Question about Brother IntelliFAX 4100 Laser Fax
Gears grinding with Brother Intellifax 4100
I put a paper in the automatic feeder and then tried to remove it but the paper was already feeding through. I pulled it out and now the machine is making a terrible grinding sound when it prints or receives faxes. The sound is coming from the front left when facing the machine. I removed the toner cartridge and cleaned it, but that didn't solve the problem. I am probably going to need to take it somewhere to be fixed, but thought I'd try this first.
  • 328 Answers
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 01, 2007
Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Nov 16, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax feeder is pulling sheets through at the same time
Sounds like the separation pads in the paper tray are worn out. You can contact Brother and purchase the parts from them. It should be less than $10. as long as the paper is being pulled from the tray it sounds like the rollers are okay.
Oct 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Original jammed in fax feeder of Brother Intellifax 2800
lift document feeder cover and look for paper. if no paper is present there are one or two switch levers that are on the bottom of feeder cover. make sure they can move freely and are not stuck.
May 27, 2009 | Brother IntelliFAX 2800 Laser Fax
PAPER JAM
If you pull the drum out of the machine. Close front cover. is the noise still there. If it is then you have a broken fuser gear. If noise is not there remove the toner cart. from drum reinstall the drum unit in machine see if noise is there. if noise is there then it will be the drum. If not reinstall the toner try that if noise comes back then it is your toner cart.
Apr 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Paper Jam
Hi Art,
Try cleaning the rubber feed rollers with a good grade of isopropyl alcohol.
Make sure the side guides of the feeder are not too tight.
Nov 22, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother 4100 intellifax
Check the blue tab on the inside of paper tray and make sure it is on correct paper size.
Fax machine is very sensitive so try not to put too much paper in it.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Intellifax 4100 grinding noice
Probably caused by the toner cart. Only use genuine new Brother brand supplies. Remans fail quite often with Brother machines.
Possibly bad gears on fuser drive. But with the poor print quality, I suspect it is the toner.
May 02, 2008 | Brother IntelliFAX 4100 Laser Fax
Auto paper feeder not taking paper
Try removing the paper, then removing the drum from the machine. Check to see there are no obstructions, then re-insert the drum, making sure that the gears mesh properly. Load the paper, setting the paper width guides and then try printing a report.
Nov 13, 2007 | Brother IntelliFAX 2800 Laser Fax
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax 4100 squeaky sheet feeder
The doc feed asm needs to be rebuilt. Only white lithium grease is used to lube the gears and avery light oil on the shafts. All parts are available from brother. I can get the parts if you have trouble obtaining them. It is relatively easy to rebuild and I charge in my area of Clearwater Florida, about 100.00 parts and labor.
Apr 19, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
462 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
