Question about Microsoft Xbox 360 Console
360 3 RINGS OF DEATH FOR THE 360 IS NOT THE GPU ITS THE GPU AND CPU HEAT SINK PASTE AND CLAMPS BETWEEN THE HEAT SINK AND CPU CHIP
  • 53 Answers
Send back 3 rings is a manufatcer mistke
Posted on Jan 10, 2009
Xbox 360 has 3 red rings.i purchased a new output cable and that did not solve the problem does not show a ppicture on tv.
Hi, first of all check if you have any warranty as this fault is covered by 3 years warranty from microsoft, so check the date on the back of the xbox, if its less than 3 years old go to their website and enter your details and they will send you out another xbox in place of yours.
if its more than 3 years old or if its been opened before then you have 2 options either pay someone to fix it or fix it yourself.
what 3 red lights are telling you is that you have the dreaded red ring of death, you get this due to the gpu and or the cpu chip over heating, now the most likely causes of this are as follows.
1 the aire ven has been blocked at one end of the xbox stopping cool air being sucked into the xbox, this air vent is the bottom part when you stand it up.
2 after prolonged use the xbox sucks in dust and this blocks the heat sinks and stops the cool air being sucked throught the heat sink and then the gpu chip over heats
3, over time the circuit board can warp causing loss of connection between teh gpu and or cpu chip.
now what has happened is one of the above has caused either the gpu chip and or cpu chip to over heat and this has then caused either bad connection between the gpu and or cpu and the heat sink, so getting the heat sink paste replaced may solve the problem, how ever most cases of rrod is due to the fact the 2 chips have over heated and the cheap lead free solder microsoft uses to bond their chips to the circuit board has failed causing a loss in connection between these chips and the circuit board.
check if you have warranty as this fault is covered
if you have no warranty then you need to either pay someone to reflow the solder or risk having a go yourself and making matters a lot worse, its not easy to do if its the 1st one you have ever done as getting it wrong is very easy, now if as soon as you switch it on you get the 3 red lights this means the chips need reflowing but if you switch it on and the fans run slow but then speed up to top speed then this indicates the the heat sink paste needs teaking off the gpu and cpu chips and also off the heat sinks and new paste putting on.
if you plan on doing this repair yourself use google and search for free rrod repair guide how ever dont ever try the towel trick it will only get it working for few hours then it will be beyond repair, or dont put it in the oven this will destroy most of board, the only way i have found you can do it yourself is by using a heat gun with 2 settings on it and you use the lowest settings, you will be shown this in the guide.
also search for this how to fix rrod using heat gun then hit search follow these instructions carefully getting it wrong will destroy your xbox, just taking it apart is a nightmare on its own so you have been warned, i can send you a repair guide if needed just send me your email address ok
now if your going to fix it yourself use google and type in how to fix rrod on xbox 360 then hit search and have a look at some of the sites, now the chances are the gpu chip will need reflowing now this can be done with a heat gun on its lowest setting, but getting this wrong can do more harm than good.
the best thing to try first is the xclamp fix, go and buy a xbox 360 repair kit off ebay make sure you get the heat sink paste with it, you can get these kits for next to nothing and if you find one with a repair guide then that will make it easier for you, without these parts you wont be able to fix the xbox anyway.
dont do the towel trick it dont work and it causes more harm to the circuit board so dont try that one.
just use google type in how to fix rrod on xbox 360 and look for a guide that shows you how to replace the x clamps with normal machine screws and renew the heat sink paste, its not hard to do and you will get a guide off google with pictures so im sure you can give it a go.
if how ever replacing the clamps dont solve the problem then use google again and type in how to fix rrod with heat gun on xbox 360 then hit search then look through the sites and look for a decent guide that shows you how to do this, dont use a hair dryer like some sites may suggest they just dont get hot enough to reflow the damaged solder under the gpu and cpu chip.
if you do use a heat gun make sure the circuit board is lying flat if its not you will do alot more harm than good so make sure its level.
i cant point you to these sites as its against site police but use google and you will find all you need and you should be able to get it sorted. if its less than 3 years old and you open it up then your warranty will be void and microsoft wont even look at it,
now i repair these for 20 quid plus parts so it comes to about 25 quid, but im in UK and the chances are your somewhere else in the world.
if you are unsure what your doing then please dont try repairing this yourself as you could do a lot more harm than good.
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Dec 21, 2010 | Microsoft Xbox 360 Console
Ring of death
Dec 19, 2010 | Microsoft Xbox 360 Console
Thebutton u turn the xboxon is flashing red why?
Dec 09, 2010 | Microsoft Xbox 360 Console
We have a XBox 360 that has the 3 rings of death on. Can you help us?
Hi you have got the dreaded red ring of death, this is very common with all xboxes and their are people out their that will fix them for you for a fee.
their is nothing you can do yourself to solve this problem as its a case of taking the xbox apart and removing the heat sinks and the x clamps and fitting new parts and new heat sink paste, this is a big job and requires special tools. so its not for the novice to do.
i do the repairs to these on a regular basis and 8 out of 10 i fix work again but others tend to be to far gone.
any way the reason you are getting this warning light is due to it over heating, check the date on the sticker on the back of the xbox as it is covered by warranty for 3 years for this exact fault so if its less than 3 years old go to the xbox website and get them to replace it for you, if its outside this time then you have 2 options you could either repair it or sell it.
you can buy repair kits and get the instructions off the net but without having done it before it can by really hard to do and you could do more harm than good.
when they built these they used cheap parts and cheap heat sink paste now over time this causes it to over heat and then you get the dreaded red ring of death and this shows you the either the gpu or cpu chip has over heated.
now the repair involves taking the xbox apart which is not easy but can be done you need to then remove the x clamps and then remove both heat sinks. once their removed you need to clean them up and remove all the old heat sink paste and use new paste, you also need to get xbox rrod repair kit as you wont be using the cheap x clamp bits anymore these will go in the bin as this is what caused the problem in the first place.
let me know what you would like to do or if you need further assistance ok
i also be damaged xbox's but im based in UK
if you are going to do this yourself then make sure you have no warranty left as this fault is covered for 3 years by microsoft so if the date on the sticker on the back of the xbox is within this time all you need to do is go to the microsoft webiste and tell them and they will give you a replacement.
i charge 25pound to do the repair so you should be looking around this price if you are paying someone also their is no guarantee the repair will work as the damage caused by the over heating could have destroyed the cpu or gpu chip but you wont know this till after the repair work has been done.
if you are doing the work yourself then you need to get a erpair guide off the net so just google rrod repair guide and this will list loads of sties with these guides, you will also need to buy an xbox 360 rrod repair kit, you can get these off ebay for next to nothing, then you need to get some heat sink paste and some special torque screwdrivers to remove the xbox case.
this is not an easy job to do and getting it wrong can do a lot more harm than good if you put to much pressure on the heat sinks when you put them back on this will destroy the gpu and cpu chip so be warned.
make sure you get a guide and correct tools or if you are unsure get someone to do it who knows what their doing.
plz rate this solution as i have a whole page of unrated posts, thanks
rrod xbox360
Sep 30, 2010 | Microsoft Xbox 360 Console
Red rings of death
0008
Sep 25, 2010 | Microsoft Xbox 360 Console
My uncle got the 360 and after a week of having it it stopped working, so he gave it to me. I am wanting to get it fixed because it is showing the red 3 rings I wanted to know where I could get it fixed...
004
Sep 24, 2010 | Microsoft Xbox 360 Console
One red light on my xbox 360
HI the problem is with the console and not the game the chances are it is starting to over heat but do the following first.
1 check the air vents and make sure their free from any dust.
2 leave the console off for at least an hour.
3 make sure your console is not being used whilst its on carpet as this will cause it to over heat really fast
4 make sure its not on top of anything else such as dvd or sky box as this to will cause it to over heat
5 make sure its not in a confined space it needs to get air circulating around it
now if the red light keeps coming on then the chances are pretty soon you will get the dreaded red ring of death all the time and you wont be able to use the xbox at all.
check the warranty sticker on the back if the console is less then 3 years old then you can contact microsoft via their xbox site and get it exchanged for a refurbished one you wont need a receipt as the sticker on the back of the console will have a date on it so check this first
also if the warranty sticker is still in place behind the front cover then they will exchange it for you but if the console has been opened up then they wont even touch it.
if the warranty is out on your console then the only option is for you to get it repaired.
now the problem is when microsoft built these they used cheap metal x clamps and these hold the heat sinks onto the gpu and cpu chip to prevent it from over heating they also used cheap heat sink paste and what then happens is over time the x clamps dont keep pressure on the cpu and gpu chips so this then causes it to lose its cooling power as the hear sink is not pressing on the chips hard enough.
so what you need to get done is get the xclamps taken off and the cpu and gpu chips cleaned to look like new and also the bottom of the heat sinks then new heat sink paste will need putting on top of the cpu and gpu chip then a more secure way of holding the heat sinks onto the cpu and gpu chip is needed, now its not easy to do so if you have never done anything like this before then its best leave it to someone who knows as its a nightmare just getting the case off let alone making sure you put the heat sinks back on level.
now i do this repair for about 25 quid plus parts which usually the total is no less than 30 quid and i only charge the labour if the xbox is fully working after the repair so if your not doing the job yourself you will need to shop around and get the best price you can do.
how ever their is no guarantee the repair will solve the problem as the cpu and gpu chip could have got that hot that it has damaged the solder that holds it onto the circuit board now out of every 10 i do only 2 will not be repairable so the odds are pretty good on getting it fixed, the repair takes a few hours and normally solves the problem then most people never have any more problems.
let me know if you need further assistance ok
Sep 20, 2010 | Video Game Consoles & Games
Removing the red rings of death
Sep 15, 2010 | Microsoft Xbox 360 Elite Console
When I turn on the system, it flashes red lights rather than green lights. What could it be?
oh thats a big problem you have three rings of death you wiil need to repair it that happens about every four years
Nov 10, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
50 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
