Question about GE Spacemaker JVM1640SJ Microwave Oven
Cycle stops and won't run until the clock is reset
My microwave frequently stops in the middle of a cycle and won't run until the clock is reset.
  • William Miller
    William Miller May 11, 2010
    What is your model number?
    Does it always run for a specific amount of time before it stops, or it seemingly random?
    Scholar:
  • 111 Answers
The magnetron cooling fan blade is either slipping on the motor shaft or has spun and fallen completely off the shaft. It can be reattached to the shaft as it just slides on. Several well placed drops of 5 minute two-part epoxy from Home Depot or Lowe's dripped into the hole in the fan blade before you slide it back on will insure that it doesn't come off again
Posted on Dec 20, 2008
Microwave stopped working
Probably a problem with the door latch safety system. This happens every so often with our microwave, which is over 25 years old, and otherwise works perfectly.
If yours is new, it may still be under warranty. If not, there are places that specialize in fixing microwave ovens.
If it is an older, or less expensive oven, it might be time for a new one.
Jul 22, 2014 | Sharp R-1500 Microwave Oven
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
Oct 27, 2017 | Emerson MWG9111SL Microwave Oven With...
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
Locks up and powers down during use leaves a F2 display on the clock window
Can't tell by pict for sure, IF this is a Microwave that is vented. Is it possible your vent it needs to be cleared. Sounds like possible moisture in the microwave, This would shut it down in the middle of a cycle. The moisture would happen from poor or clogged venting.
May 04, 2009 | Whirlpool MH1150XM Convection/Microwave...
Oven shuts down after a few seconds into cycle time for cooking
The magnatron (heating element) is located in the cavity behind the control. If it's leaking microwaves onto the electronics, this will occur. This means the Mag should be replaced and a radiation test run on unit.
Mar 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Resetting clcok on Microwave Oven..
I have a Magic Chef microwave oven, The model # is MCD1311ST.
After I reset the clock when daylight savings time ended, it displays 1:00 PM as 13:00, 2:00 PM as 14:00, etc. How do I get it back on a 12/12 cycle instead?
Warren.
Nov 08, 2008 | Magic Chef Microwave Ovens
Microwave suddenly and radomly turns off
yes ,the latch switches will need to be replaced , bad connection
Nov 06, 2008 | Sharp R-1480 Microwave Oven
Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Whirlpool GH6177XP Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
50 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
