Also it tends to run very rich and will idle but will not take throttle
You need to have the bike serviced at a shop that can correctly clean the carb and empty the gastank and put fresh fuel in. Sometimes carbs get dirty in places you cannot see. Those places are the reason your bike doesn't run right.
SOURCE: yamaha yzf750r missfire rough running
Try taking air cleaner off before going to far, Blow carbies with air, dont use full force I done this to mine and it fixed it you may be lucky dirty jets.
SOURCE: High idle on start-up
Its your idle senser sits on top of the manifold u will see it looking at u when u take off air filter cover. Little black plastic.plug in.
SOURCE: High Idle On Start-up.
Most fuel injected motorcycles do start up in a "fast idle" mode. Although I don't know much about fuel injection on Harleys (H-D will not tell you much about it unles you are one of their technicians), I don't think the system is equipped with an engine temp sensor. Since the crank case sensor get it's pulses from pockets cut into the outer edge of the left side flywheel half, the sensor will have oil on it.
SOURCE: suzki ozark 250 cleaned out tank and carb runs but will not idle
sounds like the float is not working properly , could also be the jet. would be a good idea to buy a carb kit, not very expensive and save a lot of grief.
SOURCE: throttle hesitates early, and also stalls when trying idle-carb
yes it sure does. get fresh gas too. if you are in the US, get Berrymans B12 fuel additive, double dose throw in tank and run bike til hot, then leave it to stand overnight. see how it is next day. if no better. remove air cleaners and get spray Berrymans , lift up sliders in carbs and spray a ton inside, again leave this overnight to break down the gum and varnish. if neither work then you are gonna have to pull them carbs and open them up to clean.
