HP J6480 has very grainy, smudged document scans AND copies.
When scanning documents, I get very grainy, streaked and smudged scans with a dark band across the short axis of the document. Copies come out with the same streak pattern, so I thoroughly cleaned the glass but with no better results. Increasing scan resolution did not help and I could not fix the images by tweaking the settings in the HP Document Manager program.
Any suggestions?
2 Suggested Answers
mohanchennai
  • 490 Answers
SOURCE: Vertical Light Streaks on text documents, both single and duplex
Clean the glass thoroughly using Isopropyl alcohol. Dont use solvents. Check if there is any scratch on the glass. Repeated scanning with stapler pins can scratch the glass. If it is scratched, you may need to chage it.
S. Mohan, India
Posted on Jun 13, 2009
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
Why is the photocopy and scanned document coming out dark and unreadable?
Hi there, my name is Lisa and I'd be happy to help you with your J6410. I understand your copies and scans appear dark and unreadable. Although you may not be seeing vertical bands, lines, or streaks through your scans and copies, I feel the following document might help you to troubleshoot the issue you have described:
HP Officejet Flatbed Scanner All in Ones With ADFs Vertical Bands Lines or...
Since the issue occurs when you perform both copy and scan tasks the issue is somehow related to the hardware and not to the software. Do you have the printer connected directly to a wall outlet or is it in a surge protector or power bar? Even if you have been using a surge protector/power bar all this time and you feel it is not the cause, please connect it to a wall outlet just so we can eliminate the power source as the root cause. Issues when Connected to an Uninterruptible Power Supply/Power Strip/Surge Protector In this document you will see, ISSUE: Problems or issues may arise when an HP LaserJet series printer is connected to an uninterruptible power supply (UPS), a power strip, or a surge protector
^ This is not limited to Laserjet printers.
If the issue persists, what you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process:
Step 1. Open link: h22207 www2 hp com
Step 2. Enter Product number or select to auto detect
Step 3. Scroll down to "Still need help? Complete the form to select your contact options"
Step 4. Scroll down and click on: HP contact options - click on Get phone number
Case number and phone number appear.
I hope this helps.
I work on behalf of HP.
Jul 12, 2015 | HP Officejet J6410 All-in-one InkJet...
How do I fix a dark streak down center of scanned document on HP laser jet 3330
Lines and streaks are usually caused by ink or trash blocking the scanner pickup. You need to open the top of the scanner and clean the scanner glass. Here is a link to a guide that shows where to look for something blocking the sensor.
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
May 07, 2012 | HP LaserJet 3330 All-In-One Printer
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
S. Mohan, India
Mar 11, 2009 | Panasonic KV S2025C Path-Through Scanner
It seems like part of the light on the copier has burnt out...can the light be replaced? I get a thick dark streak in a copy or scan but not when I print something. Have replaced ink and aligned...
Light is not burnt out.
Open the feed in section where you feed the documents, and clean the glass that documents are scanned across. It is simply dirty
Mar 08, 2009 | HP Officejet 6310 All-In-One InkJet...
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
207 people viewed this question
k24674
Marvin
Marvin
