Question about Whirlpool Dryers
Clothes take longer to dry
Whirl pool electric dryer, 8 years old seems to take alot longer to dry than it used to.
  • 113 Answers
The first thing to check on would be your ventillation. Check at the outside of the house to make sure you have a strong amount of airflow coming out of the vent. Should blow pretty hard. If not you need to get your vents cleaned and also make sure the duct behind the dryer is not crushed. Hope this helps. Dave www.washermd.com
Posted on Dec 16, 2008
Why is there water in my dryer
Sounds to me like your washer is not going into spin cycle, and someone is throwing sopping wet clothes into your dryer. Do you have kids that cannot understand that you cannot stuff the hell out of your washer or dryer, because the clothes need room to tumble, agitate etc? Some 30+ year olds cannot seem to grasp this in my house, but then, they think that electricity is free too.
Jul 26, 2014 | Whirlpool WED9270XL Dryer
Drying time taking to long
Try putting a vaccume cleaner as far down the vent hose as it will go and suck anythng in there out, , And if you can put a vacume cleaner attachment in the lint trap and suk some stuff out as well ,, other than that i doubth that there is anything else that can cause the problem...
Jan 16, 2008 | Whirlpool CSP2761 Gas Commercial Dryer
JLTDC01 Dryer not collecting water in the tank
ck your vent hose,there may be a block vent not allowing air to move around clothes , causeing long drying times.if vent hose is ran long way.more then 4ft say 15 or longer,it should be cleaned once a year or replaced.this in my opinion is the most main problem when having dryer issues.
Feb 25, 2013 | Dryers
Dryer heats up, but does not dry clothes. Vent is clean
As you can see, your heating element has 5 heating coils. If one or more of these coils have opened you dryer will still work and heat but not at well as it would if all coils worked together. You can check each coil with an ohm meter to verify if one or more is open.
Jan 01, 2012 | Kenmore 64742 Electric Dryer
Whirl pool duet dryer not drying clothes
Inside the door under the filter housing is 2 strips that sense wetness. If they have dryer sheet goop on them they won't sense moisture. the dryer will therefore thank them clothes is dry. Clean them sensors with windex and party on!
Nov 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
GEW9200LWO takes longer to dry clothes than it use to. checked according to to use guide trouble shooting. dryer is 8 years old and runs fine other wise.
Check your lint vent hose and the vent to the outside part is clogged. If any lint is built up it will restrict the air flow hence longer time to dry.
Oct 17, 2009 | Dryers
Dryer vibrating alot and making alot of noise.
check the felt around the inside of the door to see if it needs to be replaced
Apr 23, 2009 | Dryers
My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Moisture sensor does not seem to work
your heating element may be bad if your cycle completely finishes and the clothes aren't dry. If
Jan 28, 2009 | Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
