Question about Panasonic VB-43220 Corded Phone (pandbsvb43220)
Do Not Disturb
Someone managed to set my phone on DND. Would you please tell me how I can remove this? Thanks.
  • Diana Diaz Mar 22, 2007
    Thank you so much! We didn't have the manual. ;)
  • 944 Answers
Go to this link; http://service.us.panasonic.com/OPERMANPDF/407296700.PDF Page 4-45 of the manual (page 161 of the pdf) explains the procedure. It is not for exactly the same model, but i hope the procedure is the same. Hope this helps :) post again please if not
Posted on Mar 22, 2007
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
How to turn off ringer at particular extension?
Do Not Disturb (DND)
When DND is enabled, the telephone will not ring when someone calls, but the line
indicator still flashes. In Personal Call Manager, the
You Have a New Call dialog box
still appears and the icon for the call appears in the Calls box.
You can turn the Do Not Disturb (DND) feature on or off from the
Calls menu or the Personal Call Manager icon in the task tray.
Turning DND on or off
To turn DND on or off:
1. Click the Personal Call Manager task tray icon or the
Calls menu.
2. Click the DND menu item.
When DND is on:
• the Personal Call Manager task tray icon changes to
• the symbol check
appears beside the DND menu item on the Calls menu and the
Personal Call Manager task tray menu
• DND appears in Status bar
Oct 23, 2013 | NorStar Meridian M7310 Phone
When someone calls messae says' not accepting calls' how do i turn this off
Does this happen on all inbound calls or just some?
If this is on all inbound calls...Sounds like Do not disturb is turned on. Most uniden's have a DND (do not disturb) mode. Try turning this off and see if that helps.
Using Do Not Disturb
  • The Do Not Disturb or DND feature turns off the audio ringers of the base and all handsets at the same time. It does not affect any of the visual ringers.
  • With the phone in standby, press and hold Do not Disturb on the base. The phone automatically turns on the answering system and shows Do Not Disturb in the display on all handsets.
  • To cancel, press Do not Disturb.
If this is not the issue, it may be turned on at the central office (your phone company) try using the DND activation/deactivation code of *64 from your phone.
If this is just on some inbound calls...Then it you may have anonymous call rejection turned on. That feature blocks calls from people that block their calling number when placing calls.
Mar 01, 2012 | Uniden DECT 6.0 Cordless Phone ID
How do i remove dnd on a samsung dcs 408 pabx ?
The short code to disable Do Not Disturb is 400, 401 sets the Do Not Disturb. I have sent you a video explaining Do Not Disturb on a Samsung DCS, there are other useful tips on youtube if you search for abbeytel. Please visit www.abbeytelecom.com for written introduction, thank you
Nov 04, 2010 | Panasonic KX-T7730 Corded Phone
Ge cordless phone model #28111ee2-a,the face of the phone says do not disturb,how do i get it off?
CLICK HERE for your owners manual.
The Very Last paragraph states the following...
DND allows you to mute the ringer on all handsets.
In the standby mode (phone handset off and in cradle), press the do not disturb button on the base. The DND indicator will light and DO NOT DISTURB shows in handset display.
To cancel, press the do not disturb button again.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 31, 2009 | Uniden Cordless Phone
My unidin is saying dont disturb
To cancel the DND feature, press do not disturb again. (this is either a key on the base unit, or can be found in the Menu on the base) You can also mute the ringer tone while the phone is ringing by pressing do not disturb on the base.
Activating the DND while the answering system is off will turn the answering system on automatically. The answering system setting will reset to the original setting when you cancel the DND.
Jul 02, 2009 | Uniden 5.8GHz Dual Cordless Phone
My uniden powermax 5.8 ghz set itself to Do Not Disturb.
The do not disturb feature (DND) allows you to mute the ringer, the base, and any registered handsets at the same time. The phone must be in standby mode. Press and hold do not disturb on the base. You will hear a confirmation tone, and the DND LED illuminates. To cancel the DND feature, press do not disturb again. You can also mute the ringer tone while the phone is ringing by pressing do not disturb on the base.
If you press answer on/off when the DND and the answering system is on, both of the DND and the answering system will turn off.
To mute the ringer tone temporarily for each handset or the base, when the phone is ringing, press the MUTE soft key on the handset or the base. The ringer tone will return to the previous setting starting with the next incoming call.
May 28, 2009 | Uniden 5.8GHz Dual Cordless Phone
Can't remove DND off display
press the [world] setting button, then choose settings
choose call preferences.
change DO Not Disturb to NO
press save (middle button)
press back
press exit
johanvt
Jul 28, 2008 | Cisco 7912G IP Phone
Taking off DND
press "feature" 69 then press "feature" again ~ problem solved!
May 16, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Panasonic VB-43220 Corded Phone (pandbsvb43220) Logo
136 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
