Question about Whirlpool Washing Machines
PUMP WORKS NOTHING ELSE
ONLY FEATURE WORKING IS THE PUMP - DOESNT FILL WITH WATER OR SPIN
  • Dave May 11, 2010
    Can you give a model #? Is it a top load or front load? thanks Dave www.washermd.com
  • 113 Answers
If its a front loader, it sounds to me like the pressure switch that regulates how much water is supposed to be in the tub thinks that theres too much water. So its constantly trying to drain. If you can give me a model # I can be sure, and also provide you with a part # and schematic. Thanks Dave www.washermd.com
Posted on Dec 16, 2008
Machine starts, fills with water & then nothing... clicks on and off & time counts down. Won't spin or drain water... have cleaned filter & removed pump to check it-- all good--- then worked for two loads...
YOUR ISSUE SEEMS TO INDICATE TO AREAS TO LOOK INTO THE NON WASH OR NO AGITATION USUALLY IS DUE TO A BAD WATER PRESSURE SWITCH, THE NO DRAIN NO SPIN IS USUALLY DUE TO A CLOGGED PUMPED OR IMPEEDED PROPELLER, ARE U SURE U CHECKED IT WELL? THE ONLY OTHER THING COULD BE IS UR CONTROL BOARD IS MIS COMMUNICATING WITH UR DRAIN PUMP?
SEE PICS
May 26, 2015 | Washing Machines
I have an old speed queen Moddl AA84** i fills but nothing else- wont run-drain- spin and does not sound like it wants to try.
Go inside and try to bypass the computer board to see if it will run. If it doesn't call a repair man. If it does, then replace the computer board.
Sep 01, 2014 | Washing Machines
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing machine does not work
coupler or belt is out. whirlpool built machines use a coupler instead of belt. it is behind motor and pump
May 04, 2008 | Washing Machines
Washing Machines Logo
24 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
