Question about Kenmore 79013 Stainless Steel Gas Kitchen Range
Oven door locks and un locks code F90
The oven door lock will continue to lock and unlock while blinking door locked on control panel. If you hold the cancel button it will unlock and give error code F90 on panel but the oven is still not useable and will keep beeping until you hit cancel.
  • 1 more comment
  • kte9863 Dec 17, 2008
    After much trouble shooting, I was not able to get fault code to clear and we traced the problem to a faulty board. Part is $153.55 at local supply house.
  • Anonymous Mar 17, 2014
    Oven door is locked and will not unlock, it is giving me a -F1- code, how can I fix this?
  • Anonymous Mar 23, 2014
    light keeps flashing on display panel door locked
  • 8,197 Answers
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Posted on Dec 16, 2008
To reset the fault code you need to lift the stove top up by removing the 2 screws that hold the top down. they are located just above the top corners of the oven door. Locate the small black box in the middle near the locking mechanism. now you can hit cancel to reset the code, then before it flashes "F90" you flip the switch on the black box. This will trick the oven into thinking that the switch is working properly and will clear the code. The Door lock will not work any more and the code will re-appear if you try and use the self cleaning. but hey at least you can use your stove again.
Posted on Jul 14, 2009
We had the faulty code F90 that came up after our stove top won't work and got the F11. Holding down the stop/cancel button for 3 seconds worked to reset the F11, allowing our stove top unlock and work, but then the oven won't work. The F90 code came up. Could get that to reset. So we took the advice of Solution #2, earthen, and disconnecting all electrical power off for 5 minutes work!
Thank you for blogging this solution!!
Miss. Ducky
Posted on Nov 16, 2009
  • wickedkelly6 Oct 10, 2010
    I fixed it I took apart the mechanism pushed the arm back up and left it loose in the compartment it was in. This turned off the error message and unfortunately the self cleaning as well, but hey that's what elbow grease is for. So I have my oven back and no peeping. yeah.
    I had to take the top up and remove the front cover in order to get to the locking mechanism, and then I took earthens advice and pushed in the black button. It wouldn't stay in. I turned the power back on and it beeped again. I took it apart again and this time left it all lose and the lock mechanism unable to connect. That fixed it. Hope this helps seems a shame to get a new over or spend so much on a part just to not clean your oven, LOL
Oven has f90 error code and door stays locked cannot get oven top door
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Aug 27, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Door lock indicator lit up but did not try to lock door. F90 err. After unplugging it for over 5 min and plugging it back in the door is still locked and will not unlock.
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jul 12, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I get a code f90 when trying to either lock the oven door or attempting to clean the oven
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Jun 26, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
Code f90 indicated
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%#
May 26, 2010 | Kenmore 47153 Stainless Steel Dual Fuel...
F93 error code
unplug the range.
wait 1 minute.
wait 2 minutes.
Apr 24, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Frigidaire FES367FCC. Oven is flashing F90.
unplug the range.
wait 1 minute.
wait 2 minutes.
Apr 11, 2010 | Frigidaire FES367 Electric Kitchen Range
F90 code on Fridgidaire range/oven
unplug the range.
wait 1 minute.
wait 2 minutes.
Jan 04, 2010 | Frigidaire FEF352 Electric Kitchen Range
Beeps - won't stop - f90 code - thinks door is locked.
unplug the range.
wait 1 minute.
wait 2 minutes.
May 23, 2009 | Frigidaire FGS365EC Stainless Steel Gas...
What does the errror code F90 mean?
unplug the range.
wait 1 minute.
wait 2 minutes.
Nov 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
F93 fault code
unplug the range.
wait 1 minute.
wait 2 minutes.
Oct 04, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Kenmore 79013 Stainless Steel Gas Kitchen Range Logo
5,476 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
