Question about Kenmore 63763 Microwave Oven
I need vent dimension for Kenmore Microhood combination model #8162. Is the vent at the back 3x10 or 3x12?
  • Kenmore Master
  • 9,098 Answers
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View Manuals" button.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside. This is where you will find that information.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Posted on Dec 17, 2008
How do I change the front exhaust to top exhaust on a Kenmore microwave/hood
In order to change the venting on the microhood you need to uninstall the unit and at the top of the microwave is the blower unit. Remove the cover, flip the blower and you should then see the fins on the motor, reinstall the unit under the cabinet and your good to go. I hope this helps, good luck
Mar 15, 2015 | Kenmore Microwave Ovens
Just need to re set the clock
Barbara, Google the model number with "manual" to locate (if you do not have it) the book.
Or, contact the customer service for this unit--I am sure with the recent time change they are getting a lot of calls.
Nov 08, 2012 | Kenmore Elite Over The Range Microhood...
No power
see this causes and fix it. God bless you
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Sep 27, 2012 | Kenmore 30 in. Microhood Combination
Kenmore elite ultrawave microhood combination error code F9
F9 is normally a bad door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 22, 2008 | Kenmore Microwave Ovens
Kenmore Microhood 401.80089 - L SE L error
The 401 model prefix means it's actually made by Samsung.
On some Samsung models, there is an odd SE error message that seems to be vexing a lot of people.
It's probably a sensor going bad, or maybe scrambled code in the microprocessor, but it's odd.
There is one discussion of it here.
I hate to say it, but since it's a Kenmore brand, you're going to have to call Sears for service.
You can find them at http://www.sears.com
I really hope they can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 07, 2008 | Kenmore Microwave Ovens
Kenmore microhood model 721.80833500
our tray that goes around and back and forth jumps the tracks and stops and turns the other way I can put it back on track before it makes a round it jumps the tracks again and starts going the other way is there a part that need replaced
Jan 13, 2008 | Kenmore 80809 Microwave Oven
Kenmore microhood
"Microhood" seems to be a slang term for the "microwave hood" (hood fan or exhaust fan) which is normally part of an over-the-range microwave oven or range. But these should be available separately, as I seem to recall. I would contact home centers such as Lowe's, Home Depot (if they still exist), etc., or a local appliance store.
Dec 06, 2006 | Kenmore 62622 Microwave Oven
Microhood turntable not working
You can find an exploded view of your microwave at http://www3.sears.com (yes, the 3 is there). Ref # 3009 on the drawing is the turntable motor. I would grab it by the shaft and gently try to turn it. If it's locked up or grinding, that's a sign it's bad. It runs $24.49 plus shipping: Part Description: Quantity: Part Number: Model Number: Price: TT MOTOR 6549W1S013D 721.64663300 $ 24.49 $ 24.49 Be sure to unplug the oven before you work on it. Hope this helps!
Dec 01, 2006 | Kenmore 63763 Microwave Oven
Stainless Steel Kenmore Elite 36 in. 2.0 cu. ft. Microhood Combination Model 63763
Generally the F9 code indicates a problem with the door latch (usually upper) or with the control board. You can do a Google search for my text file "doorsw.txt" to help you diagnose and repair door switch trouble. BUT - since it always stops at 53 seconds, that leads me to think you have trouble with the control unit (circuit board / controller assembly). Once you read and digest the info on door switches, please feel free to do an updated post and I'll be happy to help you further. It may be corrupted ROM in the control unit. But let us know what you find out. - online they call me "William E. Miller, AS-EET"
Oct 15, 2006 | Kenmore 63763 Microwave Oven
Kenmore 63763 Microwave Oven Logo
123 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
