Question about Brother MFC-7220 All-In-One Laser Printer
Black line down the center of the page when printing
When I print a page it leaves a thick black streak down the center of the page
    President:
  • Brother Master
  • 990 Answers
1,check the scannor unit,which is doccument feed in open the cover look the piece glass is clean.
2, replace drum cartridge.
Posted on Dec 16, 2008
Why do I get a thick black line down side of page when copying, but not when I print
Not sure, but one possibility is that your paper you are copying is not all the way to the edge of the copier. If there is a crack along the edge where light from the room can get in it will show up black in those areas. You will see the same effect if you leave the top of the copier off and try to copy something. There could also be something wrong with the scanner arm preventing it from moving all the way to the edge of the window.
Mar 12, 2015 | Canon Pixma MX452
When printing on x3350 with a new cartridge... get lines that are double and some with thick black ink on some letters.
Try to reseat the cartridges into the printer. If problem continues, then maybe the cartridge nozzles need cleaning. Follow the simple steps below on how to clean the cartridge nozzles on the Lexmark X3350:
  1. Go to Start, Programs (Windows XP: All Programs) > Lexmark 3300 Series > Lexmark Solution Center.
  2. Click the Maintenance tab.
  3. Click Clean to fix horizontal streaks.
  4. Click Print. A cleaning page prints, forcing ink through the clogged nozzles to clean them.
  5. Print the document again to verify that the print quality has improved.
Source: How to Clean the Print Cartridge Nozzles on the Lexmark X3350
Jul 13, 2011 | Lexmark X3350 All-In-One InkJet Printer
Brand new HP Colour Laser Jet 2605 printer prints a thick black line down the center
Print a cleaning page. If this does not solve the problem replace the black ink cartridge.
Jun 07, 2011 | Office Equipment & Supplies
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Thick black line on printed page
If the line runs the way that the paper does I.E. vertical on a portrait then it is dirty rollers normally.
If you open the lid and wipe the rollers this shoukd reduce or eliminate the black lines.
May 03, 2009 | Canon PIXMA® MP530 All-In-One Printer
Streak down the center of the page
The streak is most likely the toner or the fuser
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top or front to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the defect on the page the problem is most likely the toner cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Mar 25, 2009 | HP LaserJet 2840 All-In-One Printer
Black lines running down the prints
it seems that your print head is the problem you can try to clean it first..
but if you already try to do this no other choice is to have a service center o change it for you.
thanks,
Mar 20, 2009 | Sharp AR-M450N Copier
Brother printer that prints a black line down center
probably a bad drum cleaning blade, It's part of the drum unit
Feb 02, 2009 | Brother MFC-7820N Printer
Brother MFC-7220 All-In-One Laser Printer Logo
963 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
