Question about Samsung TX-R3080WH 30" TV
TV turns off after a few seconds
I have a 2 year old Samsung DLP HLR5067WAX/XAA .. Lately the TV turns off as soon as its turned on and a picture appears. I have to turn it on over and over 6 to 10 times before it will finally stay on. Once it is on, after this ordeal it plays perfectly. Bright, excellent colors and very clear. It will play for hours with no problem. Just have to get it going. What could this problem be caused from? Bulb? Thanks for any help !! Tony
  • 3 more comments
  • tm1955 Dec 17, 2008
    I'll check the timer but i never use it, plus the tv turns off as soon as it comes on over and over. The timer can't be for less than 15 minutes so it wouldn't turn off so quickly. Good thought though, that never crossed my mind. While I check the timer, what was your other solution ? Thanks so much for your help.........
    dss
  • Anonymous Dec 25, 2008
    Same problem, but it won't stay on at all. Exact same tv.
  • DLP_Prabhu Mar 30, 2009
    I have the same problem and I replaced both lamp and balst. Still tv is not turning on. Anbody have any solutions to this problem.
  • h_leslie
    h_leslie May 11, 2010
    have you checked the timer on your t.v. to see if it has been mistakenly turned on somehow? if you've ruled this out i have another solution! i hope this was somewhat helpful..
  • Samsung Master
  • 4,033 Answers
It could be the bulb on the way out, they don't like to turn on if the inverter does not get a voltage use from the bulb, while trying to turn on the tv look at the vents for the bulb if you see it flicker on and of while trying to turn on the tv when it would be the bulb. when the tv is on and work hold a peace of paper over the vent not to cover it but to look at the bulb light if you see a flicker or bright and dim and repeats doing this then the bulb is warn out. if you hear clicking or scratching sounds this could be the inverter board on it way out.
Posted on Jul 03, 2017
5 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: 46" Samsung DLP Lines & Freeze up
This is a possible fault in the power supply, and can be a problem with some decoupler caps on some of the boards. The vertical bars and unstability are usually attributed to having high frequency noise and or clocking pulses crosstalking on to the power distribution lines that run through the boards. This can be switching power supply noise, or cross-talk from clocking pulses.
Another thing that can cause your described fault is unstable clocking between the devices that are reading and writing to the data busses. There are a number of data busses running through the set for the boards to be able to communicate with each other.
The tech will use the process of board swapping to service the set, and then do the adjustments as necessary to make sure the new boards match up.
Yes... DLP sets are fairly expensive to service!
This is my personal opinion. If the set is out of warranty, I would change for a Plasma or LCD set. If you compare the performance of these to ther DLP, the difference is very big. From what I am seeing from a service point of view, the DLP's are lower in reliability.
Jerry G.
Posted on May 06, 2008
  • 32 Answers
SOURCE: I have no color on my samsung hln5065wx/xaa DLP
If it is just no color but you still have a picture it should be your digital board. This is the board that mounts behind the light engine and should be encased in a shilver colored metal sheild
Posted on Aug 13, 2009
  • 8457 Answers
SOURCE: Have a Samsung HLR5067Wax, I
U recheck all the input and output wires connections take out and put back in for the replacement of the projection lamp?The tv colors wheel might be also dead too.Picture now,flashes colors or black&white within the picture itself?Any humming or motor noises,any these causes are the colors wheel is dying,require replacement of the tv colors wheel.
Posted on Dec 15, 2010
  • 170 Answers
SOURCE: Replaced lamp light in Samsung HLT4675XS/XAA 1 year ago. TV is now turning off. The lamp light looks colorful but not bright. The standby light stays on after turning off the TV. Lamp light blinks twi
I have a model close to yours & mine did the same thing. Its an easy fix the problem is its over heating. Unplug the tv take all the panels off the back of the tv and you will see lots of computer boards but look for one that has heat sinks and & small fan attached to it. Clean all the dust out in that area at the minimum but best to blow out all the dust on everything.
Make sure you are discharged cause if you spark any computer board it will be toast.
Posted on Feb 04, 2012
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Is there any way to buy a CPU for HLR5667WAX/XAA? How to replace it?
If you TV is 9 years old it is questionable whether further repairs are economically worthwhile.
Jun 05, 2014 | Samsung Cooling Fan Set for HLR5667WAX/XAA
I replaced the lamp on my Samsung HLS5086WX/XAA DLP set. How do I reset the timer on the lamp?
I have a Samsung DLP HLN617WX/XAA. After turning off by itself, the three indicator lights were blinking... signifying a defective lamp. I've re-seated the old lamp several times with no change. I bought a new lamp and reset the lamp hours through the "service menu" with no change. My television is still turning itself off and still blinking the same indicator lights. What should I look at, next?
Oct 26, 2010 | Samsung Televison & Video
I have a samsung HLS4266WX/XAA about 3 years old with white dots.
This is a known issue with Samsung DLP sets. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Jan 01, 2010 | Samsung DLP HL-P5663W 56" TV
Dlp TV won't turn on
possible color wheel , or just a lamp. depending on what the noise sounded like. check out some videos on you tube on how to replace color wheel. Not to hard
May 27, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
2 y/ old Samsung DLP TV (HLR6167) - no sound
your problem is most likely not the Tv i bet you are using an air antenna arent you
Feb 16, 2018 | Samsung HL-R6167W 61" HDTV
We have a Samsung HLP5674WX/XAA which seems to have a mind of it's own. It will automatically shut off or when we turn it own, there will be no picture with sound or once it turns on, the TV will shut...
I have a Samsung HLP5474WX/XAA. The ballast was replace 2 months ago. I just installed the lamp, i notice green flashing occur on the LAMP when i turn it on. The tv takes 10 to 15 second to turn on the picture, the sound as soon as i power up i can hear it. Any advice??
Mar 18, 2008 | Televison & Video
Samsung TX-R3080WH 30" TV Logo
109 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
