Motherboard shuts down before booting !
HI,
I'm building a budget PC to run under Ubuntu 8.10 Operating System.
I am stuck at the first hurdle - getting my motherboard to boot up!
Have installed an Intel D845GBV Motherboard into a new case & 400w ATX PSU.
Have correctly connected the 20 PIn power and the 4 pin 12v connectors.
The board is fitted with an Intel celeron 2.4 GHZ CPU and 512MB DDR 266hz memory.
I have connected the following also:
CRT monitor via onboard VGA port.
The front panel leads (Power switch, Power LED, Reset switch, HDD led, Front panel USB cable, Front Panel Audio cable)
The optical drive and HDD to the relevant IDE ports.
PROBLEM DESCRITION:
When I switch the psu ON from the ON/OFF button at the psu, the fan above the CPU is active, I can hear the HDD and then the all activity stops. The whole process lasts about 7 Seconds. There is no display on the monitor and no error bleeps from the onbaord speaker.
The green power LED on the board remains ON.
Nothing happens by pressing the power or the re-set switches on the front of the case.
The only way I can re-start the above activity is by switching OFF the PSU and then as soon as I switch the PSU back ON - the activity as described above repeats.
Which I pressume is the BIOS setting for ''power on'' post power failure?
Any ideas on what has gone?
Thank you all for your valuable time.
Douglas
  • 96 Answers
You should clarify this a bit more, but please make sure all of your fans are plugged in and the no jumpers are set to over-clock the processor.Also, double check that everything is fundamentally compatible.
Posted on Dec 16, 2008
Shuts down shortly after startup.
Check the ram. If its not the ram, take the heat sink off the processor and reapply arctic silver ( thermal paste) to the processor
Aug 26, 2012 | Gigabyte GA-8IK1100 Motherboard
Tip
How to detect and test a printer or any other device
Ubuntu live CD (that we can get free or make copy) detects a lot of drivers. For example hp laserjet p2015 so you can print you document on ubuntu form your hard drive if your printer can't work with vista. The amizing thing is that you don't have to install ubuntu, just boot from the CD/DVD and when you finish shut down the computer and remove the CD witout any effects on your current operating system
on Jul 31, 2010 | Computers & Internet
Hi, My sony Vaio VPCEA21FX, says that windows registry file is corrupt or missing. Thus am not able to login and it is not booting in to LKGC as well. I can restore to factory setting by but will lose...
try Ubuntu bootable disc or usb to boot from that. Ubuntu is a free operating system. you can use Ubuntu without actually installing it. you can run Ubuntu from a bootable disc or usb ......
such are called live CD or live usb.
running Ubuntu you can access the hard discpartition and hence your data and take backup os that in external media or another partition.
yoy can download Ubuntu freely. also you can order ubantu disc free of cost, even no delivery charges by post. just register and order Ubuntu from www.ubuntu.com
Apr 09, 2011 | Sony VAIO VPCEA21FX Notebook
Problems with dell optiplex sx 270 shutting down again n again
What Operating System are you running - if Windows what version XP, vista, 7? When is it shutting down, after you get into Windows (or other OS) or when trying to boot up? Are there any error messages? New machine or old machine - if old has anything changed? How long does the system stay working before it shutsdown? Is it getting too hot, fans blocked etc?
Lets start by working out if it is the hardware (Dell and devices connected) or the software (Windows etc) It is difficult to know without more details of the problem but here are my best suggestions
Try safe mode - running windows try in safe mode (F8 when starting windows), check error logs
Test the hardware - I would start by disconnecting all external devices, USB disk and other devices. If possible also remove any extra boards you have added to the machine. Even the mouse, USB sticks, anything plugged in (but leave the keyboard). Try this, do you get the same problem.
Test the OS - If you have a live CD such as Ubuntu (can be downloaded from here: http://www.ubuntu.com/desktop/get-ubuntu/download ) then try booting the system from this and see if you still get a problem
Can you run a virus checker on it, how long does the machine stay running. You can try downloading from here from another machine - http://www.avg.com/us-en/avg-rescue-cd-download and making a CD, run the rescue anti virus.
Apr 04, 2011 | Computers & Internet
My hp Pavilion a450n wont boot it shows the screen where it says Window XP and it shut down and for maybe 1 second shows a blue screen with some info and it goes back to asking to start window normally...
It sounds like your windows OS installation has been corrupted. Your computer might have a recovery partition like many HP models do.
Try hitting F11 when you first turn on the computer (watch the screen in the corners. It may say something like hit "F2 to go to BIOS or F12 to choose a boot device/ etc. Each computer is different in this regard).
If you can get into the recovery partition you may be able to do a windows repair. Alternatively, if you have your windows disc you can boot off the cd and run the windows repair tool like that.
I would HIGHLY recommend manually backing up any and all important files first. If you have a USB enclosure use that to pull the drive out and hook it up to another computer. If you dont then I would run a bootalbe version of linux or something and transfer your files to a USB drive or burn to a cd. See here to download ubuntu.
Mar 01, 2011 | HP Pavilion a450n PC Desktop
My computer freezes right after I turn it on. It does not open beyond the tobisha screen.
Sounds like you have a motherboard failure. This problem is very common with some HP laptop models, but not limited to HP unfortunately.
The problem is with the FSB controller chip that handles the work of the hard drive, dvd, keyboard, mouse, USB ports. In time, some pins from this chip lose contact with the motherboad which causes the laptop to experience random freezeups, slow responsiveness of the mouse and keyboard, and in some more extreme cases, the laptop gets stuck at the startup logo (The Toshiba screen), and in some cases even the startup logo is dimmed a bit.
There are two options: get a replacement motherboard, or fix the one you have. The repair of a non booting/random freezeup FSB problem is not too difficult, but you will have to open up the laptop. If you follow the link above, you won't need any special tools other than a screwdriver. The other option is to opt for a reflow of the FSB chip with a hot air gun.
Hope this helps. Please consider a Thumb Up vote for this post. Thank you.
Jan 20, 2011 | Toshiba Satellite PSAFGU-048002 Notebook
I have an ASUS netbook that runs linux. I don't know linux, but was told to upgrade to ubuntu. I don't know how. Anyone know how?
1. I would suggest finding out which model Eee PC you are using and the hard drive size & type (4GB SSD, 160GB SATA, etc...). If you have less than 4GB, I would probably recommend using another Linux distro, as the Netbook Edition of Ubuntu is pretty heavy.
2. Next, I would probably suggest plugging in the Eee PC (Software/OS installation is very power intensive).
3. Download your distribution (Ubuntu Netbook Edition or Desktop, etc).
4. Download a copy of unetbootin for your PC (unetbootin.sourceforge.net -- There are Linux & Windows versions available.)
5. Using a USB thumb drive (USB Memory stick), you will want to wipe the drive (format using FAT/FAT32 filesystem).
6. Run Unetbootin, selecting the proper USB thumb drive & ISO image from the Ubuntu website.
7. After Unetbootin is finished, close it and safely disconnect the USB drive.
8. Next, plug the USB thumb drive into the Eee PC.
9. Turn on power to the Eee PC & after seeing the initial BIOS splash, hit the ESC key on the keyboard. This should bring up a boot selection screen. Using the arrow keys, select the appropriate USB drive and hit Enter (Return).
10. If all goes well, you should be running Ubuntu Desktop/Ubuntu Netbook Edition as a live desktop. (The installer is a link on the desktop.)
11. There are several step-by-step guides out there, so check them out, if needed. The installer should be very simple on this type of hardware, etc.
Good Luck!
--TaoBeastie
Jul 07, 2010 | Canonical Ltd. Ubuntu
I was running a virus check, asked what to do, I said fix, computer shut down and alarm buzzer came on. now I don't get a boot sound
soks3d,
With the system shut down, unplug the power cable from the power supply. Open you're case and pull the memory from the system wait a minute than reseat the memory. Re-connect the power cable to the power supply. Try booting the system and enter the bios menu. (Pulling the memory will clear any memory resident virus). This has nothing to do with the alarm buzzer sound you heard. Typically the alarm sound is generated by the CPU. It's an audible warning that the CPU is over-heating. The CPU will shut down you're system so as not to damage the motherboard and CPU. (Suggest you check the CPU fan for dust build-up. Use canned air to help remove any build-up. You can also use a clean paint brush to help remove any dust from under each CPU fan blade.
It's also possible that the CPU fan is running far too slow and may need to be replaced.
See page 3-23 in you're user manual.
3-8. PC Health Status.
Open the link provided below for a new heat-sink and fan assembly for a socket 462;
http://www.directron.com/a4004d.html
If the CPU fan and heat-sink assembly seems clean it is also possible that the thermal grease / thermal tape between the heat-sink and CPU is too old and needs to be replaced. (Save this check for last).
Below is the link for you're motherboard;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=KV7-V&fMTYPE=Socket+A
Cheers'
Mike
Feb 20, 2010 | Abit KV7-V Motherboard
Can't find CMOS battery
Try booting up with a different operating system from your CD drive.
You can try Ubuntu 9.04 wich has a full operating system in a CD. you can even connect to the internet from this CD.
Aug 29, 2009 | Gateway M255-E Notebook
System shutdown
Systems that shut down after being powered on can point to an over heating of the CPU. Other factors come into play with overheating. Too much dust build-up on & under the CPU fan blades. Dust builds up in-between the heatsink fins (Thus the CPU fan can not cool the CPU chip.)
The CPU fan may be running too slow. When the PC system shuts down it’s saving you from hurting the system. You did not list the model number of you're system. Check you're system & clean the mentioned parts. Use canned air & a dry clean small paint brush to help remove possible dust buildup blow the dust away with the canned air.
Mike
Jul 23, 2008 | Intel Motherboard
Computers & Internet Logo
127 people viewed this question
Alun Cox
David Payne
David Payne
