Question about Dell Inkjet 720 Printer
Blue ink may be clogged
I have a dell 720 and have been having problems with the blue ink coming in. I just bought new ink cartridges and then ran in through the 'cleaning' and it works a little better. It's not great, but better. It's only on the blue. Is there anything else I can do to help it?
    Genius:
  • 2,035 Answers
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Jan 20, 2009
Dell 720 color cartridge doesn't seem to be printing with enough 'green'...all pics tinted red. New cartridge. Is is possible to balance the color any better?
Run a "print-head-cleaning" cycle -- some of the ink-jets may be clogged, thus reducing the amount of ink reaching the paper.
Try "photo-quality" paper.
Jan 28, 2010 | Dell Inkjet 720 Printer
Dell 720 printer , new ink cartriges but prints blank pages
I know it sounds silly, but never underestimate the obvious.
Did you remove the plastic protectors from the cartridges?
Another solution maybe to return the cartridges to the store for an exchange. It has only happened once to me, but I exchanged the cartridge for another "new" one and it worked fine.
Good luck
-Carlos:
Jan 07, 2010 | Dell Inkjet 720 Printer
After installing ink cartridges, my printer worked ok the first time using the new cartridges. Now, the color blue doesn't come out. I've tried aligning and all the other things.
If the cartridges are not the official HP ones then this is a common problem and in the long run I would say that it works out cheaper with official cartridges.
Either way I would return the cartridges because if they installed and aligned correctly it is a manufacturing issue.
You could try buying some others to test if it still happens or if the problem persists, this will give you more clarity on the source of the issue
Nov 25, 2009 | Dell Inkjet 720 Printer
My dell 720 printer has a new ink cartridge, acts
Take the plastic strip off the ink jet cartridge before putting the thing in the printer.  Check the ink jets to see if they are clogged.
Oct 25, 2009 | Dell Inkjet 720 Printer
Dell 720 won't print color, color ink cartridge missing
check to see if the color cartridge has the plastic tab on the cartridge. Remove and reinsert cartridge.
Sep 13, 2009 | Dell Inkjet 720 Printer
My dell 924 printer will not print the blue color I have cleaned the cartridge twice but still no blue
The color cartridge is empty or clogged (blue is magenta). Your were right to try cleaning it, but even new ones from the store often fail. Good luck.
Jun 30, 2009 | Dell Inkjet 720 Printer
Will my dell 924 printer still work without the blue cartridge
when you put the black in you had to also put the blue in do you have the empty cartridge if so put it back in for right now and see if this helps
Jan 09, 2009 | Dell 924 All-in-One InkJet Printer
Printer will not print in color
I have put in brand new color and black and white cartridges. The black works fine on the test pages, but not one bit of color shows. How can I fix it?
Apr 18, 2008 | Dell Inkjet 720 Printer
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
Dell Inkjet 720 Printer Logo
54 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
