Question about Magnacraft ® Riflescope
Will this scope handle black powder recoil
I have a magnacraft riflescope 3-9x40 recoil proof But will it handle the recoil of a knight Vision muzzleloader shooting 150gr Thank you, Lonnie
    Problem Solver:
  • 4 Answers
Yes it will!
Posted on Feb 08, 2009
Loose reticle,
Unscrew the scope tube from the center section. Not recommended.
Nov 25, 2013 | Bsa Optics Black Powder 3-9x40 Riflescope...
Scope insternal adjustments do not do anything. This is the second new scope I have had this problem with. I have borescoped the rifle and no change in either windage or elevation screws over entire...
One of the things about bore sighting is there is no shock to the scope. They are meant to have some shock that goes along with an adjustment. Try smaller adjustments and tap the tube of the scope with a screw driver handle after every adjustment. Not so hard you dent it but hard enough to get stuff moving. Hope this Helps FixYa up.
Aug 24, 2011 | Simmons 511070 4x32 22 MAG Riflescope -...
I got in a tight spot needing a scope last season. I was very short on cash so i bought a 3-9x 50mm cheap Tasco . I sighted it in at 100 yards. I missed the first deer . Two hours later I shot high on...
well one day you may lurn that cheap is cheap! and tasco is rubbish cheap! i would say without dought the cross hair in the scope has shaken apart,,,due to recoil,,,a 30-06 has a big recoil
try holding the rifle stock on your jaw and firing the rifle off?
when or if,, you wake up in hospital with a shaterd jaw and with no teeth left in it you will know then! and cheap tasco scope is an air rifle scope it cant take 2500ft/lbs of recoil???
so it wont take much of a kick to mess it up,,
i put one on a 303 enfield??? i got 3 shots before it fell to bits!
if your going to buy cheap scope's go for nicon gold crown?
Aug 26, 2010 | Tasco Riflescope 3-9x50 Dwc39x50n
Is it possible to adjust the factory setting parallax on Prostaff for air riffle use?
It is possible but not advisable. It should be done by a professional and requires special tools.
If you have a spring loaded gun, the binary recoil will destroy it in short time. If it's a PCP, you want a scope with on-the-fly adjustable parallax for range finding.
My advice would be to change this scope for a dedicated air-rifle scope.
Aug 14, 2010 | Nikon 3-9x50 Prostaff Riflescope In Matte...
I wanted to purchase an np 75, wanted to know if it would fit a 7mm rifle, or would the recoil damage this scope, also can u add an illuminator to this, and if it was pitch black how far could u see with...
il tell you this much i have one of them and i put it on a 7.62 full bore rifle,,,thats got a kick like a horse too! its quite happy sat on this rifle,,,(with over 500 rounds put through it so far) it did fall off though! my fault that was,,,i never bib it up tight? an air rifle has a far more damaging recoil than a full bore rifle has??? its true!
the russian gear may look cheep but its built like a brick sh*t house
and will take all the recoil you can throw at it,,
il take a bet with you,,,your shoulder will give up first before the russian nv gives up,,,,wont to pay me now???? you just lost!
Jul 11, 2010 | Kalinka NP-75 Russian Night Vision Scope
Using the scope
Well if it was a rifle, I would say far away, or you will get a black eye. But the recoil on a pellet rifle is backwards because the spring jerks the rifle forward, and it messes with rifle scopes, they are made to recoil back, But,,, you have a movable eyepiece in the end where you look through and it will make the cross hairs come into focus for your eyes. some one else might find them blurry. The objective lens, should be in focus no matter what. It doesn't move. and no matter what your vision is, you should be able to see clearly. If not, I'm wondering if it is fogged up. Your eye should be about 3inches, + -, Check it out. Hope this helps.
May 04, 2010 | Crosman 4 x 32 Air Rifle Scope, Black
Bausch & Lomb Balvar 6x24 Rifle target scope
Bushnell owns baush&lomb scope I have called them to repair my elite series bausch&lomb and I have been very happy with there customer service.They might be able to help with your problem to.
Mar 01, 2010 | Bausch and Lomb Bausch & Lomb Hunting...
Scope won't sight in
Yes, rim fire scopes can't be used on a stronger firearm as the recoil will alter the internal mechanism. I fought with scopes of all types for years until I bought a used Leopold, never finding a better one! Hope you can find one of those.
Dec 13, 2008 | Bushnell Sportsman 4x32 Riflescope (4x32...
Recoil from 300WSM
Well, it Barska says it's .50 cal proofed, whatever that means. One would presume it could take 30 magnum recoil then.
On the other hand, Barska is a low end quality manufacturer. You cannot expect durability in a low end scope. Of course, you could get lucky.
Unless you're target shooting at an immovable object, 10x - 40x is much more power than you'll ever be able to use. You're much, much better off considering a 4x - 16, for instance, in a higher end scope line than this scope.
Consider that at 40x the exit pupil would only be 1.25 which would make even the highest quality scopes quite dim. Barska won't have be best glass in the world and so would probably be unusable beyond some level like 18x unless in very favorable conditions anyway.
The problem with heavy recoilers and scopes is that the heavier the scope the more likely it is to take damage due to recoil. It's because it hangs out there on those high scope rings, and is heavy.
Nov 06, 2008 | Barska Optics Barska 10-40x50 Ir Swat...
Magnacraft ® Riflescope Logo
85 people viewed this question
Top Magnacraft Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
Are you a Magnacraft Optic Expert? Answer questions, earn points and help others
