Question about Northstar Generator 9 Hp, 5500 Watt, Gasoline
Northstar 5500 9HP Generator
9 years old , it's been in storage since the y2k scare. never been used,hasn''t even had fuel in it till today. It seems to want to start, there is a little smoke coming out but it won't kick over.
  • 3 Answers
Ok, try and take the bowl off and clean it out with some carb cleaner. Also open the carb top and shoot carb cleaner down it for several seconds repeatedly. If it has never been used it still was started and tested at the factory. It has gunk build up on the nedle and is probably stuck. This happens to alot of carbs even sitting for only a few years. Just take the carb apart as much as you feel comfortable with and spray carb cleaner all through it. Move the movable parts alittle and then try it. It has to work . P.S. Look in the gas tank and see if there is any rust in it. If so you need to pour some deisel fuel in it and sloush it around and dump it.
Posted on Dec 19, 2008
I have an ETQ TG60H12 6000 wt generator. It has .9 hrs because I only fire it about once a month. I've noticed a wet spot on my shed floor but was never able to determine the origin until I noticed a leak...
remove and let the tank dry out you can then get a product that you pour inside to cure the leak, cant remember the name of the product most bike shops would be able to get hold of it
Oct 23, 2013 | Northstar ETQ DG6LE Portable Generator...
Briggs as Stratton 6.75hp 190cc push mower by Craftsman (Crapsman!) will not run unless I hold the throttle open!
adjust air fuel mixture screw on main jet ,start about 1.5 turns out and slowly turn in till runs smooth
Mar 01, 2012 | Measuring Tools & Sensors
I have a 97 ninja 900. It hasn't run in atleast a year. When I tried to get it started, it took a little effort to get it to fire up. Then it stalled, started, stalled, started. Now it won't even...
I would siphon the old fuel out and replace it; if you didn't add any fuel stabilizer when you last ran the bike, the fuel has probably gone stale. I use stabilizer in all of our lesser used 2 & 4 cycle fuel eaters. It really does seem to help since restarting (especially summertime gadgets, including one car) happens cleanly.
Sep 06, 2011 | 1997 kawasaki ZX-9R Ninja
I have a 5500 ppg generator that won't start. I've verified the fuel lines to the engine are delivering fuel, but won't start. I've been able to pour a small amount of fuel down the carb...
Hello, ushicks/me hillybilly. One question how old is the fuel in then generator tank,Hey. If it has a fuel filter replace it. Modern gasoline is junk fuel and after a few months it looses some chemical proprieties. GB...stewbison
Aug 23, 2011 | Northstar Generator 9 Hp, 5500 Watt,...
I have a 2006 vento 150 cc scooter 48 miles on it and hasn't been started in 3 years Q - DOES IT A SPARK PLUG TO CHANGE Q- SHOULD I DRAIN THE FUEL OUT AND IS IT USEABLE IN THE MOWER OR WEED EATER
hi.
if it has not been started in 3 years then a new spark plug would probably be a good idea, but not essential if the old one is cleaned.
3 year old fuel should be drained and is pretty much no use for anything. you may be able to start a bonfire with it, but i would not even try to run a machine on it after 3 years.
it would also be a good idea to change the oil and clean the air filter. the battery will almost certainly need changing as well.
there should not be any major problems though.
hope this helps
Jul 17, 2011 | Vento Agility City 50 Motorcycles
Had the Ryobi RHT2660DA for just under a year. Used it last year with no problems. Went to start it today and it wont start. Any ideas?
If you left it sitting since last year with fuel in it the fuel has gone bad. Today's fuel has ethenol in it and that causes the fuel to start going bad after about a month. I suggest dumping the old fuel out into a container and using new fuel.
If really helpful, please rate.
Jul 13, 2011 | Garden
My northstar lantern lites then goes out within 20 to30 seconds. Is it the generator? and if so what # generator do I need? The lantern is about 8 years old and used once or twice a year.
If the problem is that it loses pressure quickly (that is, you have to pump it up again and then it will light briefly), the problem is most likely the cap. It has a rubber gasket underneath that has probably dried out and isn't giving you a good seal. These caps are common replacement items, all the same size, available at Walmart, Kmart, etc. Another likely culprit is old fuel. Many years ago (like 30) the fuel lasted nearly forever. But sometime since then, the fuel has been reformulated making it work better in the short term, but having a limited shelf-life. If your fuel is more than a year or two old, try some new fuel.
Dec 20, 2010 | Coleman Northstar Dual Fuel Lantern
Northstar Generator 9 Hp, 5500 Watt, Gasoline Logo
231 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Jim London
Jim London
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
