Question about E-Machines e15t 15" Flat Panel LCD Monitor
Monitor Switched Itself Off, Won't Turn Back On
I was sitting at my computer a couple of nights ago when my monitor switched off. Screen, power light, everything. The light on the transformer on the cord is still on, and when I unplugged it and plugged it back in, the computer made its obligatory noises for when you unplug and re-plug a USB device. I rebooted the computer, and still, no dice. Anyone have a suggestion?
Some older LCDs (I've only encountered this issue with LCDs) are 100% "comfortable" only with their
native resolution. So, if the resolution is set to anything but their native resolution problems like
the monitor wouldn't wake back up can be faced by the user.
On the other hand, some older LCDs can be "unhappy" with particular resolutions and by trial
and error the right resolution where your monitor won't play tricks on you anymore can eventually
be found.
Posted on Oct 09, 2008
If you have another monitor at home, try the other monitor. If not, take your computer to a friends house and try their monitor. I have a similar problem with my Compaq Presario SR1120NX. It turns on fine, then after a while screen saver kicks in, turns off monitor. Monitor status light turns amber. I move the mouse and it never turns back on. Have to hold power button down, then turn back on to get video back. Any suggestions?
Posted on Apr 06, 2007
  • 624 Answers
With the computer on shine a flashlight on the screen where the Windows Start button would normally be. If you can faintly see it then your backlight has malfunctioned. Check your warrantee to see if you?re still covered. If not then it is repairable at most TV or computer repair shops. If you can?t see anything with the flashlight try connecting the monitor to another working PC. If the problem follows the monitor: -Check the monitor for bent or corroded pins. -Again see if you warrantee is still active or take it to a repair shop. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Mar 22, 2007
I dont want to look at the No HDMI Cable Message after the computer shuts down. Is there a way to make the screen go blank more quickly. Or do I have to watch the message scroll across the screen for 10...
A couple of options. First and cheapest, you could turn off the monitor. Second, for about thirty to fifty dollars, you can pick up an energy saving surge protector. With this, it has a main plug, and switched plugs. The switched plugs cut power when the main item is turned off. I.E. PC turned off, monitor, speakers, printer all turn off a moment later.
Dec 11, 2011 | Dell ST2420L 24 inch LCD Monitor
Not able to turn it on. for no apparent reason the screen was black after setting overnight. The pilot light was on. tapped the space bar a couple of times thinking the computer would wake up and desk top...
I have the same monitor & just had same problem. Did you find a solution to your problem? This is the second time my monitor has done this. The first time I had problem i unplugged it and disconnected it from pc. Plugged it into power source and blue pilot light came on then went off. I did see the LG logo on screen before it shut down. After several times doing this and pressing the power switch repeatedly it seemed to reset and recognized it was not receiving a signal and indicated this. I then reconnected monitor to pc and all appeared to work fine for several days. Now I again have same problem after sitting over night.
Dec 02, 2009 | LG W2252TQ Monitor
HP vs17X monitor blue power ligth blinking, nothing on screen
Sounds like a power surge fried the electrical connections inside.
Jul 14, 2009 | HP Pavilion dv9000z Notebook
The W1907 goes blank when i turned the monitor off and then on
I would say don't turn off the monitor at the switch at all unless you are not going to use it for a long time. I just leave mine switched on and the power save blanks the screen if I am away from it for 20 minutes. I leave my PC switched on all the time as well. If I need to use it for any reason it takes ages for it to start up fully so it's more convenient to just leave it all going so it's ready when I need it. If away from the PC for a day or more switch it off but I keep going back to it all day and night so it's easier for me to leave both on all the time.
Jun 17, 2009 | HP w1907 LCD Monitor
When I turn my monitor on a "Going to Sleep" message is displayed on a black screen and then the screen goes all black. We had a power outage acouple of nights ago and the pc was on. Since then our power...
It will be video cable or related.
Responding to prior post,
Fuses have nothing to do with the video proper.
If you have a message on the screen, which says the monitor is basically working or saying the fuses and inverter is working.
That message appears with lack of video, so it can be the cable itself, possibly the video card on the computer.
Dec 20, 2008 | HP Compaq 1501 15" LCD Monitor
Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
ekwhoward@yahoo.com.
Thanks
Ekow
Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
Dell E193FP Problem
Probably a failing power supply
Apr 17, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
ViewSonic VA912b (Back light with blank dark screen)!
the capacitors in the monitor give out have to see a technician
Aug 19, 2007 | ViewSonic VX910 19" LCD Monitor
E-Machines e15t 15" Flat Panel LCD Monitor Logo
203 people viewed this question
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
