Question about ViewSonic G70f (Beige) 17 in.CRT Conventional Monitor
Squiggly monitor I have a monitor that is hooked up to a projector in a lab setting. The screen on both sides of the monitor, not the projected image on wall, is very squiggly. Is there a fix to help the screen so that it is not squiggly and you can read it without hurting your eyes? The monitor also does this when it is not hooked up to the projector.
  • 624 Answers
Since the image on the projector is OK then the problem definitely lays in you monitor. You might want to turn off any other electrical equipment in your lab, especially any kind of radio transmitter and see if that is affecting your picture. Strong magnets or large power cables can also generate magnetic fields that can adversely affect CRT pictures as well. If that isn?t the problem then it is likely the monitor. It can be fixed; however, this is typically beyond the skills of the average user. Any TV and some computer repair shops can repair a CRT but is it economically feasible? A new 17? CRT can be had for $60 on-line and that has a 1 year warranty. Repairing your old monitor could easily run that or more and usually is only warranted for 90 days. Let us know if you have any other questions and please don?t forget to rate this posting.
Posted on Mar 22, 2007
Infocus lp425z projector pushes latop display to left quarter of output image
Usually this is a hardware acceleration setting problem on the 'advanced' properties setting in your 'screen resolution' properties on your computer. Re-set the hardware acceleration to the 2nd setting and this should fix your issue. We have this regularly when we project on a double projector system and the one projector keeps shifting everything left until we adjust the hardware acceleration settings on the computer. No more issue.
Mar 11, 2013 | InFocus SOFTCASE, LP425Z Multimedia...
I hooked up my Think Pad laptop to an Epson EMP-74 and the image projected is upside down. How do I fix?
Do the following for setting the screen.
1. Press the Menu button
2. Select Projection
In the Projection option,
Select Front : When the projector is in front of the
screen.
Select Front/Ceiling : When the projector is in front of the
screen and suspended from the ceiling.
Select Rear : When the projector is behind the
screen.
Select Rear/Ceiling : When the projector is behind the
ok
Apr 06, 2011 | Epson EMP-74L Multimedia Projector
I have a Dell laptop ready to go with my first Power Point presentation. I check the projector out from the library and there are no instructions. I googled instructions and tried the advice: Push Fn and...
Look for the F-key with a square/icon of a laptop. Press FN+This button until you see your screen display show that it will be using your LCD + the output on your computer. Remember you need to hook both the VGA or HDMI out to the projecter as well as the USB cable.
Mar 03, 2011 | InFocus In2102 Projector
CTX EzPro 550 data projector and laptop operating on Windows XP
Usually the key combination is 'Fn' (function Key) + F4 (or which ever F key that displays the symbol of monitor on it). This key combination is used to toggle the display between monitors.
Please come back and vote for me if this turns to be helpful for you. Thnx
Mar 20, 2010 | Electronics - Others
Image not seen on screen...only a blue background
go into the settings menu and select the computer input.
Jul 17, 2009 | Sanyo PLC XU35 Multimedia Projector
Computer used to work with projector, and now doesn't?
Have you tried pressing Fn F5? On my system (HP), by computer monitor goes dark when I connect the projector. Pressing (Function) FN F5 toggles the video between Computer Monitor, Projector, or Both.
Check the function settings for your computer. On my Compaq laptop at home, the video function is F4, so there may be different settings for your computer.
Jan 10, 2009 | Office Equipment & Supplies
Cut off part of projected image
Hi-
Try changing the cables and try setting the resolution to 800x600 on the computer.
hope this helps
Aug 25, 2008 | Epson EMP-S3 Multimedia Projector
Can't get computer images to project
Hi, I have found out that you must have the laptop set to an external monitor, in the control panel, display area, click on 2, then you must have the projector turned on before you start the laptop so it can recognize that the projector is there. Also make certain that you allow the unit to cool off by turning the lamp off, leaving the fan on and open the door where the projection lens is located.
Jun 29, 2008 | Lightware VP 800 Plus Multimedia Projector
Reversing the picture on the monitor
Here is the manual:
ScreenPlay 4805 ScreenPlay 4805
Check page 38 on picture settings, you can revers the image to project from behind a screen (mirror), I don' think you can have picture upside down (180 rotation) using projector settings. You need to reverse image source (eg. picture on computer).
Apr 24, 2008 | InFocus ScreenPlay 4805 Multimedia...
Projected image is not the same as computer monitor
as long as nobody has physically changed the lens poition, you can go into the menu on the projector and do a factory reset. this should default the settings back to where the installer put them.
Feb 05, 2008 | Mitsubishi ES100U Multimedia Projector
ViewSonic G70f (Beige) 17 in.CRT Conventional Monitor Logo
149 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
