Question about Sharp LC-20AV4U Television
My sharp LC-20AV4U tv did not turn on when i plugged it in
I moved the TV from the bedroom to the living room, so I needed to plug it back in along with the DVD player. I plugged the TV in first and when I plugged it in – I was behind the TV at the time - I thought I noticed a flash, not sure where it came from exactly on the TV – but must’ve been the screen. I didn’t think much about it at the time as it didn’t seem that big and I thought it might’ve just been a flash from the outlet when the plug entered.
I then tried to turn on the TV – but nothing happened – no sound, no click, no pop. Nothing. Tried unplugging it, and replugging it, moving to another outlet etc – still nothing. I then read online that sometimes as a safety feature, the TV will shut itself off - and if you leave your set off and unplugged for 6-8 hours it will reset – allowing you to turn it on again. So I waited until the next morning and then plugged it back in and tried it again – still nothing.
So I took off the back of the TV and found that the little 4W 125V fuse was blown. I didn’t see any other noticeable damage, so I picked a few new fuses up at Radioshack and replaced it, then plugged it back in. As I plugged it back in – I heard the fuse blow – sizzle,pop. I tried the power button – again nothing.
So I guess something is causing the power to come in at the wrong wattage/voltage and thus cause fuse to blow – powerpack, voltage regulator or whatever.
  • idil578 Dec 18, 2008
    many thanks. i will try to get a multi meter & do as you suggest. will let you know the results. thanks!
    Problem Solver:
  • 15 Answers
The fuse is blowning because most likely when you plugged it it, it took a power surge. And the power surge blow a proection diode. As long as you opened it up... in the power section you will see a bunch of diodes. Get a multi meter and check these diodes out. Besides the diodes... you will see a transformer.... if you are looking at the unit with the fuse to the left... then look to the right of the transformer... you will see a transistor on a metal heat sink... that could have blown also.. if that did... then you should also check the diodes just on the other side of the heatsink too.
Good luck
Posted on Dec 18, 2008
Aerial Socket on LG TV ceased working
Most likely the TV has a burned out receiver board.
May 24, 2017 | LG Televison & Video
I have a Sharp LC-C4655U TV that was purchased and used in the USA. I have no moved to Europe where the current is 220v. Do I need a transformer or converter or may I simply plug the TV in the socket?
Sir most of the tv today is auto volts try to check the voltage rating at the back of your tv if indicates 100 to 240 volts you can just plug it in you don't need a transformer. Feel free to send feed back good day and best regards.
Aug 17, 2011 | Sharp LC-C4655U 46 in. LCD TV
My flat pane sharp LC-20AV4U does not turn on. The power light is gone (usually it is orange when off and green when on) switch gets power and works.If I had a wiring diagram I probably could figure it out
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 04, 2011 | Sharp LC-20AV4U Television
Sharp LC-37SH12U LCD TV is 20 months old and would not power on
Your power supply unit needs servicing on some part replacements. bad capacitors, voltage regulators, hi-watt resistors,....etc
Nov 03, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Problems moving the router and getting the internet.
your bedroom cable phone plug has issue.
These is not dial tone or low voltage problem in line.
So just replaced that phone cable and jack .then check.
Aug 07, 2009 | Linksys WAG200G Router
No sound
Check the back of the tv for a switch that says speakers. Switch to internal
Apr 23, 2009 | JVC AV-48P575 48" Rear Projection...
Moving TV's from one room to another
tSounds like you have a PIP window open. Is everything else black excpet for that small "internet box?"
Mar 20, 2009 | Vizio L32 32 in. LCD HDTV
Polaroid Model TDA-03211C
Our tv sharp aquos LC 52 GD^U 52 in. HDTV LCD plays a narrative along with the closed captioning on selected channels, especially channel 2. We cannot get it to turn off and it is annoying to the point of wanting to return the tv. Please help.
Jul 14, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Picture settings messed up!
Loose cable or wrong setting. Channel, input type, etc. Also. make sure the audio isn't plugged into the video input [either end]
Dec 03, 2007 | Toshiba 27AF45 27" TV
Thomson dsi 4200 satellite receiver
The only way this would work ( and this applies to any form of cable/satellite box) so the only way this works is if the TV that has the satellite connected to it has a video output normally indicated with the color yellow, but you still need sound that normally is the red and white (RCA cables). So the first tv needs to have video and sound outputs and the TV you want it connected to needs to have the video and sound inputs. depending on the distance between the 2 TV's this might prove to be rather difficult. it would be easier to run the coax cable from the main satellite box to the room where you have the 2nd TV however to do this you would need to move the satellite box back and forth. Hope this helps
Aug 22, 2017 | Televison & Video
Televison & Video Logo
195 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
