unregistered (unlikely).
If you need to re-register the phone, the process will vary depending in the model of the base station and will be covered in the manual.
Apr 05, 2011 | Panasonic KX-TGA101S Cordless Handset
Panasonic KX - TG5664
may be the problem is with the speakers check that first
Jun 02, 2008 | Lands Phones
The telephone batteries are fully charged; however when I attempt to use the telephone I receive a message stating, "No link to base. Move closer to base, try again." The telephone is very close...
Check your user's manual for registration, or RE-REGISTER the handset to the base. In essence, it involves stepping to the registration on the handset, pushing the handset locator button on the base, then saying OK on the handset. They will sync up.
Carl
Feb 10, 2011 | Panasonic Lands Phones
No link t move closer to base try again base
this depends on what phone you have. most pjones when you open the back of the battery cover, their is a connect button really small. look around the base for a connect button and press the base connect button first, then the phone. after abit they should connect to each other. plaese let me know if this does not work
Feb 23, 2010 | Lands Phones
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
Can not dial out gives me a message that says no link to base
several things check the base is connected to mains power and switched on.
You have obviously checked to see if it is outof range,and checked the batteries.
If you are using more than one base check that you ar connected to the right one.
Also if you have too many appliances connected to the phone point they won`t run.
Nov 05, 2009 | Panasonic Phones KX-TG5571
Handset is fully charged and states No Link to base. Move closer to base, try again. This does not work as it has been tried.
Oct 22, 2009 | Panasonic KX-TGA101S Cordless Handset
Phones have no dial tone and a message that says
Unplug base (both connections) and re-plug them again. It works for me whenever this happens.
Mar 17, 2009 | Panasonic KX-TGA560M Cordless Expansion...
Link to Base
Dec 30, 2007 | Panasonic KX-TG2357 Cordless Phone
Panasonic KX-TG5439 5.8 GHz Dual Handset Cordless Phone (P02120) Logo
60 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
