our whirlpool super capacity 465 electric oven/range has a similar problem. the lights and display all work, but the oven nor the range will heat up. any solutions?
My Dacor smooth top range is not working at all EXCEPT for one light at the Main Dacor Logo below all the individual burner switches. This unit is 12 years old but normally works perfect. I toggled the main breaker, which was not affected by this. That's all I'm comfortable with.
What does this mean? My model is not marked with a #, but it's a 5-burner black-top and the only paperwork the seller left was a flyer with a model # of CET 3658, which is has manual knobs for burners, and mine is all touch-pad.
Can anyone help me?
Comment by Guest, posted on Dec 27, 2007
we have a similer problem. when the stove is turn on, one of the two lights is out and the cook top is got have the power only. please notify me with a solution.
Ranges have dual breakers in the breaker panel, on mine ONLY one tripped thus not supplying enough power to the elements, but enough for the clock...CHECK ALL BREAKERS IN THE BREAKER BOX FIRST! Hope that helps :)
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on Except for the lights my entire range is out....what can I check ?:
Solution #2
posted on Aug 08, 2005
Perkins - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
A - This normally means you have lost something in the main power...check - 1) - The fuses for the range in the your main house fuse box or the breaker for the range in your house fuse box. 2 ) - If you feel brave - remove power and pull out the range and look at the wires where the main power comes into your range....this connection block sometimes gets loose and burns.
